325es noob build
  • BFT_Boyle
    • Jul 2016
    • 199
    #91
    There is a early style e30 that follows me to work in the morning. I need to get mine finished up so we can be friends! :)
    Got my cluster installed yesterday, all seems to be working now except the SI lights are kind of tweaking out. Not sure whats up there, but tach works at least.
    Finally started installing some of the cooling lines, then I got to that one between the firewall and the head.... It was at that point I realized how bad it would suck if these hoses leaked (they are older but still pliable) so I ordered a kit from ECS. Also picked up a new clutch slave cylinder since I found mine to be leaking.
    Lastly, I wanted to check out my plugs to see how it's burning. A fair amount of soot, however I have not cleaned them since I first started running the engine, so they have seen some pretty crappy air/fuel mixtures. I'll have to clean them off and recheck. At least there is no oil. I mean there shouldn't be with good rings, and new stem seals. I never changed the valves guides, but they felt just fine.
    • BFT_Boyle
      • Jul 2016
      • 199
      #92
      Hey gang, so I don't know the shift pattern on these trannys. Don't have the top emblem on my shifter and never been in one. .... Left and up is reverse? Most of the knobs I see online show that, but a few are different.
      • Skarpa
        • Jan 2013
        • 495
        #93
        When in neutral, the stick rests between 3 and 4. Left up is 1 and left down is 2. Extreme left up is reverse. You need to pull the shifter a bit harder to left to access the reverse.
        E30 Armo "330i"
        • BFT_Boyle
          • Jul 2016
          • 199
          #94
          Thanks!
          That's does make sense now. I got the shift linkage installed and was trying to feel my way through the gears and could feel that far left had a stronger spring return.
          • iwantspeed
            • 3164
            #95
            nice work so far
            my first e30 was an 325e also
            yes the valve cover has a breather hose to the side of the intake boot
            another upgrade is to replace the plastic t fitting on the fuel lines with a brass one
            you need a brass 5/16 t fitting or a brass 8mm t fitting like this
            https://www.amazon.com/dp/B002ET2LLQ...X5Y6A106K18FJ&
            and a picture and link from my previous e30
            Project
            Parts for Sale
            Feedback
            YouTube Channel
            • iwantspeed
              • 3164
              #96
              i also recommend doing this little mod
              or replacing the cork gasket at the throttle body its common for it to leak
              Project
              Parts for Sale
              Feedback
              YouTube Channel
              • BFT_Boyle
                • Jul 2016
                • 199
                #97
                Originally posted by iwantspeed
                nice work so far
                Damn that thing is clean! I have seen the brass tee and I will likely do that. Noted on the TB gasket too. I'll have to read through your eta build. Looks like a good list to go off of.
                • iwantspeed
                  • 3164
                  #98
                  The build thread used to be on e30tech.com but the website is down.
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                  • BFT_Boyle
                    • Jul 2016
                    • 199
                    #99
                    Modeled up a shifter cap to 3D print out. Cause why not :)
                    • BFT_Boyle
                      • Jul 2016
                      • 199
                      #100
                      Found a better idea for a shifter cap. Nice OFE copper disk. I can stamp in the shift pattern then fill the embossment with engraving paint.
                      • BFT_Boyle
                        • Jul 2016
                        • 199
                        #101
                        Just chillin'
                        • BFT_Boyle
                          • Jul 2016
                          • 199
                          #102
                          Kind of off topic, but today marks 1 year since I f'd up my arm. Very fortunate to be able to turn a wrench today and still get "that stupid POS god damn nut onto the POS buried ass stud. God damn POS engineer" without too much difficulty ;)
                          On topic news is that my cooling hoses are coming this week 🤗 along with the clutch slave cylinder. Which means.... I might be able to take a test lap around the neighborhood!!!!
                          • BFT_Boyle
                            • Jul 2016
                            • 199
                            #103
                            Oh and after much thought. I've got my heart set on a M50 (non-VANOS)swap down the road. It just seems like the most logical next step after I learn how to drive with the M20 installed. Ill be keeping my eye out for a good deal on a donor, but for now this is just early early thinking.
                            • 2mAn
                              SeƱior Mod
                              • 21017
                              #104
                              Where in CA are you? This is a pretty legit build. I think almost every current E30 owner must've started with an eta. The non-Vanos M50 is ok, but might as well make the most of the work you've done on the bottom end, and get a 731 (323i) head. It will be quite a bit of a jump from where you are at and a lot less work than the 24v swap
                              Also, that doesnt look like a ES. ES has Sport seats, Mtech1 steering wheel, front and rear spoilers (you're missing the cowcatcher), but most importantly the Sport cars (the 'S' in 'ES' ) have a Limited Slip differential. There should be a tag on the diff labelled S2.93
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              Make R3V Great Again -2020
                              • BFT_Boyle
                                • Jul 2016
                                • 199
                                #105
                                I'm in Grass Valley. Bout an hour East of Sacramento. I'll have to check out that 731 swap then. If I'd have known how far I would be invested into this M20, I might of just did the engine swap in the first place. It has been a really good learning experience though.
                                As far as the "S" model, I was unsure in the beginning. Yeah the badge is there (albeit it's not in the right spot. Blamed that on whoever painted it). It does have the M-tech I steering wheel, and the diff tag confirms 2.93 LSD. Sticker in the door jamb also confirms "es".
                                I know Google will show me the light, but the 731 head... Larger porting while retaining compression with the eta pistons or what?
