M60b40 powered Volvo 240
  • 2mAn
    SeƱior Mod
    • 21024
    #106
    Love this build
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • paynemw
      • Dec 2015
      • 439
      #107
      sweet hot rod!
      • FireFight
        • Mar 2012
        • 1367
        #108
        So I welded a jam nut on the back of the Volvos booster-pedal-connector(?) haha
        Next I primed and painted it
        I tossed it on and did a test for on the car
        The distance between where the booster meet the firewall and the end of the connector was 5"
        With it all the way threaded on it was the perfect length, but then the pedal wasn't able to travel properly, so I pulled it back out of the car and cut down the rod
        Now to toss it in the car
        Mounts to the pedal perfectly
        And all bolted up.
        Next I tried out the brake lines
        I hate how tight this bend has to be.
        So my plan is to get a couple grommets and run this brake line though the wheel well and pop it back in the bay towards to bottom, that would make the bend a lot less aggressive
        I also welded the bolts to the shift plate
        That got repainted black and is drying now.
        Next the clutch
        I was unable to find the proper heim joint so I decided to try a different route
        I had to drill out the ear off the pedal to fit the clevis pin
        This way should still allow rotational movement as to prevent binding. Next I need to pull the clutch pedal bracket and drill a hole to allow the mounting bolt to fit with the pedal being higher and then I can lengthen the pedal and figure out the prefect location for that ear
        WTB:m60b40 in PNW
        Zachary Ripley
        85 318i M50B25tu.
        92 525it 5 speed.
        80 244gl (m60 prepping).
        • 2mAn
          SeƱior Mod
          • 21024
          #109
          Cant you put a hard 90* on the master and hook up the brake line to that?
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • FireFight
            • Mar 2012
            • 1367
            #110
            All dried
            Mounted
            All done.
            All that is left for the shifter is to build a custom DSSR and I can't do that until the motor and trans are in
            WTB:m60b40 in PNW
            Zachary Ripley
            85 318i M50B25tu.
            92 525it 5 speed.
            • FireFight
              • Mar 2012
              • 1367
              #111
              I have been thinking about that, it would be perfect, just trying to find one that is the correct flare seems to be a pain, most I find are bubble flare on one side and pipe the other
              WTB:m60b40 in PNW
              Zachary Ripley
              85 318i M50B25tu.
              92 525it 5 speed.
              • delamaize
                • Nov 2013
                • 1464
                #112
                all 3 of my masters have 90 deg hard fittings right where it comes out of the master cylinders, and it seems to be fine....
                Dumpster Fire Pilot
                • FireFight
                  • Mar 2012
                  • 1367
                  #113
                  are they bubble flare on both sides?
                  where did you get them?
                  WTB:m60b40 in PNW
                  Zachary Ripley
                  85 318i M50B25tu.
                  92 525it 5 speed.
                  • Sh3rpak!ng
                    • Jan 2014
                    • 2667
                    #114
                    This is really cool. Subbed
                    Shadetree30
                    • delamaize
                      • Nov 2013
                      • 1464
                      #115
                      It was somewhere local here, I wanna say in Centralia. I'll see if I can figure it out....
                      Dumpster Fire Pilot
                      • FireFight
                        • Mar 2012
                        • 1367
                        #116
                        That would be great man, was it bubble flare on both the make and female side do you recall?
                        Thanks man!
                        WTB:m60b40 in PNW
                        Zachary Ripley
                        85 318i M50B25tu.
                        92 525it 5 speed.
                        • TimKninja
                          • 2131
                          #117
                          Love this thread man, thanks for posting all of the little details. .they help ALOT when people do their own swaps .
                          I love 240s , I miss mine all of the time even tho it was a monumental piece of crap. Want another one some day .
                          1985 325e M50TU(Sold)
                          1991 318is Slicktop (Sold)
                          1990 325is Brilliantrot S50/5 Lug Swapped.
                          1992 525i Manual shitbox Winter Beater
                          • Arn02
                            • Sep 2014
                            • 8
                            #118
                            Love it, doing something similar. Any updates? I'm curious how the engine sits with the motor mounts.
                            • dr_nec
                              • Aug 2020
                              • 1
                              #119
                              HEy I just stumbled across this thread and I'm in love. any news on it?
                              • e30austin
                                • 15382
                                #120
                                OP sold the project a couple years ago - i don't know where it ended up. hopefully, it went to someone who would finish it.
