Restoring the 2nd produced E30 318is !
  • kenshin86
    • Feb 2018
    • 44
    #31
    Spring 2023 update
    Without a catalyzer or middle resonator, the exhaust was loud, so I got a new Walker resonator and Quite-Flow SS muffler.
    The existing exhaust was completely rotted and also in the wrong size: 2" pipe was welded after the manifold instead of the standard 2 1/4" for a 318is as seen in the below picture.
    New stainless steel muffler and resonator with correct 2 1/4" pipe.
    The old muffler fell off during removal.
    Finally managed to get iS seats instead of the existing E36 leather seats, and after a lots of cleaning and sorting out small things below are the results:
    seat rails sanded, cleaned, painted and lubed.
    3rd seat belt was hidden under the rear seats.
    knee pad worm gear.
    cloth cleaning
    Before and after:
    Until next summer.
    • kenshin86
      • Feb 2018
      • 44
      #32
      Summer 2023 update
      - Driveshaft vibration
      Recently I started to notice a thumping rotating noise coming from the driveshaft, the center support bearing is solid but I there is a play in the center locking nut: the plastic inside it might be worn or it may need more tightening.
      After driving the car more, the problem was was only observed during on/off throttle or when engaging the clutch.
      As per the Bentley manual troubleshooting table this is most likely caused by a siezed sliding coupling, and indeed upon further inspection the gunk on the splines were baked in so hard I had to use an angle grinder with a brush wheel to clean them.
      In addition, the plastic teeth of the central locking nut were gone, that explains the play in my last video.
      With a new nut and fresh moly grease, the vibration is now gone !
      - Headlight restoration
      The plastic frame of my headlights were broken beyond repair, and the light assembly was glued onto the front grill using silicone to hold it in place.
      So I got new frames, 3D printed the broken plastic bits of the adjusting screws, crimped some bullet connectors to the wires instead and painted the metal rings.
      - the work bench
      - remaining parts to be installed
      - rust repair
      It was finally the time to do what should have been done from day one: welding work. At the start of this journey 7 years ago I didn't have the knowledge, and was not aware of the common rust locations, and I dreaded the work because of the limited time I can spend in each visit (2 weeks max), so I took the car to a local body shop to uncover the below
      dashboard removed
      scuttle area
      new sunroof
      behind rear wheel, all the fuel hoses were rotted
      new sheet metal was welded on top and covered with fiberglass putty and then epoxy primer.
      Hopefully in the next spring the car will be fully painted.
      Until next time.​
      • Panici
        • Dec 2009
        • 2571
        #33
        Originally posted by kenshin86
        - The bulk of old/broken/replaced parts:
        - Rust repair
        That is a seriously impressive pile of items replaced! Nice work.
        Going to keep as spare parts or throw them out?
        I had many of those same rust spots on my car, and a few more on top of that.
        Took years but finally repaired them all!
        • kenshin86
          • Feb 2018
          • 44
          #34
          I will keep them in case some parts in the future are NLA, and to remind my self how much money I spent :D
          Glad to hear yours is finished, and what a beautiful color especially in the sun !
          • kenshin86
            • Feb 2018
            • 44
            #35
            Update Spring 2024
            During this visit I decided to do a full body paint since the whole process will not cost you more than $ 500 in Lebanon.
            It took around 4 weeks to finish and below are the results:
            Coming out of the spray booth:
            Reached my garage:
            Identifying all chopped and sliced wires with a help of label machine and crimping in new connectors for the headlights:
            Replacing OBC damaged screen:
            Next visit in God's will should be the re-installation of the interior/dashboard/seats and hopefully I can get all the wiring sorted out.
            • Panici
              • Dec 2009
              • 2571
              #36
              Paint work looks good. Now for the long reassembly/rebuild!
              • Northern
                I like cupcakes & sh!tboxes
                • 5284
                #37
                Paint turned out great!
                Originally posted by priapism
                Originally posted by shameson
                • kenshin86
                  • Feb 2018
                  • 44
                  #38
                  Thanks ! Honestly I was not expecting this degree of black although it is the correct original color Diamantschwarz metallic.
                  Maybe the previous paint was faded away due to age and I was perceiving it more as dark grey when the sun was shining as you can see in this old photo:
                  • kenshin86
                    • Feb 2018
                    • 44
                    #39
                    Thanks ! the reassembly sure takes more than expected when you have to sort all the wiring and clean all the parts.
                    Painting took around 4 weeks to finish and costs around $ 500 in Lebanon believe it or not.
                    • Panici
                      • Dec 2009
                      • 2571
                      #40
                      $500!? That is absolutely amazing!
