RIP 318is, long live 325is that will actually be a 318is
  • Dj Buttchug
    • Jun 2010
    • 7678
    way to bounce back op. m42 is plug and play into late 325i chassis.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Ronan
      • Aug 2014
      • 83
      Need too haha. Trying to finish out the autocross season. If I can get 2 more wins I will finish 1st for the year in my class.
      (OO=[][]=OO)
      • Ronan
        • Aug 2014
        • 83
        Made tons of progress tonight. Got the rear sway bar mounted and half of the tar out of the trunk haha. Why does everything have to take so long?! Sway bars are suspension technics with IE rear mounts.
        Next I will get the rear subframe in. Revshift bushing in it along with the rest of the car and a 4.10 lsd.
        (OO=[][]=OO)
        • Ronan
          • Aug 2014
          • 83
          Figured I would post a little about my engine. Always meant too but never did.
          So here it is my frankin motor. It is a m42 block with M44 internals.
          Then a m42 head. Valves reseated and new seals. 6mm valves.
          With s52 cam trays with 32mm lifters.
          Had to cut a new oil passage and fill the old one.
          With the 6mm valves instead of the 7mm and the 32mm lifter I saved about 2.5 lbs in moving parts in just the head.
          All bolted together.
          All that matched with the lightened m20 flywheel make for a pretty responsive motor. Lots of fun.
          (OO=[][]=OO)
          • varg
            Florida Turbo Man
            • May 2014
            • 3406
            How high are you revving it?
            IG @turbovarg
            '91 318is, M20 turbo
            • Ronan
              • Aug 2014
              • 83
              I have a turner chip which makes it a 7k reline.
              (OO=[][]=OO)
              • ajp340
                • Mar 2016
                • 62
                Originally posted by Ronan
                Sure do. Right now I am focusing on getting the new car running before I start parting but I will let you know when I do.
                Sent from my LG-K371 using Tapatalk
                Sweet, thanks a lot. It will go to a good home, check it out!
                • Ronan
                  • Aug 2014
                  • 83
                  Looks good. I will let you know just give me a week or 2 to get mine running
                  (OO=[][]=OO)
                  • c0rbin9
                    • Dec 2015
                    • 609
                    Noooo
                    1991 318is Brillantrot daily driver (slow restoration)
                    • Ronan
                      • Aug 2014
                      • 83
                      Rear subframe installed this morning. Hoping to get the engine in tomorrow.
                      (OO=[][]=OO)
                      • stonea
                        • 2892
                        Sub'd for M42 love. Although I don't own a 318i, I wouldn't mid one.
                        My Garage
                        Feedback
                        Instagram: Stone.Hopkins
                        • Ronan
                          • Aug 2014
                          • 83
                          Well the engine didn't make it in today. But thats ok it will give my friend time to fab up the bracket for the power steering pump and me time to modify the steering coupling for my zhp rack. Hopefully next weekend it will go in.
                          (OO=[][]=OO)
                          • Ronan
                            • Aug 2014
                            • 83
                            Ok I have a small update. With the help of a good friend from work we fixed my power steering pump mount.
                            Before
                            And after
                            All with a band saw, drill and grinder. Still need to modify my steering coupling but hopefully engine goes in on Saturday.
                            (OO=[][]=OO)
                            • Ronan
                              • Aug 2014
                              • 83
                              Engine is final in the car. Not running yet but in the car.
                              (OO=[][]=OO)
                              • ajp340
                                • Mar 2016
                                • 62
                                Hey man any update on headliner with sunroof?
