T-Erz remote mount turbo e30 revival thread
  • grinchxvx
    • Dec 2015
    • 295
    #76
    M52 head in all its glory[emoji41]
    • grinchxvx
      • Dec 2015
      • 295
      #77
      Got the block surface all cleaned up:
      Started out with a brown scotch bright roloc at low speeds and then moved to a blue Norton rapid strip disc at low speeds since it's a little softer. Also tried a razor and scraper but it wasn't working for me so that's what I busted out the air tools. There is still a little bit of staining but I can't catch my nail on it or feel it so I think it will be fine for my CES head gaske combo.
      Also got my timing cover back on along with the passenger motor mount arm and buttoned everything up the most I could until the head gasket shows up this week.
      • grinchxvx
        • Dec 2015
        • 295
        #78
        BW s360 is here along with me finally getting my salad shooters on. It's a good look until I get flares and wide wheels
        • grinchxvx
          • Dec 2015
          • 295
          #79
          Haven't updated In a while since I made a thread on BFC and I get more answers in that forum but anyway here it is. Motor is completely together now and the only parts I need to finish for my m52 turbo swap is a BOV and exhaust. The motor is still on a stand at my job and I'll be putting it in after I move into my new house that has a garage [emoji41]
          Also my m20 had been driving with a rod knock and it finally let loose last week so the car is out of commission until the m52 goes in. I'm assuming the rod bearing on cylinder 6 didn't have anything left in it and just took the rod and maybe piston with it. I found the rod in the road after it shot through my oil pan lmao
          • Northern
            I like cupcakes & sh!tboxes
            • 5247
            #80
            Looking good!
            Originally posted by priapism
            Originally posted by shameson
            • grinchxvx
              • Dec 2015
              • 295
              #81
              Been a hot minute since I updated here since I've been mostly using BFC, car is basically done and I'm just waiting on the exhaust for it to be drivable
              • grinchxvx
                • Dec 2015
                • 295
                #82
                She's done! Was driving the car for a month and I cracked the pan through my red 46 pan so I'm now Just finishing up new pan, HIK skid plate, and motor mounts since the cheap UHMW ones I bought I can't get to tighten
                • grinchxvx
                  • Dec 2015
                  • 295
                  #83
                  • efficient
                    • Feb 2012
                    • 3312
                    #84
                    Sick build
                    • grinchxvx
                      • Dec 2015
                      • 295
                      #85
                      Long overdue update, I'll let the pictures do the talking https://vimeo.com/192848502https://vimeo.com/192848644
                      • kronus
                        • Apr 2008
                        • 13032
                        #86
                        maybe you should raise your car a little.
                        cars beep boop
                        • grinchxvx
                          • Dec 2015
                          • 295
                          #87
                          I agree. I Already went back to stock top hats and that helped a lot but I can't raise it anymore until I get my coilvers on this winter
                          • grinchxvx
                            • Dec 2015
                            • 295
                            #88
                            Got the lift in my shop. Winter revamp has officially begun.
                            • ak-
                              • 12422
                              #89
                              lol did you break the hik skid plate?
                              More updates!
                              1991 325iS turbo
                              • Northern
                                • 5247
                                #90
                                fuck yeah
