*!Build of the year candidate!* Strange PNW Build: E30+Volvo
Tomorrow should be a little better. I don't need to run around picking stuff up. It's going to be just fabrication stuff. Plus drilling out a bunch of spot welds. Today I got the gantry set up, the body lift rigging fairly level, the fuel overflow tank relocated and one half of the Amazon inner rocker drilled out. I made the kids clean the inside of the E30 out (it's like pulling teeth to get them to help). Tomorrow I'll drill out the other rocker first, then just straight to lifting the body and test fitting.
Getting closer. It's a process of lower, mark, raise, trim, lower, mark, raise, trim until I get it where I want it. Then it'll be raise, grind, weld prime, lower and weld.
