Project Armo "330i" M-tech 1
  • Skarpa
    • Jan 2013
    • 495
    #271
    Work on the exhaust continues. The exhaust piping has pretty much found it's shape. Of course some details such as brackets and sensor bungs are still missing.
    I will after all make a little space in the firewall to get a flex piece in the rearmost headers. My hands are a bit tied with the locations because I want to place the O2 sensors in the headers rather than the exhaust pipe to keep the exhaust easily detachable. I also wanted to place the V-bands in the downpipe area where they are less likely to snag anything. I haven't quite got the hang of welding upside down with the flux cored wire. It's more or less spattery and runny. When welding in normal position I'm happy with the results.
    When I had the front end of the exhaust in shape it was time to move on to the catback section. I had to make a small lobster cut in front of the pipe connections to point them down and avoid hitting the gas tank and its heat shield. Likewise I had to make a similar cut in front of the rear muffler to have it horizontal. It took less modifying than I thought according to my first mock up. I had cut off the exhaust tips to have the rear muffler in correct position.
    The pipes could be a little closer to rear subframe. If it seems to be a problem, Ill make further modifications. The exhaust tips need to be extended and tilted sideways to line them up with the rear apron.
    I'm not the biggest fan of the slanted exaust tips but I decided I didn't want to modify the plastic apron. When the exhaust tips were tacked in place I started eyeing the supports for the rear muffler. The original brackets in the rear muffler didn't work so I cut them off. E36 exhaust mounts will work when placed according to the cutouts in the exhaust heat shield. Although I had to make a bit more space on the right side.
    That's where I got so far. Next time I need to bring some stainless flat steel to make the brackets in the muffler.
    E30 Armo "330i"
    • Skarpa
      • Jan 2013
      • 495
      #272
      Today I updated the gear diagram to six speed version. I was pleasantly surprised when I found an oval 6-speed emblem with the older style M-stripes. I think It's been used in E34 and E31.
      E30 Armo "330i"
      • Skarpa
        • Jan 2013
        • 495
        #273
        I decided to leave making the brackets for the muffler until I have the exhaust fully welded in case I need to react to distortions. Instead, I took on the shifter linkage. With the GS6-37BZ transmission and E9X shifter support the shifter would be positioned about 30 mm too far back and 10 to 15 mm to one side in E30 body. I cut up the shifter support to correct the position.
        I don't have equipment for welding aluminium so I had to come up with a way to mock up stuff and keep them in position when I take them for a welder. I drilled a couple of small holes and screwed the parts to a piece of sheet metal. I'll tell the welder to make triangle supports to the joint to make it stronger and neater.
        The actuation rod needed respective changes.
        I didn't just weld the tubes side by side. First I cut off a bit from one of them to reduce the offset but I should have cut a bit more. As you can see the shifter didn't end up perfectly centered. I got it corrected with a bit of bending for the rod, though.
        E30 Armo "330i"
        • Staszek
          • 2533
          #274
          Where did you get that? I need one for my S54.
          • Kershaw
            • 11822
            #275
            Garagistic is your trusted source for high-quality BMW performance parts, specializing in E30, E36, E46, and more. Discover custom-engineered components, from suspension upgrades to drivetrain solutions, designed to enhance your BMW's performance. Shop now for fast shipping, expert support, and unparalleled quality.
            You should replace the carrier shifter bushing. I used a 98 Ford Explorer front end link bushing, but use whatever. Even brand new, oem sucks. It's such a massive improvement over stock.
            AWD > RWD
            • Skarpa
              • Jan 2013
              • 495
              #276
              BMW no longer sells badges separately, just full knobs. I got mine here. It says genuine but it didn't come in bmw packaking so I'm not sure about that. The quality seems OEM, though.
              http://m.ebay.co.uk/itm/GENUINE-BMW-...%257Ciid%253A3
              Originally posted by Kershaw
              https://store.garagistic.com/bmw-per...hifter-bushing
              Thanks for the tip. It feels pretty squishy indeed. I'm tempted to try out a polyurethane bushing from roller skates if I luck out with the dimensions.
              E30 Armo "330i"
              • Skarpa
                • Jan 2013
                • 495
                #277
                It turned out just fine :up:
                E30 Armo "330i"
                • Staszek
                  • 2533
                  #278
                  Is it round or oval? Looks round in the link, but oval on your knob.
                  • Skarpa
                    • Jan 2013
                    • 495
                    #279
                    That's oval.
                    "Additional Info: Oval shape emblem, width - 30mm / height - 33mm"
                    I'm not sure if they ever made a bmw with round shifter and six gears.
                    E30 Armo "330i"
                    • BUDNUNTA
                      • Apr 2005
                      • 996
                      #280
                      What adhesive have you been using when you bond and rivit the panels on?
                      We're out there in here.
                      • Skarpa
                        • Jan 2013
                        • 495
                        #281
                        Originally posted by budnunta
                        what adhesive have you been using when you bond and rivit the panels on?
                        3M 08115. You also need the spreading gun 08571
                        E30 Armo "330i"
                        • Skarpa
                          • Jan 2013
                          • 495
                          #282
                          Now I've moved all of my project pics to kuvat.fi. While doing that I reorganized the pics into categories so it's easier for me and maybe also other people to find what they are looking for. It was a tad impractical to have all the 1500+ pics in a single folder. While doing that I managed to break the last functioning hotlinks in this topic so I still need to repair those when I feel energetic.
                          E30 Armo "330i"
                          • Skarpa
                            • Jan 2013
                            • 495
                            #283
                            Clearance made for the header flex joint.
                            The patch is curved to give the most space even though it doesn't really show in any of the pics.
                            E30 Armo "330i"
                            • Skarpa
                              • Jan 2013
                              • 495
                              #284
                              I welded the rest of the fixings for the fuel lines and the heat shield to the bottom of the car and assembled the E36 power steering rack with new Lemförder tie rods
                              E30 Armo "330i"
                              • NufnSus
                                • Apr 2012
                                • 119
                                #285
                                Edit: oo, kuvat.fi or the forum software seems to find the linked pics even when they are moved to a different folder. Awesome!
                                Thanks for going through that effort, would've been a shame to lose all that well-documented fab work...
                                Sent from my Moto G (5) Plus using Tapatalk
