Mr. Wolfe's M62 Swapped (VW Turquoise) MTech1 e30
  • paynemw
    • Dec 2015
    • 439
    #46
    Originally posted by Mr. Wolfe
    Thanks guys. They must not be working because I have had several people tell me to update them even though I can see them on my computer. I use Firefox, but there was an update for it that worked.
    Can anyone else see the pictures in the first post?
    Mr. Wolfe
    I checked out your build thread in both Chrome and Mozilla, neither let me view the pictures from photobucket. What's the chance of you transitioning to flickr across the board or fix the BB code
    • Mr. Wolfe
      • Jul 2014
      • 540
      #47
      I will at some point.
      Converted an e46 M3 shift knob over to my e30 shifter housing. Should go nicely with my M62 / 6MT conversion.
      IMG_3053 by Greg Wolfe, on Flickr
      IMG_3052 by Greg Wolfe, on Flickr
      IMG_3051 by Greg Wolfe, on Flickr
      Mr. Wolfe
      • bradnic
        • Jul 2012
        • 3554
        #48
        oh hell yes
        HOWTOs:
        DB vert plastic bumpers
        OEM Keys
        MTech1 docs
        88 ix Lach/Card
        91 ic Calypso 3.1
        86 Cosmo 2.7
        OEM+ or bust!
        • iXguido
          • Nov 2009
          • 731
          #49
          Converted an e46 M3 shift knob over to my e30 shifter housing...
          Nice! I did the same thing, just to get a cheap illuminated shift knob. my car was still a 5spd though :p
          • Mr. Wolfe
            • Jul 2014
            • 540
            #50
            Did you get yours to light up? If so, care to share?
            Mr. Wolfe
            • iXguido
              • Nov 2009
              • 731
              #51
              Mr. Wolfe
              I did have it light up. I tapped into the ashtray light wiring for power. I left the original plug on the shifter and found a plug to match and wired that into my car so the shift knob/boot was easily removed.
              • Mr. Wolfe
                • Jul 2014
                • 540
                #52
                Excellent, thank you.
                Mr. Wolfe
                • Mr. Wolfe
                  • Jul 2014
                  • 540
                  #53
                  New Euro valence just showed up.
                  IMG_3126 by Greg Wolfe, on Flickr
                  Mr. Wolfe
                  • bradnic
                    • Jul 2012
                    • 3554
                    #54
                    you may want to mod the ends of the narrow strip above the bumper to add slots on the bottom of each end for a body nut. your 771 USDM DB valance has them - 2 body nuts and screws on each end, top and bottom of the narrow bit. without that lower screw, the gap between the fender and the valance on that narrow strip is not as clean.
                    my repro 772 is missing those the lower sides of each end, where the fenders are screwed to the front valance. looks like your OEM 772 is missing them too. If you do decide to mod it so it works like the 771, make sure it's before the parts are all painted.
                    HOWTOs:
                    OEM Keys
                    MTech1 docs
                    88 ix Lach/Card
                    91 ic Calypso 3.1
                    86 Cosmo 2.7
                    OEM+ or bust!
                    • Mr. Wolfe
                      • Jul 2014
                      • 540
                      #55
                      Not sure exactly what you mean. Maybe it will make more sense when I go to mount it? I am going to install everything and then uninstall and prep for paint.
                      Mr. Wolfe
                      • bradnic
                        • Jul 2012
                        • 3554
                        #56
                        the spot right where the fender and the narrow strip above the bumper meet, just above and outboard of the marker light, below the low beam headlight. the fender wraps around the narrow strip. the fender is screwed to the narrow strip just outboard of that gap. on the US diving board valance there are 2 screws on each end. with the 772 valance only 1 screw is used, so the fender might not sit flush.
                        HOWTOs:
                        OEM Keys
                        MTech1 docs
                        88 ix Lach/Card
                        91 ic Calypso 3.1
                        86 Cosmo 2.7
                        OEM+ or bust!
                        • Mr. Wolfe
                          • Jul 2014
                          • 540
                          #57
                          Think I got it, thanks for the tip!
                          Mr. Wolfe
                          • Mr. Wolfe
                            • Jul 2014
                            • 540
                            #58
                            Got my wheels back from PC.
                            IMG_4080 by Greg Wolfe, on Flickr
                            IMG_4081 by Greg Wolfe, on Flickr
                            IMG_4082 by Greg Wolfe, on Flickr
                            IMG_4083 by Greg Wolfe, on Flickr
                            IMG_4084 by Greg Wolfe, on Flickr
                            IMG_4085 by Greg Wolfe, on Flickr
                            Mr. Wolfe
                            • 0-60Motorsports
                              • 65
                              #59
                              Wow they look stunning bud
                              • Mr. Wolfe
                                • Jul 2014
                                • 540
                                #60
                                Thanks Ejaz!
                                Mr. Wolfe
