Dumb questions thread!
  • HerbE30
    • Nov 2015
    • 538
    This thread is for my questions. I really hate to clutter with multiple threads that already have similar content. I assumed the forum wouldn't hate me if I kept all of my 'dumb' questions in one place.
    Can I use MAF cleaner to clean the IVC?
    When converting to e46 hubs, what is everyone using to reduce acriment angle? I am planning on running BCs for the new year and wanted to make sure I wouldn't have any "Why did I use the 4x100 hubs?!?!" moments. I am perfectly content with the brake options available with the 4x100, so aside from that, what would be other advantages? I plan on using e30 offset CAB, but flipped so I don't have tons of caster. Am I correct?
    I also have a slight stumble, below 1.5k and above 5k. I will be cleaning MAF, adjusting valves, changing plugs, fuel filter, and coolant temp sensor? Any other leads will be looked into. The car was advertised with a JC chip, and with most CL adds, I assume it was a lie. Should I pull the 1.3 apart and check? Can this cause a stumble on 89 octane, as the JC required 93?
    P.S. I do use the search function, frequently. If I am asking, the importation I find may be lacking, or I am looking for more feedback.
    Stay tuned for the questions that shouldn't have been asked!
    20% Accurate
    Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
  • iwantspeed
    • 3164
    just use any regular carb spray for the icv
    no comment on the e46 question
    for the stumble
    first replace all the sources of a vaccum leak
    then replace the ignition system
    cap
    rotor
    plug wires
    spark plugs
    coil
    still stumbles try replacing for a crank positon sensor from the actual dealership it comes with a metal housing.
    Project
    Parts for Sale
    Feedback
    YouTube Channel
    • TobyB
      • 5266
      Why, any acriment angle reducer will work, of course-
      don't spend more for BMW reducer.
      I like it in cream form, myself....
      I had to Gargle it-
      Ackerman, you mean?
      The hubs themselves won't affect Ackerman, only track width, and thus, scrub radius.
      I never saw any reason to go to 5 lugs, but then, I am not a stretched poked wheel whore...
      t
      • HerbE30
        • Nov 2015
        • 538
        @iwantspeed - There were some fairly large cracks in the intake boot post MAF. So I am hoping that is my issue. Will be ordering one soon. Still planning on a small tune-up though. I also cleaned the MAF really well. I removed and cleaned the CPS, I thought it had abrasions on it, but it was just gunk.
        @TobyB - I realized my spelling was off when I tried to google answers... haha. Thanks!
        I guess people would value 5x120 over 4x100 when looking for large authentic wheels at the required sizes..
        I realize the 5 lug swap doesn't add akerman (;D). I was trying to say (but I was at the job):
        My plans are to run e46 control arms with e34 tie rod parts. So I would have the camber and a wider track.. But wouldn't I still be needing something to correct akerman? Or I guess I should say, reduce akerman for more skids?
        20% Accurate
        • Jaker
          • Oct 2013
          • 234
          Ackermann can certainly be impacted by a hub change. If the steering arms cast into the hubs are different at all, chances are the Ackermann will change as well.
          • Das Delfin
            • Sep 2014
            • 2293
            love how this was moved to members rides. Sick burn, admins
            • efficient
              • Feb 2012
              • 3312
              How long are coolant hoses supposed to last?
              I replaced all my coolant hoses in 2014. One of them just burst.
              • ELVA164
                • 4861
                10 years I think is the recommended replacement interval, so something was wrong with either the hose itself, the installation, or the cooling system.
                • Jb325is
                  • 2137
                  Well with e46 arms, the only angle that matters is, like, angle bruh.
                  - '88 m54 coupe
                  <3
