The Blunderwagon - 89 325iX touring 3.1L stroker
  • Julien
    • 7471
    #181
    Originally posted by kronus
    tossed the iX weaves back on and have been driving it.
    I wonder who balanced and installed those rims on the wagon, they did an AMAZING job
    ;D
    Build Threads:
    • kronus
      • Apr 2008
      • 13032
      #182
      I don't know but I've heard they also found me a sick deal on the center caps and look real good running around a track in pink yoga pants
      cars beep boop
      • Danny
        • 14216
        #183
        This has never been verified.
        • FredK
          • 14763
          #184
          Thank you for bringing this up.
          Julien, when will you satisfy your end of the bargain?
          • kronus
            • Apr 2008
            • 13032
            #185
            shit i just got the best idea for a belated birthday present
            cars beep boop
            • FredK
              • 14763
              #186
              I believe I said sweatpants. I don't want to see Belgian pipe flopping around in yoga pants. Or do I?
              • Julien
                • 7471
                #187
                The later I wait the more epic it will be, amirite? 65 year old belgian in pink pants runs lap available 3d virtual reality youtube
                Build Threads:
                • FredK
                  • 14763
                  #188
                  Danny, please arrest him. jk
                  • Danny
                    • 14216
                    #189
                    He’s in some inner city somewhere. I’m COUNTY LAW BABY. Fuck cities.
                    • Julien
                      • 7471
                      #190
                      bump
                      Build Threads:
                      • 2mAn
                        SeƱior Mod
                        • 21031
                        #191
                        Originally posted by Julien
                        bump
                        so many builds, so little updates
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        Make R3V Great Again -2020
                        • kronus
                          • Apr 2008
                          • 13032
                          #192
                          ok ok ok jeez
                          I converted the stroker motor to AWD spec. I took detailed photos of this since nobody else has documented it thoroughly, but need to dig them out and put a big ol thread together.
                          The things that had to happen:
                          - swap IMS and IMS gear to iX (spins the other way)
                          - swap oil pump and oil pump drive shaft
                          - mount iX rear sump bracket to #5 bearing cap
                          - drill and tap two additional holes in the bottom flange of the block for the additional bolts that go around the pass side front driveshaft
                          - get some threaded plugs that match the RWD oil relief valve hole, drill out their centers to allow oil to pass through, thread them in and butt them up against each other to set their level flush with the block bottom surface
                          - drill and tap a mount hole for the oil pressure relief part of the iX oil pump
                          - enlarge and retap the motor mount holes since the iX mounts use bigger bolts
                          - tap out the old RWD dipstick
                          - drill a new hole for the dipstick, push a cutoff bit of the former RWD dipstick into it to match the iX setup
                          - plug the old dipstick hole with a rubber enlarging plug thing
                          it was a bit of work but it's done
                          anyway then last weekend I dropped the old driveline out while julien took creepshots of my ass crack ;D
                          disassembled the driveline from around the old shitty motor
                          did some deferred maintenance -
                          - new tie rods (inners and outers)
                          - new tie rod boots (old ones were totally fucked)
                          - different control arms with new lemforder outer balljoints (yes, old ones were fucked too)
                          - new sway bar links (guess)
                          - new sway bar bushings
                          - new front driveshaft bearing that goes into the oil pan extension flange thing
                          - subframe that doesn't have a huge piece fucked out of it
                          everything went back together using a novel assembly method -
                          (oh yeah also I got some IE long tubes and a fuckload of 2.25" to build into a nice midpipe)
                          and it's ready to be reinstalled now, more or less, so, that's where we are.
                          cars beep boop
                          • jeenyus
                            • Aug 2011
                            • 2064
                            #193
                            Nice. Find a way to use RWD transmission mounts on the IX to keep the transmission in place. Since it's out and all
                            Sent from my Pixel 2 using Tapatalk
                            • kronus
                              • Apr 2008
                              • 13032
                              #194
                              not sure what you mean - there's no RWD flanges on the transmission so I can't use a RWD-style bracket.
                              cars beep boop
                              • jeenyus
                                • Aug 2011
                                • 2064
                                #195
                                On the transmission there are spots for the mounts (at least on mine) and I've been thinking how I'd be able to get some more support back there. A single mount is cool and all, but imagine more support back there...
