I'm in to watch the show!
777- Kamotors E23 Turbo Build + E38 content and a hint of e32
Almost done, got intake back on, replaced majority or rubber with silicone hose. I discovered that the oil return hose was split and leaking, not having the time to order a new one I decided to reburbish what I had. I have loads of -an oil hose and -11 was the perfect fit
perfect tight fit.
Sent from my SM-N920T using Tapatalk
7speedshop.comComment
Sooo very tired....new thermostat in the e23, runs very cool now. However it breaks up and back fires around 5500rpms.
Pulled valve cover off the e38 took like 3hrs just to strip the nasty paint off it and then the finish of the cast metal was way rougher than I thought it'd be so I just crinkle painted it.
Got the ecu back, new spark plugs, just need to finish one more valve cover and I can drive it!
I did find that the knock sensor was fine and it was just the insulation that came off two wires giving the check engine light. 2 pieces of tape and the car was better than ever!
Subbed. All of the coolest looking 7's that were made.
Is the E23 an auto or 5spd?IG: deniso_nsi Leave me feedback here
