e10 2000 touring OBD2 S52 Build - Classicdaily / Blunttech
  • jakeb
    • 1909
    This car is done and back to Brando at blunttech but I wanted to post the build (and will start being better at posting build threads).
    This was a very quick and dirty build. We built it about a month from pulling/parting the donor e36 to driving the car 900 miles to AR (midam) and then Brando driving it 700 back to MN.
    The car already had upgraded suspension and brakes.
    On to the build and pics.
    The car (this was after engine was in and running)
    Started by dropping a spare m50 block in with e34 oil pan and no trans.
    Cut some of the front shelf out but not all.
    That's Tim
    Early on fitting with the trans.
    You can see it's long in an 02 bay
    Things were so tight that the crank pulley was close to the lower nose panel. So we had to make a cut.
    How it fits with the engine in.
    And very close back at the firewall
    We ended up using the g240 trans from an m42 because it has an OD and is a lot smaller to fit in the 02 tunnel.
    It still required some heating and beating. This was a bit more than was needed in the end.
    Underside as it is getting fitted
    We did have to bend the center track rod down a bit to clear.
    Pictures as we were fitting things before the mounts.
    Throttle body is a tight fit but clears above the booster. A different throttle linkage was made.
    Throttle linkage
    And for fun a turbo would probably fit......
    Making mounts
    Passenger side
    drivers side
    Going in for the last time
    The radiator is made for a jeep but then we flipped the inlet and outlet.
    Has a pusher fan in the nose and a puller off to the drivers side.
    Fan had to be shaved a little to clear the alternator.
    Not exactly sure what the driveshaft is from. It was one I had on the shelf and fit after pulling the center out a little bit. A new CSB mount was made later.
    bimmerworld shifter
    Sorta an odd exhaust routing but we wanted to fit the largest glasspack we could in the center to make it quiet (which worked out).
    touring tank is VERY deep. touring sender on the right. 318is pump and sender on the left. Extended the pump down as low as possible with the wiring that was on the pump. As you can see when the gauge reads empty there is still a good amount of fuel the pump can still reach. But....there is still some it can't reach at the bottom of the tank.
    Finished engine bay pictures
    2 days after we got it running we took off for AR to mid america 02 fest.
    Just before leaving.
    Our home for many miles
    No speedo...but at least a tach and GPS.
    Half way there
    Feel Free to post and ask any questions.... The car is done and back in MN.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • getouth
    • Jan 2010
    • 3343
    Grassroots!! Good shit!
    FEEDBACK:
    http://www.r3vlimited.com/board/showthread.php?t=316212
    BMWCCA #398608
    IG @yagayo38
    "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
    • SSR-125
      • Jan 2014
      • 578
      looks sweet man, nice progress
      88' E30 325 24v Turbo Coupe
      91' E30 325i Sedan
      09' E82 135i Coupe (Sold)
      01' E46 325ci Coupe (Sold)
      97' E36 328is Coupe (Sold)
      91' E30 325i m52 Coupe (Sold)
      90' E30 325is Coupe (Sold)
      90' E30 325ic Coupe (Sold)
      88' E30 325is m20 Turbo Coupe (Sold)
      88' E30 325 Coupe (Sold)
      87' E30 325e Coupe (Sold)
      86' E30 325es Coupe (Sold)
      • jhaurimn
        • Nov 2012
        • 2224
        Nice :)
        Current:
        1989 325i
        1988 M3
        1987 325ic
        Past:
        2001 330ci
        2001 M3
        • CorvallisBMW
          Long Schlong Longhammer
          • 13039
          Wow, talk about a sleeper. I bet that thing hauls balls!
          • dirty30
            • 3092
            totally awesome!!!
            • jakeb
              • 1909
              Yeah it is quick. It still has an open small case diff in it so you have you respect what it is.
              • e30polak
                • 6136
                How bad does this throw the weight balance off? I've driven an m20 2002 and it was pretty noticeable (more so than my s54 in my e30).
                INSTAGRAM: @UNDR8D_EMPIRE
                • Link
                  • May 2012
                  • 834
                  I love the simplicity of the build thread. I've never scene that style '02. Good job on the build.
                  View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
                  • blunttech
                    • 12850
                    I was really surprised how well it handles. We did all the suspension before Jake got it so its got good stuff but I was expecting it to be worse. Its not.
                    Cant wait till it gets a strong diff in it so it can be thrashed. Its ridiculous
                    sales@blunttech.com
                    www.blunttech.com
                    Like us on Facebook
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      Man wish I could of saw this when I was up at your place Steve.
                      1991 318i 4dr slick top
                      Mtech 2 turbo restoration
                      • semaj4712
                        • Mar 2012
                        • 3069
                        Pretty cool, I would personally pull the stickers off and make it a nice sleeper
                        29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
                        72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
                        Gewerkschaft der Polizei Sticker/Clings For Sale $8
                        • 2mAn
                          SeƱior Mod
                          • 21010
                          how much for a set of engine arms?
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          Make R3V Great Again -2020
                          • phreshkid
                            • 4655
                            This looks like such a great idea.
                            I have just the car for this. But I'm wondering why not just go s54 if an s52 will fit? Actually I don't really wonder. The s52 with g240 is plenty. But then you'd have to change the rear end gearing to a 3.73LSD or 4.10LSD if you really want to be a stoplight to stoplight monster.
                            And I know Jake makes those rear end conversions too.
                            Damn it. Damn it. Damn it. Nothing is stopping me from writing a check and sending a shell and motor.
                            • jakeb
                              • 1909
                              $300 for engine arms
                              hehe it really is a good idea! The car we did has a 3.64 and gearing is nice. xway at 80 you are right around 3k rpm. But plenty of pickup.
