RIP 318is, long live 325is that will actually be a 318is
Hey sorry I have run into some issues with my engine and have been working on that. I will pm you tomorrow.
Sorry for the lack of updates I have been busy trying to make it work. Car moved under its own power last weekend but was burning coolant which it wasn't doing when I pulled. Working on getting the head off to see what's wrong. Cylinders 1,3&4 all compression tested at 150psi. #2 is at 30psi. Should have a good idea of what went wrong tomorrow.(OO=[][]=OO)Comment
Any idea how much power the Frankenmotor M42 is making? Er, was making. Trying to be optimistic here. I'm trying to feel out options for building up the M42 that don't involve spending $9000.
I'm the guy at BMW CCA Houston with the red 318is BTW. Hopefully within the next few months I'll finally have the car out on course...1991 318is Brillantrot daily driver (slow restoration)Comment
Hey c0rbin9! I would be very happy if it was making 130hp at the wheel. Not sure it is though but I can dream Haha. A friend of mine said it feels a lot like what his e30 m3 felt like with the s14 engine in it, so I will take that as a good thing. You have seen how it does at the autox. If I make it to the next one(only 3 weeks away!) I will have Chris take you for a lap in it. You drove your ride out to the autox back in September. I say race it! Then as you make changes you can feel and understand the benefit or lack there of Haha. Just my 2 cents.
Took the head to the machine shop on Monday. They found it was .003 in. warped between cylinders 2 and 3 and my exhaust valves were leaking. They are doing a 3 angle valve job and decking the head. Should have it back by Thursday and hopefully running by the end of the weekend giving me a week to make sure it is ready to race.(OO=[][]=OO)Comment
Very cool to see someone giving the M42 a fighting chance! What was the reasoning behind the S52 cam tray's? Are they lighter?IG: deniso_nsi Leave me feedback here
FEEDBACK:
http://www.r3vlimited.com/board/showthread.php?t=316212
BMWCCA #398608
IG @yagayo38
"The Best E30's were built with two camshafts four cylinders and sixteen valves!".Comment
I imagine it's quite a bit more responsive than the stock unit with dual mass flywheel, too.Hey c0rbin9! I would be very happy if it was making 130hp at the wheel. Not sure it is though but I can dream Haha. A friend of mine said it feels a lot like what his e30 m3 felt like with the s14 engine in it, so I will take that as a good thing. You have seen how it does at the autox. If I make it to the next one(only 3 weeks away!) I will have Chris take you for a lap in it.
I'm sure I'll see you out there at some point, hopefully in the near future. Will be nice to have another 318is as a point of comparison!
As my car is my DD and the maintenance history was unknown when I bought it, I wanted to bring it up to a baseline of reliability before autocrossing it. That is mostly done, as I've worked like a slave on it every free weekend for the past 6 months - check out my build thread. :)
Are you out there Brodee? I'm free this weekend if you wanna check out the 318is.1991 318is Brillantrot daily driver (slow restoration)Comment
I know that the s/m52 are the same not sure on the others. I swapped them in for the smaller lifters. Swapping the lifters and valves(from 7mm to 6mm) took 2 or 2.5 lbs out of moving parts in the head. If you look at the pictures I posted earlier you can see the oil passage that was machined. As for making them shorter you cut off cylinders 5 and 6. I did it with a band saw.
Between the flywheel, the m44 crank and the head work I think it is much more responsive.Originally posted by c0rbin9I imagine it's quite a bit more responsive than the stock unit with dual mass flywheel, too.
Brodee is probably moving to his new house with a huge! shop this weekend haha. But Brodee has raced and driven my car. He could give you a lot better description of how my engine compares to other e30 engine options out there. But I am very please and glad I stuck with the m42!(OO=[][]=OO)Comment
Very cool. I've heard of people swapping over to a VW lifter that was lighter and fit right into the stock cam tray's as well.
We're still dragging our feet with a 2.1l M42 project car... everyone always doubts these motors!!IG: deniso_nsi Leave me feedback here
So I got the head on several weeks ago only to now have an issue with oil in cylinders 1,2 and 4 which I didn't have before. Got pretty frustrated and took a break from it. But this weekend I plan on investigating the issue. I am wondering if they put the wrong valve stem seals on. I still have good compression on all cylinders. Any thoughts on the issue would be greatly appreciated.
Thanks,
Ronan(OO=[][]=OO)Comment
