Daily'ed Sedan build: 1986 325
  • wworm
    • Dec 2016
    • 1719
    Whats up guys, I've been meaning to start this for a while now so here goes:
    I was looking for my first car and knew I wanted something european, old and tuneable. Thanks to r3v I decided on an e30 since there's so much info here. At the time my budget was super small but I needed to get a car asap as I was wasting a lot of time and energy biking to and from my jobs. I ended up checking out this car and it was in pretty solid shape considering I managed to talk the guy well below $2K for a running fully functional e30 325.
    (except for a blown indicator bulb)
    It is in desperate need of paint, and I'm open to color suggestions too, but for now I'm primarily focusing on performance before I dive into aesthetics. Id like to do a euro bumper swap but I think I'll settle for plastic bumpers due to the fact that they exist in the states.
    Here's the car a few days after I bought it.
    IMG_1398 by el_wormo, on Flickr
    It had a pretty used drivers seat so I ended up getting a corbeau gt seat that matched the age of the car pretty well and spent way too much time trying to weld a bracket for it before throwing that away and using angle brackets that the seller provided.
    IMG_1399 by el_wormo, on Flickr
    51166108071__D798FFAE-99F7-45D5-A0C3-524E7EB607BE by el_wormo, on Flickr
    Then I wanted to make a shift boot to replace the nasty old one. I've made a lot of backpacks in the past so I'm pretty handy with a sewing machine.
    51215993928__67E1455D-A1C0-423C-9202-D7CB5AF0C18D-2 by el_wormo, on Flickr
    I settled on the top right corner fabric. Unfortunately I didnt take enough photos of the process but it was a fun little afternoon project.
    I also made a goofy set of boots for my friends e36 m3.
    Image-1 by el_wormo, on Flickr
    some point along the way I refreshed the brakes with stainless lines, new rotors and pads but don't currently have any pictures of the new setup.
    Then I wanted to get into suspension. I rebuilt the rear end with 80A poly bushings, ST swaybar and welded diff and sway bar mounting reinforcements in, or rather, my old college roommate did that on a different subframe I purchased the day before while I was pulling the whole assembly out. I installed raised subframe bushings to counter the camber created when I put in H&R sports a month prior. I didn't realize that I needed to space the differential down until I was thinking about reinstalling it the morning of, so I had to run to the hardware store and find some spacers and extended diff mount bolts.
    IMG_1835 by el_wormo, on Flickr
    I didnt want to have to wait to burn out the bushings so I managed to hodge podge some things together in a big bench vice to press out the old OEM bushings. Heating the whole thing up with a torch definitely helped but I didn't have to melt or burn out the actual rubber
    IMG_1830 by el_wormo, on Flickr
    The rear trailing arm bushings just pressed out with a big C clamp.
    I wanted to buy separate front and rear subframes just so that I could weld the reinforcements in while still being able to drive the car to and from work. I'm currently working on the front subframe and its getting assembled with offset CABs, new control arms and motor mount/swaybar mount reinforcements. Also getting a steering rack from the e36 m3, as my buddy is putting a z3 rack in his car. Hopefully the front end will match the rear after this coming weekend. Right now the car drives pretty weirdly because the rear is so crisp and the front is all mushy. Very uhh...oversteerable
    Also did a late model ellipsoid swap about a week ago for better nighttime visibility
    IMG_1850 by el_wormo, on Flickr
    I installed dynamat under the rear seats to help reduce the increased road nose from the poly bushings. I want this car to be road trippable so that I can drive it down to bimmerfest next year
    IMG_1888 by el_wormo, on Flickr
    here's a really crappy picture of how the cockpit currently sits. I installed a euro clock at some point along the line.
    IMG_1884 by el_wormo, on Flickr
    I'll also note that I've got a slow pile of 24v swap parts accumulating under my bed/in my basement ;)
    and I'll end the first post with a picture of a beautiful example of what one of these cars can be that I saw in freeway traffic one day on my way home from workIMG_1529 by el_wormo, on Flickr
    1984 Delphin 318i 2 door
  • wworm
    • Dec 2016
    • 1719
    Ahh it seems none of my photos are working. I'm using flickr as photobucket decided to not be functional anymore. Anyone know how to fix these?
