Agree there's a very slight rake rear-wise. Could be the garage floor though. My cars lean towards the center and rear of the garage when parked..
Project Lessmeister: 91 318iS Restomod w/ MTech2 and modern drivetrain
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
e30m3s54turbo: I save my money for tuner parts. -
The car is raked moderately towards the front, the lower late model rear arches create an illusion....
The tires aren't oversized, they just aren't hellaflush stretched. Most people seem to go with 205's on 16's because they are cheap and plentiful. The tires on here are literally the exact same diameter as the stock tires. There isn't a more perfectly +2 wheel/tire combo to be had in that respect.
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
195/65-14 5.0in 12.0in 24.0in 75.3in 841 0.0%
225/45-16 4.0in 12.0in 24.0in 75.3in 841 -0.0%Tenured Automotive Service Professional - Avid BMW Enthusiast
https://mtechniqueabs.com/Comment
I agree with George.
I don't think it is just the arches. You could get away with a small spacer in the rear and dropping the front a bit more and it would look much better.Are Three Vee
Dad Spec
I have to agree on this. Most of the hobby E30's run undersized tires if you compare to factory specs. For example the popular tire size 215/45/16 is half an inch smaller than the stock size 205/50/15. 205/45/16 is almost an inch smaller.
A spacer in the rear would most likely require rolling the fenders. I'm not sure about the facelift but in pre-facelift I know it would.Last edited by Skarpa; 03-03-2016, 06:40 AM.Comment
I'm glad to see you agree with George, fortunately I have the benefit of the car here in my garage and I can see quite plainly that it is raked forward, not rearward. I haven't bothered to take a measuring tape to the rockers but I certainly could....
A spacer in the rear would result in tire/fender contact. It is already very close, and this is a functional wheel/tire combo, not a hellaflush stance queen.
The front will likely drop itself another quarter inch or so as everything wears in. Anyone that has installed new OE upper strut bearings and has bothered to compare the compressed 25 year old originals next to the new ones knows there is easily 1/2-3/4" of "lift" given to the ride height there alone. I installed E90 drop hats at the same time to largely nullify this affect.
I don't mind people pointing things out that could be done better, but when you haven't bothered to read through the thread and you're offering an uninformed opinion (that's what it is) Its kind of annoying.
i have been over to jordan's to drool on this car a couple times now. for me, i would say the stance is perfect. there is no ghey fender rolling. measuring at the rocker panel, i would say it sits about 1/2" or less higher at the rear. for me, this car has the perfect drop. it does indeed have a lot of tire under it, but its gonna need it to hook up. i wouldn't change anything. i say its perfect the way it is. you might need to see it in person to understand.
i really don't know how anyone could make a judgement like this from a facing quarter view photo anyway. maybe we should just chalk it up to the keystone effect of the photograph.Last edited by flyboyx; 03-03-2016, 06:47 AM.sigpic
Gigitty Gigitty!!!!
12 135i M sport cabrio grey/blackComment
Are you really that upset over a little advice?
I never said it wasn't raked forward. I have been following the thread since day one. I was simply agreeing with George by saying the fitment isn't quite there, and offering a solution. Sure you may not be able to space the rears, but the front would look a lot better a bit lower.
But then again you have always been quick to dismiss any sort of constructive criticism or advice.Are Three Vee
Dad Spec
I'm not upset, much less "that upset" and I did not dismiss your criticism/advice, dismissal would have been telling you to shut up, ignoring you, or the like. I didn't do that. I kindly explained what components are on the car in an attempt to convey to you why it sits where it does, and that it would naturally lower itself as the new parts wear in.
I get that you would like to see the car lower. You obviously like your car low. You're tucking tire up front and poking wheel past the fenders. I've had cars this low, and its not practical for a normal person to drive a car at that ride height.
I'd invite you to purchase the vehicle and to adjust the suspension and ride height to your specific taste.
In the meanwhile the car will be setup in a manner most would consider a tasteful lowering, which is aesthetically pleasing while maintaining a reasonable ease of operation. While I'll likely have the car awhile this car is ultimately being built for resale at the end of the day and I need to keep the "everyman" in mind in that pursuit.
I don't feel like it is a stretch to assume most buyers looking at spending this kind of money on a restored E30 aren't going to want it so low its difficult to drive.Tenured Automotive Service Professional - Avid BMW Enthusiast
Jordan, BMW could not have built a better car......... turn a deaf ear to critics!FEEDBACK:
http://www.r3vlimited.com/board/showthread.php?t=316212
BMWCCA #398608
IG @yagayo38
"The Best E30's were built with two camshafts four cylinders and sixteen valves!".Comment
Very well said Sir. Jordan for President. [emoji2] [emoji5] [emoji2] [emoji5] [emoji2] [emoji13]I'm not upset, much less "that upset" and I did not dismiss your criticism/advice, dismissal would have been telling you to shut up, ignoring you, or the like. I didn't do that. I kindly explained what components are on the car in an attempt to convey to you why it sits where it does, and that it would naturally lower itself as the new parts wear in.
Sent from my SM-N920V using TapatalkComment
I really like the drop... and Jordon is right, new mounts will lift the car. I just experienced this first hand on my vert. Lifted so much it looks like a gasser now. Immediately ordered drop hats.
I like the stance and as you said, a great, visually pleasing, yet functional amount of low. Not that you need my approval, or anyone else's.
But in the interest of "constructive criticism." You do come off as curt sometimes in your responses. Just a heads up... again, you don't know most of us from Adam though, so you do you boo boo."A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
91 318is Turbo Sold
87 325 Daily driver Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
92 325ic Sold & Re-purchased
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i SoldComment
