ITB without standalone ECU
  • Justbergy
    • Nov 2016
    • 41
    Hey I was thinking about doing ITB's on one of my m20 engines and thought to use motorcycle throttle bodies but then the standalone ecu is like 700 bucks minimum. So it got me thinking about modifying the AFM. I believe all it is is a barn door type flap that has a resistance that changes based on how far open the "flap" is. could you hypothetically put the Air flow meter on the exhaust? obviously some modifications would need to be done but would that work almost? My thinking is all it needs to do is have the flap move based on the air the engines using. I know its pretty ridiculous but just thinking outside the box ya know?
    Thanks
  • ThatM20Guy
    • Aug 2014
    • 600
    If you are willing to do some soldering you can get a mega squirt kit for as little as $300
    Shop Classic MegaSquirt ECUs at DIYAutoTune for standalone engine management, tuning flexibility, and proven performance control.
    89' 325ix Diamantschwarz/Black rattle can...
    Insta: r_moose_w
    Originally posted by flyboyx
    I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
    • digger
      • Nov 2005
      • 6173
      you can put the afm on the inlet with the right airbox, but ive also seen a MAF used. you can make an airbox without much difficulty. im sure you could find a used ECU if you hunt around
      i would not look into the AFM on exhaust any further.....
      • Kershaw
        • 11822
        Wouldn't there be throttle response issues with the AFM in front of a large plenum feeding into ITBs?
        AWD > RWD
        • digger
          • Nov 2005
          • 6173
          since you'll be making a plenum/airbox from scratch ideally you would make a smaller plenum like the size of the dbilas which is designed to work with OE AFM.
          if you were truly worried about throttle response youd ditch motronic and the AFM and run a proper tps and full standalone where you have the freedom to easily change the fuel delivery and injection timing, ignition timing etc
          • Kershaw
            • 11822
            Hah, true.
            AWD > RWD
            • Justbergy
              • Nov 2016
              • 41
              Thanks so much for the info. Probs smart to stay away from going that would haha. Thanks again
              • Todd Black 88
                • Oct 2007
                • 3449
                Ummm.....like the s14?;)
                Originally posted by codyep3
                I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                2001 silver/Blk 325 cabby. SOLD
                2002 325xit Sil/blk. SOLD
                2010 F650gs twin
                • JimmyP
                  • 394
                  Well yeah,,, to a degree.
                  Once one experiences an S14 with no AFM and Alpha N or an MAF vs with an AFM in front of the TBs, it feels absolutely broken when you feel it with an AFM again.
                  Jimmy P.
                  87 E30 M3 Prodrive British Touring Car
                  88 E30 M3 Zinnoberot - Garage Queen
                  88 E30 M3 Lachsilber - SCCA SPU #98
                  92 M Technic Cabrio - S14 Powered!
                  98 318Ti Morea Green
                  04 Ford F350 Dually Tow Machine
                  • The Dark Side of Will
                    • Jun 2010
                    • 2796
                    That's what well tuned acceleration enrichment and deceleration enleanment are for.
                    • digger
                      • Nov 2005
                      • 6173
                      That doesn't work very well with AFM and throttle switch
