325ix Touring Clubrally racer project
  • kronus
    • Apr 2008
    • 13032
    Most e30s don't have vented rear rotors, so that trick would not work super well.
    Nice progress! Why a touring base for rally?
    cars beep boop
    • Zdrenka
      • Feb 2016
      • 11
      Soooo, I'm still lost on the inner ball joints on the front control arms.
      The inner balljoint is a story of its own to. The bolt and nuts are just spinning in the joint. The taper must've been nocked loose when I tried to hammer outer joint or something. Has anyone any idea to what I should do next? Cut it between the joint and taper? I tried putting pressure on the joint with a jack - does nothing.
      What do I do? I can't cut the nut from the top because of the lack of space. Cutting it from below will still leave the taper part in there. Hmm...
      A nut chrusher maybe? It'll be a tight fit if so.
      • Zdrenka
        • Feb 2016
        • 11
        Ah! You're right. Guess the IX spec worked in my favor for once ;)
        So, first of all I just really like the Touring. I like estates in general. The fairly slanted rear window gives it a fairly sporty look I think.
        Second, I figured it would be fairly practical since, Rally'ing of any sorts always require to haul lots of stuff to the race location. I'll definitely be carrying a second set of wheels for starters. The penalty is not that great weightwise so I figured it would be better than hauling a trailer, which would also limit our speed on the highway from 130 to 90 kph.
        Third, there aren't a lot of decent e30's left on sale for cheap money. I wanted a M20b25 ideally and the IX spec just caught my eye. I though; well its a little more expensive to maintain but 4wd and rally go together pretty well right? :D
        Forth, my other hobby is cycling. More specifically, cyclocross, which require a bit of space when going to races and such. A car like this comes in handy when bringing along a couple of mates.
        Also, I seems like 325IX Touring is kind of a cool car. I've seen good examples on sale for 15-25k euro in germany! I paid 3!
        So unless I fuck it up completely it should still be a decent deal.
        • bradnic
          • Jul 2012
          • 3554
          great thread! SUB'D
          and terrific work so far. rear subframe restoration takes time! be sure to check all your brake and fuel lines for corrosion. It is very simple to bend out your own replacement lines if needed.
          HOWTOs:
          DB vert plastic bumpers
          OEM Keys
          MTech1 docs
          88 ix Lach/Card
          91 ic Calypso 3.1
          86 Cosmo 2.7
          OEM+ or bust!
          • Zdrenka
            • Feb 2016
            • 11
            Will do. Brake lines will need a good overhaul. I just ordered a set of open end brakeline wrenches. Hopefully they will do the job.
            • kronus
              • Apr 2008
              • 13032
              put a jack up under the ball to keep the taper planted in the subframe, then take the nut off the normal way.
              cars beep boop
              • bradnic
                • Jul 2012
                • 3554
                ^ this. done it that way 3-4 times.
                HOWTOs:
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • Zdrenka
                  • Feb 2016
                  • 11
                  I tried that. It's still spinning. :(
                  • bradnic
                    • Jul 2012
                    • 3554
                    Have you soaked the threads with a penetrating oil like PB Blaster? A little heat from a propane torch may help as well, but be careful with oil catching fire. You may have to use an impact driver
                    And you will still need the jack
                    HOWTOs:
                    OEM Keys
                    MTech1 docs
                    88 ix Lach/Card
                    91 ic Calypso 3.1
                    86 Cosmo 2.7
                    OEM+ or bust!