    • MR E30 325is
      • Dec 2008
      • 3300
      Excellent starting point!
      My previous build (currently E30-less)
      http://www.r3vlimited.com/board/showthread.php?t=170390
      A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
      • wworm
        • Dec 2016
        • 1719
        Originally posted by MR E30 325is
        This should help
        I'll update this post after you fix the links and I read your intor.
        Thanks!
        • sampayne
          • Apr 2014
          • 396
          Nice progress so far! Does the dynamat on the rear bench make a noticeable difference in reducing outside noise?
          Originally posted by 2mAn
          The BMW V6 is the best
          • wworm
            • Dec 2016
            • 1719
            Yeah I'm kind of impressed tbh considering I only put it under the bench cushion. I used to work in a porsche 356 and 911/912 restoration shop and dynamatted the entire interior of a track 912 build and was thoroughly impressed by how much quieter it was after sticking it everywhere. I plan to eventually put it on the floor under the carpet too and maaaayybe in the ceiling under the headliner.
            IMG_1409 by el_wormo, on Flickr
            Wish I had photos of the interior. Installing it sucked cuz that car is so damn tiny on the inside. But overall dynamat is just a big giant stretchy sticker and is super easy and very worth it in my opinion, especially for long trips and stuff.
            • sampayne
              • Apr 2014
              • 396
              Thats good to hear. I'll definitely have to get some. Thanks
              • The_Lope7
                • Jan 2015
                • 303
                Sounds like the dynamat is really doing the trick so nice! However I do cringe at the idea of ever having to remove it later down the road. That stuff is a huge pain to get off and leaves that nasty sticky residue everywhere.
                ▲ 1991 318is ▲ | Feedback Thread
                • Stanley Rockafella
                  • Aug 2011
                  • 4062
                  There's a simple solution for that....
                  sell the car
                  • wworm
                    • Dec 2016
                    • 1719
                    Yeah pulling it off is no joke, however, if you dont clean the surfaces prior to installation like me, it makes things a liiiiittle easier. I made sure not to cover up anything removable or any wiring so I can't imagine I'd ever need to remove it unless this becomes a full blown track car build...
                    I fantasize about a supercharged 24v setup...
                    edit: eyyyy 69th post
                    • MR E30 325is
                      • Dec 2008
                      • 3300
                      I had a supercharged S52 for a year or so (til the SC took a dump on me).
                      If you are fantasizing about it, I can tell you without any fear of error, that it is abso-fucking-lutely a must do!
                      Insanity is a great word to describe it.
                      • wworm
                        • Dec 2016
                        • 1719
                        Oh man thats a dangerous thing to say to me, haha. However, I live in CA and I'd like to BAR this swap for the time being.
                        What supercharger setup were you running?
                        • MR E30 325is
                          • Dec 2008
                          • 3300
                          It was the AA Rotrex C30 kit, slightly modified/upgraded
                          • _stefan
                            • Jul 2017
                            • 2
                            those shift boots look nice
                            • wworm
                              • Dec 2016
                              • 1719
                              Alright text only update for now, pics to come:
                              trying to get rid of the gnarly squeaks from installing poly bushings. If anyone has any tips other than "smear the living sh*t out of everything with copper anti seize" that would be great.
                              Was driving today and heard a chunk/clang immediately followed by a rubbing noise. Fortunately, I was only two blocks away from home so I got home and jacked the car up to find that I had lost a caliper guide bolt on the drivers side caliper. Got a replacement at the hardware store and loctited it prior to installation. After driving the car around I seem to have a sponge instead of a brake pedal now. As I'm going out of town for the weekend, I'll be taking the car into a shop to get looked over and hopefully my brakes will be back up and running smoothly by the time I'm back!
