E30 Coupe Complete Rebuild + M60B40 Conversion Thread
  • E30Bug
    • Sep 2016
    • 113
    #106
    Couldn't believe how good the main bearings looked.
    [ATTACH]120626[/ATTACH]
    [ATTACH]120627[/ATTACH]
    [ATTACH]120628[/ATTACH]
    5 broken bolts in the valley pan. This will be fun getting these out I'm sure.
    [ATTACH]120629[/ATTACH]
    [ATTACH]120630[/ATTACH]
    • E30Bug
      • Sep 2016
      • 113
      #107
      All ready to take to engine machinist.
Name:	E30 - 25.jpg
      And a few days later I picked it all back up again. All nice and shiney and new looking.
      Heads and block were skimmed, heads had the oil and exhaust galleries cleaned, valves re-seated and new valve seals put in, They were also pressure tested. The bores on the block were not honed as the engineer said they were in great condition. Oil galleries were all cleaned and new plugs put in.
Name:	E30 - 27.jpg
Name:	E30 - 28.jpg
Name:	E30 - 29.jpg
Name:	E30 - 31.jpg
      • E30Bug
        • Sep 2016
        • 113
        #108
        Cross hatching looked great.
        [ATTACH]120636[/ATTACH]
        Crank was crack tested and linished.
        [ATTACH]120637[/ATTACH]
        [ATTACH]120638[/ATTACH]
        I have most of the parts for the engine. Still waiting on a few bits but can make a start on putting it back together.
        [ATTACH]120639[/ATTACH]
        But firstly those dreaded snapped bolts to get out.
        [ATTACH]120640[/ATTACH]
        • E30Bug
          • Sep 2016
          • 113
          #109
          I got 4 of the 5 snapped bolts out without issue but that 5th one would not come out. I ended up snapping the easy out in the hole I'd drilled in the bolt. I've since heard that when the pros do it they will only use an easy-out once or twice then they use a new one. I am now taking this to my engineer mate who thinks he'll be able to set it up in a special machine with a special bit (not a drill press but something else?) and that will drill the hardened steel easy-out out as well as the bolt.
          [ATTACH]120641[/ATTACH]
          [ATTACH]120642[/ATTACH]
          [ATTACH]120643[/ATTACH]
          Decided to re-build all the lifters instead of buying new ones. Just couldn't warrant spending that sort of money on these when I can spend a few days and nights cleaning them all. Mind you, I think I'll be pretty sick of doing them by the time I've done all 32 of them.
          [ATTACH]120644[/ATTACH]
          • econti
            • May 2014
            • 1148
            #110
            Looking good and shiny
            • E30Bug
              • Sep 2016
              • 113
              #111
              Thanks man.
              Really looking forward to getting the engine built and engine bay painted so I can get it in and going.
              • wworm
                • Dec 2016
                • 1719
                #112
                oh man. I snapped an easy out off in a broken camshaft cap bolt on my yamaha once. 6 hours with a dremel later (and about 6 carving bits) and the bolt was finally out. Hopefully your machinist friend will be a little quicker lol
                1984 Delphin 318i 2 door
                • E30Bug
                  • Sep 2016
                  • 113
                  #113
                  Yeah its a pain isn't it. I'm taking the block in today so heres hoping we get it out without any trouble and I can get stuck into building this motor.
                  • E30Bug
                    • Sep 2016
                    • 113
                    #114
                    Well we got the broken bolt out today. Took a carbide drill bit to drill the easy-out out on his machine then we drilled the bolt out as close to thread size, then ran a tap through it to clear the rest of it out. So glad it came out without any more dramas.
                    • slum dog
                      • Jun 2017
                      • 110
                      #115
                      Updates?
                      • alistairolsen
                        • Jul 2017
                        • 191
                        #116
                        next time, put a nut over the broken end and weld it on, the heat and a larger hex head is normally enough to free them and saves damaging the head
                        • alkkamai
                          • May 2018
                          • 60
                          #117
                          Tremendous! This is to be driven exclusively on a clean, indoor track, right?
                          1987 325i cirrusblau "Beatrix" Let Me Tell You About My e30
                          1990 Golf etwas rot "Rosalie" SCRAP
                          1991 Golf etwas silber "Silvia"
                          Originally posted by jeffnhiscars
                          ...and you guys are way too into "mast lube & polishing" :)
                          • Staszek
                            • 2533
                            #118
                            Such an awesome project. Wish I had your painting skills!
                            • jeenyus
                              • Aug 2011
                              • 2064
                              #119
                              whoa, whoa, whoa! wtf is this?!
                              I don't know if i've ever seen an undercarriage look like that... ever. Great work!
                              I'm curious when you show the bearings, cams and crank and you say they look good, what are you looking for necessarily? Upon visual inspection, what are you looking for exactly? scoring? pitting? the obvious? or is there something more obvious i'd miss if i didn't know?
                              • dmjensen
                                • Jan 2011
                                • 805
                                #120
                                Updates please
