Porsche smorche - I have a car habbit
  • chondamx
    • 247
    #31
    Why in the actual fuck?
    '91 318is M52 Turbo (in pieces)
    • slammin.e28
      שמע ישראל
      • 12054
      #32
      • DEV0 E30
        • Oct 2004
        • 8893
        #33
        944 Spec Racing is fun to watch.
        I wouldn't want a 944 as a project though...
        • Ether-D
          • Sep 2011
          • 2838
          #34
          Thanks brocephus.
          Originally posted by Andy.B
          I was born on 3/25…
          • slammin.e28
            שמע ישראל
            • 12054
            #35
            Yeah man. They're like the 944 peeps
            • Ether-D
              • Sep 2011
              • 2838
              #36
              It really is. Idk if this will be race car or street car. Likely street.
              I was born on 3/25…
              • Ether-D
                • Sep 2011
                • 2838
                #37
                If a 1983 rabbit has the same ignition housing and the same ignition switch as my 944, wouldn't you assume it takes the same ignition lock cylinder? Cause the 944 one is $60 and the rabbit one is $12. What gives?
                I was born on 3/25…
                • Andy.B
                  • Sep 2011
                  • 1650
                  #38
                  One says Porsche and the other says VW. I come across the same thing with my vw bus. It shares an engine family with the 914, so I get to pay Porsche prices for VW power.
                  Nothing like 5k to rebuild a 70hp motor...
                  • Ether-D
                    • Sep 2011
                    • 2838
                    #39
                    Time for a swap. Bam. Done.
                    I was born on 3/25…
                    • Ether-D
                      • Sep 2011
                      • 2838
                      #40
                      I'm about to do a full ignition lock cylinder swap on this car. Bam. Done.
                      Btdubz, I pulled the ignition switch off the back of the lock cylinder housing. Dropped in a battery and got it to turn over. The cam is off and all of the valves were closed but it sounded healthy so far. So we know the starter works. Now we're getting somewhere...
                      I was born on 3/25…
                      • pandaboo911
                        • 2070
                        #41
                        only thing 944s are useful for is engine swaps
                        • Ether-D
                          • Sep 2011
                          • 2838
                          #42
                          I pulled the head yesterday. All exhaust manifold bolts came off with ease. There was a decent score in cylinder #4. I could catch my fingernail in it. I think I'm gonna ignore it though. It'll probably be ok, so I ordered all of the gaskets and seals for it. I'll have them next week.
                          So what might cause 1 cylinder to have a score? Debris? Oil starvation? All of the above?
                          The rest of the motor seems nice and tightish.
                          Having one of these motors rebored is apparently a bit of a bish. I've read that it's some special process that most machine shops don't have the tooling for (because non-sleeved aluminum block). At this point, I'm not afraid to pull the block out and take it to a machinist, but don't wanna dump too much money into it just to see if I'm going to like the damn thing.
                          Will a relatively small score cause lots of problems? Or will it just have slightly lower compression in that one cyl and lose a smidgeon of power and whoopty-frickin-doo who cares?
                          I was born on 3/25…
                          • Ether-D
                            • Sep 2011
                            • 2838
                            #43
                            I read the internet and this is the answer. Good, cause it's many grands to redo an alusil® block correctly. Super!!
                            I was born on 3/25…
                            • Ether-D
                              • Sep 2011
                              • 2838
                              #44
                              K, so I got all of the gasketry for the entire motor. Ebay - $230. Not too bad, a smidgeon more expensive than the m20 equivalent. I also grabbed a new used cam tower for $75 so, that is neat. Ima drop the head at the machinist tomorrow morning for a skim and lap as well. The it's on, as if it were Donkey Kong.
                              I was born on 3/25…
                              • varg
                                Florida Turbo Man
                                • May 2014
                                • 3413
                                #45
                                I like the look of 944s, can't say I wouldn't buy one and mod the crap out of it if I had the chance. I want to see how this turns out!
                                It's a few less grands to ditch the meh-tier M44 for something a little more skookum
                                How about an M20 powered 944 ;D
                                IG @turbovarg
                                '91 318is, M20 turbo
