Now that is a fill and drill!!
1990 325is restomod project aka "Klaus"
Finally did a little this weekend, pulled the front hubs off and replaced them with brand new hubs and bearings. I cleaned up the dust shield a bit which I realize I may have to trim a bit for the new brakes. I test fitted the rotor. Next step will be to install the new calipers and pads.
The old rotor set screw was so rusted and stripped I couldnt get it off so I removed the entire hub with the rotor attached.
All off, and yes the PO painted not only the calipers blue, but the rotor hats as well.
Forgot to buy new dust caps, they are on the way. I still have to torque the nut down and bend the tab in.
[/url]
And a little test fit of the caliper, just held up for now.
Originally posted by sonomabimmers View PostJust read all this, WOW. Bringing new meaning to B(rought)M(y)W(allet)
those wheels by that NC crew are SO clean! and clean work man!Paynemw
1986 Toyota 4Runner SR5 - Sold!
the ebb and flow of 325is ownership - In RVA
1988 BMW 535is - RIP but my dream BMW
Question on bolt direction for the BBK.
I know the instructions said for the ones that bolt to the OEM caliper brackets you put the bolts through so the nuts are on the back side (closer to the engine instead of the rotor).
As for the ones that go from the bracket to the actual caliper, logic to me would say they would go in the same direction with the nuts on the back side close to the engine.
Although I saw a pic of it the other way, they work in either direction, so I guess it doesn't make too much of a difference but I would like to do it right.
Pic for reference, I put one on one way and one on the other to illustrate.
This is the pic of someone else's install with their bolts the other way.
If put the head end on the caliper - more surface area to grab. Let the nut sit on the bracketI BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Originally posted by bradnic View PostIf put the head end on the caliper - more surface area to grab. Let the nut sit on the bracket
Got the other side wheel bearing done and mounted both front Calipers. I havent switched over the brake lines yet, I will do that this weekend.
In the mean time I for some reason wanted to change my radio, nothing wrong with the one I had, I just wanted buttons!! I sold the old one on the board this morning, LOVE that panjo is gone or it would have never sold.
Anyway I havent pushed it all in and closed it up yet but here is the new headunit, I got the colors pretty close, in this new one you can use an App to dial in the colors basically infinitely. When I get a change I will play with it more.
nice. I had the same pioneer audiquattrot uses in his IX. switched back to the IR slider CM5908 radio and added jaysterling's BT board. OEM FTW!
so glad panjo's gone.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Originally posted by bradnic View Postnice. I had the same pioneer audiquattrot uses in his IX. switched back to the IR slider CM5908 radio and added jaysterling's BT board. OEM FTW!
This one was much closer then the other one, so I am happy with it. Although one day I may black out the knob:)
