E30 Resurrection Intro
  • vertbmw
    • Nov 2013
    • 9
    Make sure to change timing belt that car has been sitting for a while
    • estoguy
      • May 2013
      • 1087
      Keep at it! Great to see you bringing it back!
      Estoguy
      • Shangsta
        • 1485
        Good work so far. I agree with vertbmw. If the motor in it is good then make sure you do a timing belt asap
        :shock:
        • Jshbrwr
          • Sep 2015
          • 90
          Yeah I'm beginning to see the importance of the timing belt/water pump work...but honestly I just want to get it running. I received my spark plugs from PP and am now looking for a good article on replacing those. I'm sure its not too difficult, but I have a feeling it might get trickier when I'm actually doing it.
          Meanwhile, I'm looking for a good timing belt tutorial. Pelican parts has lots of tech articles and I wonder if you guys have had good luck with those?
          • Jshbrwr
            • Sep 2015
            • 90
            Hey, any ideas would be appreciated...see pix below
            Before:
            After:
            I now have to figure some way to seal up that nasty gap before I install the carpet. I have a similar issue on the other side of the trans tunnel. Anyone used FlexSeal?
            • dnguyen1963
              • Nov 2011
              • 2649
              Put JB weld or Bondo in the gap then spray some PlastiDip to cover it up. Way cheaper than FlexSeal.
              • Jshbrwr
                • Sep 2015
                • 90
                Excellent, thanks for the tip!
                • Stanley Rockafella
                  • Aug 2011
                  • 4062
                  If I were you I'd address the rust on the floor boards before putting carpet back in
                  • kway
                    • 1084
                    Buy a 110v harbor freight welder for $90 and stick some metal on there. It's not as difficult as you might think. The trans tunnel is something of a structural element of the car. Not the most stressed, or critical, but there is a degree of importance there.
                    '84 318i - Lapisblau/Schwarz (in cryosleep)
                    '06 330i - Titansilber/Schwarz
                    • Jshbrwr
                      • Sep 2015
                      • 90
                      If you were me, how would you address that 😀???
                      Isn't there some kind of spray sealant or something made for that? Or is that just called Rustoleum...?
                      Sorry I sound like I'm clueless.
                      Also, I noticed there's a "Projects" forum. Should this move over there?
                        • 34839
                        done ;)
                        cool story!
                        • Jshbrwr
                          • Sep 2015
                          • 90
                          Thanks nando!
                            • Aug 2011
                            • 4062
                            If you were me, how would you address that ��???
                            The shop that's doing the body work on my e30 cut the (surface) rust "square" portion behind the front wheel wells and welded in new sections of metal.
                            It currently looks surface rust in your pic but it's just going to progress regardless of the type of spray sealant you use.
                            good luck
                            • Jshbrwr
                              • Sep 2015
                              • 90
                              That sounds dismal
                                • 34839
                                POR-15 if it's just surface rust. if it's more than that, you'll have some work to do..