                      Even the cheapest paint jobs around here cost 10x as much. 😵
                      • zwill23
                        • Jul 2015
                        • 615
                        #41
                        Love comeback stories like this. You're running out of things to replace / restore so I guess that means it's time to enjoy it
                        • kenshin86
                          • Feb 2018
                          • 44
                          #42
                          Summer 2025 update:
                          During my vacation, I have assembled back all the interior and sorted out the electrical issues I was facing before:
                          - All of the center console / dashboard lighting was not working, it turned out to be a broken headlight switch rheostat, I used this nice guide to fix it:
                          Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
                          - The wiper arm was not activating the washer water pump when pulled in, the problem was a dirty contact inside the switch itself: there is cutout where you can spray contact cleaner and use a tiny file/sandpaper to clean it.
                          Finally it was the time to do the steering rack upgrade: 5 years ago I got a new Z3 rack from China for around $ 300 shipped from AliExpress (https://a.aliexpress.com/_c3QiKjTV), I believe it's the same unit sold in the US under the AAE company name model 3111N.
                          The conversion was the hardest job I've done so far, with me under the car pushing the new rack up in while dad was inside the car to mate the male splines of the steering linkage to the female splines of the steering shaft coming from the steering wheel.
                          The steering knuckle u-joint cross bearing was also replaced with a new one (model # ST1540), with new rubber guibo and plastic guide pin as I was having lots of bumps and vibrations in the steering wheel whenever I go over a bump on the road.
                          The steering was installed without the hydraulic assist, and after driving the car I felt it was a little heavy at slow speeds, so maybe will consider putting it back the hydraulic part in the future.
                          The below video shows the amount of play that was present in the knuckle before:
                          And the conversion is not complete without a newly re-upholstered 370mm small steering wheel that I did myself using this guide as reference:
                          https://forums.pelicanparts.com/pors...-tutorial.html
                          Here are my kids adding the rear emblem as the final step in the assembly before driving the car:
                          Bonus content: my brother-in-law's E30 with the rare Folger wide body kit
                          Thanks !
                          • Panici
                            • Dec 2009
                            • 2571
                            #43
                            Z3 Rack and 370mm rack is a great combination. That's what I run in mine.
                            Steering wheel looks okay, but having that top stitch line uncentered would drive me nuts!
                            • kenshin86
                              • Feb 2018
                              • 44
                              #44
                              - During my home country visit this summer, I got help from my sister's father-in-law to replace the subframe bushings, a job I always feared to tackle. He repairs BMWs since the 1970s and have a special press designed specifically for this job:
                              In a matter of minutes, the old bushing was out and the new one was in while the car was on post lift.
                              Without this tool, I was planning to use the below linked method, using a 5/8" bolt:
                              Remove a stuck, seized rear subframe bushing on a BMW E30 - technique for oxidized bushings that will not budge.
                              In the below gif you can see the condition of the old ones:
                              - The elephant trunk rubber drain hose 51731911369 below the front windshield was hard as a rock.
                              Considering the replacement from BMW is around $ 50 (51731911369), I printed one myself from TPU (flexible rubber material).
                              I installed it and it fit well ! The 3d model was downloaded from cults3d.com for around 3 Euros.
                              - The Tachometer in my cluster was not working since I bought the car.
                              I replaced the batteries and bought another cluster and tried it without success.
                              Finally I found a way to bench test the tachometer to check if the problem is from the board or in the wiring.
                              This was done using a 12V battery, some wires and a signal generator.
                              The excellent guide can be found at:
                              Bench Testing BMW E30's Tachometer: In this article, I am going to show you how to bench test your E30's tachometer using a signal generator. Also, I will give you the specification for the tachometer signal to use.
                              To my surprise, I found that there is no problem in the cluster / board.
                              The RPM needle is moving and the issue is in the wiring !
                              I suspect the signal wire coming from the ECU is the problem since all other wires checked OK.
                              - Ultrasonic cleaning for the fuel injectors and filters change:
                              - I opened the fuel tank to the condition from inside.
                              It was clean and rust free, but found a rubber gasket laying in the bottom so I removed it:
                              - Replaced all the fuel hoses on top of fuel tank, which one of them was held by zip ties !
                              Also changed the fuel pump filter and oring.
                              - The sunroof handle was sagging and falling down, so I put it in a vise to press in the tabs holding the handle, problem solved:
                              - Cleaned the AFM and changed its gasket:
                              - The floor mat was not staying in its place under my feet and moved all around, so I added plastic holders and screwed their counter part in the carpet:
                              - Finally did a compression test after all these years and found that all the cylinders are in very healthy condition with pressure ranging from 205 to 210 psi for all:
                              - Replaced the side mirrors glasses with new ones from China:
                              - Until next time !
                              • Panici
                                • Dec 2009
                                • 2571
                                #45
                                Did you use submersible rated hose for the in-tank fuel pump connection?
                                I tried it with regular fuel injection hose and the outside was soft within a month.
                                I ended up replacing it with submersible-rated Gates 27097 (3/8" ID)
