M52/Zf Alpine White 1986 E30
  • JeLani
    • Aug 2015
    • 1552
    #46
    Je'Lani's 1986 2.7i - progress thread
    Got the 'i' injectors thanks to modernist !
    April 2016 edit : my car still had the red eta injectors , not very good , it ran horribly and misfired frequently , i have a 525 ecu and of course stroker, 17lbHr m50 injectors are also good.
    More updates next week
    1986 LTW M52 (First project 2015- )
    1998 e36 328ic/5 -
    Roundie alpina pig cheek’d (1969)
    1967 2002 parts car
    1994 318iS junked.
    • 2mAn
      Señior Mod
      • 20860
      #47
      Why are you changing the headgasket?
      Simon
      Current Cars:
      -1966 Lotus Elan
      -1986 German Car
      -2006 Volkswagen Jetta TDI
      Make R3V Great Again -2020
      • JeLani
        • Aug 2015
        • 1552
        #48
        im unsure of its condition blown gasket + brown muddy coolant , couldn't take the risk.
        jan 2016 : The head was pulled because of the symptoms of a blown head gasket.
        1998 e36 328ic/5 -
        1967 2002 parts car
        1994 318iS junked.
        • JeLani
          • Aug 2015
          • 1552
          #49
          Trunk's now rust free, didn't take any pics before but it was ugly
          1998 e36 328ic/5 -
          1967 2002 parts car
          1994 318iS junked.
          • modernist
            • Apr 2014
            • 283
            #50
            Looking good! :)
            1986 327i
            transaction feedback
            DIY thing
            meh
            • JeLani
              • Aug 2015
              • 1552
              #51
              thanks modernist!. to anyone else: I'm still getting to the bottom of the electrical problem, it may be the simplest thing causing it. My goals for next month are replacing battery terminal cable, putting in an i cluster ( current cluster may be causing issues ) . And as soon as I get my costco battery exchanged i will check my fuses for excessive battery draw.
              1998 e36 328ic/5 -
              1967 2002 parts car
              1994 318iS junked.
              • JeLani
                • Aug 2015
                • 1552
                #52
                Found a pair of 17x8 style 5's near a dumpster lol the tires are sh^t. Just need two more, there's alot of e38's at the junkyard. But i found 3 of em for $265 , so a full set of rc090 plus a spare basically for $265. Good deal...
                Cleaned them up a bit
                1998 e36 328ic/5 -
                1967 2002 parts car
                1994 318iS junked.
                • BECKSTER
                  • Jun 2015
                  • 667
                  #53
                  I wish I could find style 5's at my local dumpster .
                  1990 Alpine 325is
                  1992 Schwarz 325ic (sold)
                  • JeLani
                    • Aug 2015
                    • 1552
                    #54
                    Update : injectors installed, runs beautifully. Next : 325i 7k cluster.
                    1998 e36 328ic/5 -
                    1967 2002 parts car
                    1994 318iS junked.
                    • JeLani
                      • Aug 2015
                      • 1552
                      #55
                      So could someone help me? My oil light is flickering while it is overheating. What is this?
                      this was my bleed screw never being cracked and me trying to drive it everywhere. do this after removing / draining radiator .
                      1998 e36 328ic/5 -
                      1967 2002 parts car
                      1994 318iS junked.
                      • ManSalad
                        • Jan 2014
                        • 418
                        #56
                        What part of San Diego are you in? Would be down to help out a fellow San Dieganite!
                        Instagram: @derkm
                        • JeLani
                          • Aug 2015
                          • 1552
                          #57
                          Eastlake! Sorry i barely saw this!
                          1998 e36 328ic/5 -
                          1967 2002 parts car
                          1994 318iS junked.
                          • JeLani
                            • Aug 2015
                            • 1552
                            #58
                            Progress and notes of this month: school's been beating my arse and so has work. I've been gathering parts :
                            Oil pan gasket , oil filter , and finally the " I " vdo cluster bought from Constantine.
                            Others: Sourcing out my leaks and concluded it is the oil pan ( unless im wrong ) because the gasket is trashed and yeah..
                            - need to bleed air out of cooling system .
                            - install cluster and parts mentioned above
                            - hopefully drive the f*ck out of it again
                            1998 e36 328ic/5 -
                            1967 2002 parts car
                            1994 318iS junked.
                            • JeLani
                              • Aug 2015
                              • 1552
                              #59
                              1998 e36 328ic/5 -
                              1967 2002 parts car
                              1994 318iS junked.
                              • JeLani
                                • Aug 2015
                                • 1552
                                #60
                                7k now :)
                                1998 e36 328ic/5 -
                                1967 2002 parts car
                                1994 318iS junked.
