325es noob build
  • BFT_Boyle
    • Jul 2016
    • 199
    #196
    New tires just in time for some winter driving!
    Rides soo much better with balanced tires. I'll be replacing my strut inserts in the next couple weeks. Looking forward to not having so much rocking and rolling going on.
    • BFT_Boyle
      • Jul 2016
      • 199
      #197
      Üro Parts, yay!!!
      • 2mAn
        Señior Mod
        • 21017
        #198
        you shouldve known better. Uro parts are garbage. Order your parts from Bluntech. Hes a forum sponsor and is known for his artwork. Win win
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • BFT_Boyle
          • Jul 2016
          • 199
          #199
          Yeah, that was an early purchase when I was still naive [emoji17] . Thanks for the recommendation, I'll check em out!
          I should say that my U-joints are pretty stiff. I'm going to replace them while I've got everything out. I can feel/hear a noticable knock from 1st-2nd. Probably didn't help the cheap parts.
          On that note, I'm going to try to attempt replacing the joints myself. I've got access to a fairly extensive machine shop and some coworkers who will trade their time for beer ;)
          • BFT_Boyle
            • Jul 2016
            • 199
            #200
            Went to the vintage road race today. God I love these cars.... Though the 510's we're killing it on the track. Another love of mine....
            Anyways, nothing much new to report other than I'm in process of rebuilding my driveshaft/U-joints. Knocked out one joint and got measurements for replacement. Need to talk to one of my machinist co-workers about fixturing the yolk so I can cut a retaining ring groove it. Shouldn't be too difficult.
            Sent from my XT1585 using Tapatalk
            • BFT_Boyle
              • Jul 2016
              • 199
              #201
              New joints are going in. I left the original stake marks visible so I could match the bearing depth on both sides. I plan on tack welding a washer in place to keep everything retained. I also ordered a replacement CSB. Went with Febi instead; no Üro parts.
              • BFT_Boyle
                • Jul 2016
                • 199
                #202
                Went to bleed my brakes today and nothing came out of the rear calipers.... Fronts bled just fine so what's the deal?? I also noticed that it almost looks like the rear line isn't even hooked up, it's like taped up. Why would someone do that? I haven't noticed a problem with braking, but maybe I've just been using my front brakes only?? E brake works but that is mechanical so yeah.
                • BFT_Boyle
                  • Jul 2016
                  • 199
                  #203
                  Finally putting the "new" Bilsteins on today :)
                  • 2mAn
                    Señior Mod
                    • 21017
                    #204
                    Did you ever figure out the brake situation?
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • BFT_Boyle
                      • Jul 2016
                      • 199
                      #205
                      One of my other goals today. After reading a few posts I'm thinking clogged brake line? I'll also be rebuilding all the calipers as soon as the kit comes in.
                      • BFT_Boyle
                        • Jul 2016
                        • 199
                        #206
                        Progress shots. Moving up to 40mm. I thought the ES came with these larger shocks already, but I guess I'm getting an upgrade.
                        • 2mAn
                          Señior Mod
                          • 21017
                          #207
                          Hmmm thats weird. The early 84-85 models had the smaller tube strut housings. I hope yours works, you might need different strut housings. Worst case you can re-order the correct smaller diameter and sell the larger ones, but I would want the bigger ones personally.
                          The fun things to go through when fixing an old car, are all the surprises you find when fixing the old crap
                          Good luck!
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          • BFT_Boyle
                            • Jul 2016
                            • 199
                            #208
                            It was close, but it fit like a glove. Here is my passenger side insert. 😂
                            • BFT_Boyle
                              • Jul 2016
                              • 199
                              #209
                              Success! The new shocks make a huge difference. I can't wait to do the rear sets. Also pleased with how smoothly everything went. Between breaks and fucking around, took about 4 hours.
                              • 2mAn
                                Señior Mod
                                • 21017
                                #210
                                Nice! The rear is stupid easy, you can do it while you drink your beer don't even need to take a break
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
