So interestingly enough, I did the injector dead time test today using the method above by switching from 1 squirt simultaneous to 2 squirts simultaneous and checking if the AFRs remained constant. I wasn't able to get the AFRs to remain exactly the same(.3ish off), but the best dead time turned out to be 1.13ms as I was running before. Since that doesn't seem to match the given dead time value that I've found online for Bosch 55# injectors, I think the injectors I have might be modified. This also leads me to believe that I had asked the PO for the dead times and entered them in when I got it running for the first time.
Anyways, I adjusted the timing and AFR table a bit and did some more Tune Analyzing tonight. By the end of the drive the car felt like it was running really well. Once I get the VE table a little more dialed in I'll start throwing some more timing at it and take some logs to throw into Virtual Dyno.
Here are a few of my tables right now.
