The Blunderwagon - 89 325iX touring 3.1L stroker
  • kronus
    • Apr 2008
    • 13020
    #91
    That is most likely not your throwout bearing. It might be your pilot bearing, or input shaft bearing on the transmission.
    I don’t have a part #, sorry. As far as I can tell, this is a regular m20 kit. I think the ix kit is dimensionally similar but has a stiffer pressure plate spring.
    cars beep boop
    • jeenyus
      • Aug 2011
      • 2064
      #92
      I ended up just using a regular M20 kit from Sachs too. I didn't see anything ix specific.
      • D.Martijn
        • Sep 2016
        • 1022
        #93
        Cool, thanks. That might also be the silent whining I'm hearing when I accelerate under load.
        No problem. So far I've found this number for a Sachs kit 3000 132 002, looks like a regular 325i kit.
        And yes, the pressure plate spring is stiffer.
        1990 325iX Touring - November 2018 R3V Car Of The Month
        1980 Volkswagen Golf mk1 1.1
        1974 BMW 2002 Touring
        Instagram
        • Julien
          • 7471
          #94
          Originally posted by D.Martijn
          Do you happen to have the part no for the whole kit? If I'm not mistaken the ix has a different pressure plate that the regular 325i.
          It rattles with the pedal out, when I press is in, the rattle is gone.
          That's every 325i ;)
          Build Threads:
          • kronus
            • Apr 2008
            • 13020
            #95
            can confirm
            also, anyone have any really super excellent 100% great ideas/tips for pulling out the TC bushing that aren't "have the specific OEM BMW tool you need for just this purpose"?
            cars beep boop
            • parkerbink
              • Jun 2004
              • 10137
              #96
              Borrow the tool from Ryan G?
              lol
              • kronus
                • Apr 2008
                • 13020
                #97
                heh, maybe if he wasn't 2 hours away.
                I think a shopmate has a generic bushing puller tool. will see if I can rig it to work. the offset hole is a pain.
                cars beep boop
                • parkerbink
                  • Jun 2004
                  • 10137
                  #98
                  In '80 I drove from Santa Monica to Newport Beach for a carb for my first '71 2002. Was over a 2 hour trip on the San Diego parking lot then.
                  lol
                  • jeenyus
                    • Aug 2011
                    • 2064
                    #99
                    can confirm
                    I just got a little hack saw, took out the bushing, then i sawed through the metal sleeve and banged that bitch out with a hammer. Took maybe 30-45 min to get it out. To put in the new one, freeze it and then get some grease to slide it into place. Make sure the geometry is lined up or it will get slightly stuck.
                    IF you want pictures for reference it's in my thread somewhere.
                    • kronus
                      • Apr 2008
                      • 13020
                      #100
                      I'll take a look, thanks.
                      Also, primered and undercoated my booger weld job last night in prep for the trans to go back in, and got my driveshafts cleaned up, primered and painted. All that stuff's boring, so no photos yet.
                      Trans, TC and driveshafts should be going in this weekend if I can get the bushing swapped, and then I can finally drive it for real.
                      cars beep boop
                      • jeenyus
                        • Aug 2011
                        • 2064
                        #101
                        I'm waiting on a gargistic TC bushing in 80a poly. Looks like a great piece, so i might be in the same boat this weekend. Mine will be much easier to push in though, cause it's not metal sleeved.
                        • D.Martijn
                          • Sep 2016
                          • 1022
                          #102
                          So I assume you are now using the E34 CV joint for your rear driveshaft?
                          Instagram
                          • kronus
                            • Apr 2008
                            • 13020
                            #103
                            That is the plan, but it looks a little tight. Might end up needing to space the diff down a bit, which would suck but is not the end of the world.
                            cars beep boop
                            • 2002tiiguy
                              • Jul 2013
                              • 467
                              #104
                              kronus, for the bushing, i think i cut out the old one and then used a balljoint press c clamp to push the new one in
                              • 2002tiiguy
                                • Jul 2013
                                • 467
                                #105
                                Heres an ix pressure plate, i can do some measuring if anyone is interested
