*!Build of the year candidate!* Strange PNW Build: E30+Volvo
  • Donkeyshins
    • 34
    #1081
    Originally posted by adam.nonis
    One of the things I'm trying to deal with (it's a personal problem) is not having this engine look “too new” in the vintage body. The reason I painted the block that color and wrinkle black painted the valve cover. My attempt to change the look leads me down some really silly paths. Like making an N52 oil cap vintage-erator. 😛
    Sent from my iPhone using Tapatalk Pro
    I stopped by the shop and met up with Adam and saw the progress. This is going to be a gem when everything is finished! Lots of really neat ideas at play.
    • adam.nonis
      • Apr 2017
      • 755
      #1082
      Plenum mold is done. Not the best ever made, but these always try my patience. Hopefully pull a part next week-ish
      • adam.nonis
        • Apr 2017
        • 755
        #1083
        Step one. Trimmed fresh out of the mold. Showing throttle body placement. Other half is done. Going to try and find time to combine the halves tonight. There'll be plenty of finish work to be done, but that's always the case for me.
        • adam.nonis
          • Apr 2017
          • 755
          #1084
          Beauty shots. Still some pinholes to fill on the plenum. Later though.
          • Panici
            • Dec 2009
            • 2325
            #1085
            Visually that looks fantastic!
            Let me preface this by saying: I don't know anything about intake manifold design.
            With that shape at the rear of the plenum, will #6 have the same airflow as say #3?
            '87 BMW E30 325is Turbo
            '99 BMW E36 M3 - - - '98 BMW E36 328i
            • adam.nonis
              • Apr 2017
              • 755
              #1086
              That remains to be seen, but with most intake designs there is a balance between packaging and airflow. Most cars don't have 100% equal airflow on all cylinders and design typically attempts to get the percentage of separation as low as possible across all cylinders. We sent through this in the early 90s with turbo Buicks. The rear two cylinders actually were lean in comparison to the front two. My thought process was to balance brake booster clearance and change the cross sectional area in a way that would help velocity the further away from the throttle body it got. In reality, if there was a cylinder I'd be concerned with, it'd be #1. We'll see. Luckily, the injectors are in the head. If this royally sucks, I can just put on one of the standard options.
              • Panici
                • Dec 2009
                • 2325
                #1087
                How will you determine per-cyl mixture though? Individual EGT bungs?
                • adam.nonis
                  • Apr 2017
                  • 755
                  #1088
                  You could. That's what you'd do if you wanted max HP. I won't be going through that much effort. You just tune to knock. Typically. I'm not 100% familiar with BMW tuning, but I know the N52 has knock sensors. If you can get knock and AFR to align, you're usually pretty good.
                  • Donkeyshins
                    • 34
                    #1089
                    As always, amazing work, adam.nonis! I really like the patterning on the plastic!
                    • adam.nonis
                      • Apr 2017
                      • 755
                      #1090
                      Busy week ahead. Seats are back from upholstery. Pics soon.
                      • adam.nonis
                        • Apr 2017
                        • 755
                        #1091
                        I know this is a BMW forum, so we'll say I'm prepping for the E30 picnic (I'll be there), but in reality, I'm getting ready for the iPd Garage Sale in Portland on the 18th. All Volvos, all day. I've convinced them to not have my car be part of the “judged” group, but allow me to pick Best of Show.
                        Anyway, there's gonna be some Volvo content and some E30 content over the next few days. This thread doesn't seem to get much traction anymore, so maybe my trigger warning doesn't matter. lol
                        • lukeADE335i
                          • Apr 2013
                          • 1384
                          #1092
                          Good to see the swap is progressing Adam - great work as always!
                          My e30: OEM+ with M30B35
                          • Donkeyshins
                            • 34
                            #1093
                            adam.nonis I'll be interested to see what the HP / TQ numbers look like with your intake manifold / airbox. Could be *very* interesting to those in the E8x / E9x crowd. Especially if there's a way to route into the stock airbox.
                            • Donkeyshins
                              • 34
                              #1094
                              adam.nonis I'll be interested to see what the HP / TQ numbers look like with your intake manifold / airbox. Could be *very* interesting to those in the E8x / E9x crowd. Especially if there's a way to route into the stock MAF / airbox.
                              • adam.nonis
                                • Apr 2017
                                • 755
                                #1095
                                Well, I didn't exactly take the time to photo journal the work I did. I decided last minute to try and make a carbon hood for my car. Materials arrived Tuesday at 11 and I was clear coating it by noon on Thursday.
                                I tried a different technique than I normally do. Instead of making a mold, I prepped and laid up three layers of carbon on the outside of the hood. De-molded that, then two layers of CSM on the inner structure. De-molded that, then bonded the two together. So, dimensionally it's slightly oversized from the stock hood, but there was room in the gaps.
