M52/Zf Alpine White 1986 E30
  • JeLani
    • Aug 2015
    • 1552
    #76
    Got the manifold off, and the greyish peeling material is the glue, obviously it couldnt withstand the heat given and is very brittle
    1986 LTW M52 (First project 2015- )
    1998 e36 328ic/5 -
    Roundie alpina pig cheek’d (1969)
    1967 2002 parts car
    1994 318iS junked.
    • JeLani
      • Aug 2015
      • 1552
      #77
      And there.. Sits thy 885 head. Getting this far relieves me.
      1998 e36 328ic/5 -
      1967 2002 parts car
      1994 318iS junked.
      • JeLani
        • Aug 2015
        • 1552
        #78
        Je'Lani's '86 2.7 Stroker re-fresh progress
        She cleans up good ! Before Degreasing
        - After .
        1998 e36 328ic/5 -
        1967 2002 parts car
        1994 318iS junked.
        • JeLani
          • Aug 2015
          • 1552
          #79
          Head comes off this thursday
          1998 e36 328ic/5 -
          1967 2002 parts car
          1994 318iS junked.
          • TimeMachinE30
            • Jun 2014
            • 3749
            #80
            Originally posted by JeLani
            Despite stated above, the head will be off tomorrow lmao. Work really gets in the way. But the belt is off (finally) . After going back and fourth realizing that the harmonic balancer had nothing to line up with, referring to the e30source timing belt tutorial, but then i remember , the block and head are totally different! 😂 , so only the crank and head timing marks really matter ( if that makes sense) .
            All nonsense aside , what is a recommended machine shop in san diego area?
            Not close at all to bimmer heads?
            ACS S3 Build / Dinan 5 E34
            • JeLani
              • Aug 2015
              • 1552
              #81
              I live in chula vista , wheres bimmerheads?
              1998 e36 328ic/5 -
              1967 2002 parts car
              1994 318iS junked.
              • JeLani
                • Aug 2015
                • 1552
                #82
                Successfully pulled the head. Such a mess .. Looking to get machined now.
                1998 e36 328ic/5 -
                1967 2002 parts car
                1994 318iS junked.
                • 2mAn
                  Señior Mod
                  • 21062
                  #83
                  up here in LA
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • JeLani
                    • Aug 2015
                    • 1552
                    #84
                    Dropped off the head at the shop for a Valve job , resurface , and pressure test
                    1998 e36 328ic/5 -
                    1967 2002 parts car
                    1994 318iS junked.
                    • JeLani
                      • Aug 2015
                      • 1552
                      #85
                      Its been about a week but i got my head back and its crack free , haven't had any time in the garage because of work.
                      What needs to happen as of today :
                      - block drain , there are rust flakes in there for whatever reason.
                      - Head goes back on
                      - Camshaft seal
                      - Oil Pan gasket
                      - Replace some hoses
                      -Thermostat (figured out that caused cooling problems.I'm positive)
                      - I have a new TB to put on
                      - Cluster batteries, only the right half lights up when the lights are on.
                      however , the head after machining. I'm pleased.
                      I like water
                      1998 e36 328ic/5 -
                      1967 2002 parts car
                      1994 318iS junked.
                      • JeLani
                        • Aug 2015
                        • 1552
                        #86
                        Also the timing cover
                        - sanded , 200 and 100 grit , then used high heat rattle can . I think i did fine for a first
                        With this , i didnt want the same dirty bolts to be on this, especially after the time i put into painting it, so they're sitting in some cleaner .
                        Sorry for the shit 6s photos
                        I like water
                        1998 e36 328ic/5 -
                        1967 2002 parts car
                        1994 318iS junked.
                        • JeLani
                          • Aug 2015
                          • 1552
                          #87
                          So further plans i've been looking at since i wont have to be worrying about the motor bugging out on me any time soon, i realized both front spring perches are shot to hell so i'm looking at some suspension kits.
                          - brake pads and rotors
                          I also am looking for a second pair of style 5 RC090's if anyone on here has any ( im psyched i even found a pair near a dumpster) . Makes me happy it'll be running well in a matter of time though. *EDIT : found some plus a spare :)
                          Sent from my payphone using Tapatalk
                          1998 e36 328ic/5 -
                          1967 2002 parts car
                          1994 318iS junked.
                          • JeLani
                            • Aug 2015
                            • 1552
                            #88
                            Test fit of the newer style cam gear i bought from constantine. Test fit because i still need a camshaft seal and o-ring.
                            Was scared at first because i couldnt get it on, but found out this comes off
                            Going to order the rest of the parts i need tonight :) highly considering running blue top injectors but we'll see how it runs first.
                            1998 e36 328ic/5 -
                            1967 2002 parts car
                            1994 318iS junked.
                            • JeLani
                              • Aug 2015
                              • 1552
                              #89
                              Pulled the trigger on ordering
                              •Exhaust manifold heatshield gaskets
                              • camshaft seal and o-ring
                              •thermostat
                              • thermostat to throttle hose
                              •headbolt washers * ( these weren't there when i pulled the head) they were quite the buck for some washers.
                              • Catalyzer - manifold flange gaskets .
                              Also picked a late valance up for a great price today. \(^o^)/
                              1998 e36 328ic/5 -
                              1967 2002 parts car
                              1994 318iS junked.
                              • JeLani
                                • Aug 2015
                                • 1552
                                #90
                                Need free time and just a few hours , i just feel good right now.
                                1998 e36 328ic/5 -
                                1967 2002 parts car
                                1994 318iS junked.
