Melon's E30 Build.
I've spent the past few days diagnosing what's going on, to no avail. Checked the valve clearances again, all good, tried different injectors, same rough idle. Unplug AFM, it stalls, so it's working, same thing with TPS and ICV. No vacuum leaks, no clogs in any fuel line either. It does it with both FPR's I have.
I have new injectors and new spark plugs and wires on the way.
I ripped a lead on my new wires, and am using the old set. It's probably fine, but I'm trying to reduce variables.
Really not sure what else to check. Going to fix a nasty exhaust leak, and wait for new parts to arrive.I do things.Comment
Current flame: E30 318iS Alpinweiss II slicktop / LSD - Joanne
The old man: 1970 2002 Polaris(ish) slicktop / rat rod - Wallace
The ex: E92 335i 6MT M-Sport - Betty
The heavy: 2001 4Runner SR5 Sport (3rd Gen) - FredComment
finally figured mine out after replacing the throttle body switch, that blue computer under the glovebox, and vacuum hoses and doing some vacuum leak testing while inhaling a stupid amount of mineral oil that God knows what if my toilet has yet recovered.
Idle control valve. Junkyard should be cheap
Try cleaning your idle control valve?
My valve was completely shot so I decided to just permanently restrict the air going through it. drilled a hole in a penny and put it in the intake part of the icv and my car started dieing immediately off throttle and especially with A/C on since I had restricted the icv to much, I made the hole bigger and she idles great.
Before the penny she idled insanely revving from 700-1500 and not letting me get in gear without grindings all the time. Now she's steady dead on 700 with the penny for the past months
Sent from my Pixel 3 XL using TapatalkLast edited by Sonny; 03-23-2019, 09:12 PM.Comment
I cleaned the ICV and even bought an eBay replacement (that seemed to run worse)
But, I like the penny idea, what size hole did you drill?
As far as the TPS goes, when I unplugged it and the AFM the car died. AFM was restored by Bavarian Restoration, TPS is also new and both worked fine before I serviced the valves.I do things.Comment
Honestly I used a random nail and smacked it in the penny against a piece of wood/tree. To lazy to mount a penny to drill so don't know the size but I'll tell you this, you can try it over and over it'll cost a penny each time. Mine worked great the second time, hole is smaller than the average ladybug. I'd say half the size of a Tic Tac.
When you do this cold starts will be COLD STARTS. She will bog out and die every cold start unless you hold the gas, but don't do it while starting the BMW motors hate getting flooded with someone flooring it while turning the key, and cold 20w-50 oil is sitting at the bottom so don't go past 1.5k rpms during warmup, as soon as the car starts push the gas slightly and warm her up manually for a minute or two, after that you can remove you foot of the gas and she'll hold her idle. I've been running like this for 70 miles daily, seems like the icv did a simple job of just restricting airflow but it costs to much for me to consider a $400 new one. A penny did it all, make sure it is seated straight, I put it against icv and then pushed the icv into the hose to connect. I noticed if I put the penny in the hose first and then the icv right after it made no difference since the penny always finds a way to tilt almost immediately or while driving, so have it against the metal of the icv and them push in fast, youll know if you did it right.
Oh and the eBay one goes in the trash use your original
Sent from my Pixel 3 XL using TapatalkLast edited by Sonny; 03-24-2019, 08:59 AM.Comment
So It was running well last night, just idling poorly.
Went to drive it to work today, and it would start and die, it would only stay running with the throttle opened up a little bit. Think the ICV finally shit the bed.
Found one on eBay (Not the Chinese special) so I'll give that a shot.I do things.Comment
I’m in the same boat brother. Been dealing with surging idle since getting the car running again, can’t find a vacuum leak and everything in the engine bay is brand new. Unplugged the ICV and it didn’t change a thing so bit the bullet and bought a new ICM and ICV, talk about a wallet tap.'86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
Albie325 Build Thread | Albie325 COTM Jan 2021Comment
