777- Kamotors E23 Turbo Build + E38 content and a hint of e32
  • dude8383
    • Jan 2005
    • 10387
    #31
    Nice. That'll be a ton of fun with a manual gearbox for sure.
    • delamaize
      • Nov 2013
      • 1465
      #32
      Dat 7......
      Dumpster Fire Pilot
      • kamotors
        • Nov 2007
        • 7102
        #33
        I test fit the e30s new wheels on the e23. 285 18x9.5 rear et20 and 245f18x8.5 et20 and they fit perfectly lol. The e23 has huge reae tubs, a 305 would easily fit. Now I know what I can get away with.
        Sent from my SM-N920T using Tapatalk
        7speedshop.com
        • totheredline
          • Jun 2013
          • 762
          #34
          I want an e23 now.
          Sent from my XT1585 using Tapatalk
          = Heidi 1988 325 -> 335i. 7200rpm built M30
          • kamotors
            • Nov 2007
            • 7102
            #35
            The e23's cap and rotor were nasty! The car stutters a bit at WOT around 5500rpms and this only helped a little. Going to replace coil, clean AFM and TPS next. Made a quick video of the replacement. https://www.youtube.com/watch?v=KCfraeTNf10
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              #36
              Letting my brother borrow the 285's as they aren't what I was hoping for performance wise.
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                #37
                The e32 developed a tick and missfire. The missfire definitely seemed ignition related but I feared the tick was something worse. Discover the prongs had broken off the Bosch plugs(actually common on these) and the plug was finger loose. What ever shop worked in it needs to learn how to tighten plugs, both rear plugs on each side were loose. Access is tight back there and I'm guessing the shop didn't have patience or tools to do it right. Well all fixed now with a set of NGK's. No more missfire, no more ticking (it was exhaust escaping the plug hole).
                7speedshop.com
                • kamotors
                  • Nov 2007
                  • 7102
                  #38
                  Kinda tempted to turbo an m60 and put it in the e23, but the amount of wiring needed scares me a lot worse than fabbing parts does.
                  7speedshop.com
                  • kamotors
                    • Nov 2007
                    • 7102
                    #39
                    Replaced fuel pump with my old e30 bosch 070 single fuel pump setup, and replaced ignition coil but car still stutters at 5k rpms. Only thing I haven't replaced is the plug wires and fuel filter so doing that next.
                    7speedshop.com
                    • SmallDave
                      • Jan 2015
                      • 100
                      #40
                      Glad you get to keep working on the car Kam! Hoping for peace for your family
                      • Kershaw
                        • 11822
                        #41
                        The MSD blaster 2 works as a replacement for the Bosch coil? I contacted MSD and they said they had nothing that would work for an e30.
                        AWD > RWD
                        • kamotors
                          • Nov 2007
                          • 7102
                          #42
                          I ran the msd on my e30 and several customer builds without issue. Works in both m30 and m20s.
                          7speedshop.com
                          • kamotors
                            • Nov 2007
                            • 7102
                            #43
                            First auto-x this weekend, time to see which seven is "better"..
                            E32 740i mods
                            -H&R sport w/ KYB
                            3.15 LSD
                            245 front tires
                            285 rear tires
                            muffler delete/xpipe
                            Jim conforti tune
                            weight reduction
                            E38 740i m-sport mods
                            B&G springs w/ Bilstien
                            3.15 Open rear diff
                            m sport sway bars
                            245 front tires
                            285 rear tires
                            muffler delete
                            DUDMD ECU tune
                            7speedshop.com
                            • kamotors
                              • Nov 2007
                              • 7102
                              #44
                              Some euro grills I found for cheap finally showed up. Too bad i don't have headlights to fit it.
                              7speedshop.com
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                #45
                                E32 740i mods
                                -H&R sport w/ KYB
                                3.15 LSD
                                245 front tires
                                285 rear tires
                                Jim conforti tune
                                weight reduction
                                3.15 Open rear diff
                                m sport sway bars
                                245 front tires
                                285 rear tires
                                muffler delete
                                DUDMD ECU tune
                                Battle of the land yachts haha
                                1991 318i 4dr slick top
                                Mtech 2 turbo restoration
