Member since '03 back with a '89 325i
  • Smoove1
    • 505
    Well, time for an long overdue update...
    I entered a friendly bet with my good friend Duane over which would be faster. An E30 or a EF civic. So with that in mind, I started sorting out my car.
    First things first. My car had a miss at idle and low RPM. Compression test showed low compression on cylinder 4 and the leak down test showed it was coming from the exhaust side. So with that in mind, it was time to pull the head:
    We ended up finding 3 burnt valves. The worst on cylinder 4. Had the head refreshed with replacement valves and slapped the thing back together.
    Next up was refreshing the suspension. From what started as a simple bushing replacement turned into a whole lot of "well, if we're in there we might as well replace..." I ended up replacing the front LCABS, trailing arms, rear subframe, and diff bushing with Powerflex black series bushings. We decided to add adjustable trailing arm mounts to the subframe while everything was out. I also installed new front lower control arms while doing the front LCABs. I noticed there was a power steering system leak so at that point I did a Z3 1.9l steering rack conversion with new inner and outer tie rods, new p/s hoses and reservoir. Engine and trans mounts were also replaced at this time with IE urethane units. Shifter bushings were also replaced. While I was working on all this, my best friend, Kyle, was working on the strut housings for my Ground Control track school kit. While modifying the strut housings we decided to add some sway bar mounts to the strut bodies to use with E30 M3 sway bar end links. Before buttoning up all the suspension, I replaced the brake pads with PFC 11 compounds all around and SS brake lines.
    Last couple things to get the car prepped for the battle against the EF. I removed the sound deadening out of the trunk, added a TMS Chip, built a single SS 2.5in exhaust from the exhaust manifold back, and 949 Racing spec e30 wheels with NT01s. I also swapped the diff for a 4.10lsd from the 3.73lsd. Looking back I feel that was a mistake.
    We completed the car 2 days before the race. To save time, we loaded up the car and brought it over to Trinity Autosport for an alignment:
    And here is the finished product. Cosmetically it's not pretty but that the best we could do with the time we had.
    Here are some pics from battle day:
    And here is the video: https://www.drivingline.com/articles...e30-bmw-video/
    As you can see, I lost. I was pretty bummed out that all our efforts turned into a loss. I hate to say it but the Civic was the better car that day. If I had more time in my E30 I probably could have produced a better result. I also probably would have found out sooner that my ABS was failing. And before anyone ask about the drivers...
    This is my best time in the E30:
    We switched cars and this was my best lap in the civic. Please keep in mind I've never driven any Civic or FWD for that matter on a track before:
    I only did 4 laps total in the Civic. I put down a faster lap time then Duane's winning time on my second lap in his car. He ended up running a 2:11 in the E30.
    In all my sadness, I loaded up the car and headed home:
    So now what to do with this thing? I plan on continuing with sorting it out and doing a track day here and there. I still have my track prepped E46 M3 and S/C E36 M3 project to play with. I'm trying to avoid being too deep into this car but we all know how that goes. The next thing to do will be repainting all the rock chips in front and repairing the crushed left rear corner. I picked up a set of 16x9 BBS RS' to give it a bit more presence when driving to Sunday breakfast.
    The RS' were cool to look at but they rub a little too much for my taste. Running them made it was waste to have such nice suspension and not being able to go around a corner or freeway transition quickly. I decided to put the TE37s back on until I have some money to refinish the RS', fix the body work, and modify the fenders to make the wheels work.
    This is how it sits as of today. BBS RS' have always been my dream wheels for the E30 but I do like TE37s on everything.
    Thanks for following along. I'll update this again once more progress is made.
    • parkerbink
      • Jun 2004
      • 10138
      Sorry you lost, nice update.
      • Echo30V
        • Sep 2017
        • 301
        Awesome whip. Tour e30 is much cooler than the civic, so it won in my mind. By the way, do people still say “cool” or am I 100 years old and really not that cool?
        • ATL_E30
          • May 2017
          • 240
          I think the new phrasing is "Dope".
          Dope update Smoove!
          • e30_world
            • Aug 2014
            • 586
            Welcome back, what a nice car to get back into e30's with!
            F80 M3 Alpine
            E10 Fjord Blue 2002
            E28 Blackish 535i
            E21 Silver 320i
            Disco1 98 4.6
            E30 Cirrus coupe S50 SOLD
            E30 325i SOLD
            E30 Alpine 325i vert Euro spec SOLD
            E30 Alpine coupe 325is SOLD
            • Jamie H
              • Jul 2012
              • 55
              Welcome back!,
              Where did you source the mtech 1 style spoiler from? It looks to be one solid piece but it fits well.
              Would love a reproduction option that's decent rather than paying through the nose for a worn genuine example.
              Thanks!
              • Balleristic31
                • Aug 2009
                • 4198
                Wow I have never seen TE37s look so good on an e30! Making me want a set! :)
                -NICK
                • 2mAn
                  Señior Mod
                  • 21005
                  The TE37s look great
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • Smoove1
                    • 505
                    Originally posted by Jamie H
                    Welcome back!,
                    Thanks!
                    The spoiler is a replica I ordered off of eBay. The fitment was good and I plastic dipped it instead of painting it to make it look more rubber like an original. Also, the filler plate is matte black vinyl and the tail lights are laminx’d since MHWs are like $750 now for some reason.
                    • alistairolsen
                      • Jul 2017
                      • 191
                      An example of modern wheels on an old car that I actually like! Good job so far!
                      • Smoove1
                        • 505
                        Thanks guys. They're one of my favorite wheels.
