1985 325e
  • wholepailofwater
    • Apr 2018
    • 63
    1985 325e
    Hi everybody, just picked up a one owner 229,000 mile, manual trans, e30. Its got cloth interior and no cracks in the dashboard. Got a folder full of receipts and records, starting with the bill of sale from the dealership.
    I have been reading up as much as possible on e30's, this is my first BMW. But I have always had German cars, VW, Benz. Already got the bentley service manual.
    I need to do a timing belt change asap, water pump as well? Any suggestion on where to get the timing belt and other parts? Is there a place that sells a kit? Anything else I should check out while i'm in there?
    I'll post some pics when I figure out how.
    Thanks
    JP
    1984 533i
    1984 733i
    1985 325e
    1998 M3
    1998 318ti
    2008 335i
  • Echo30V
    • Sep 2017
    • 301
    Welcome to the wonderful world of e30s. If you don’t know and/or have no records of the last timing belt change then it is imperative that you change the belt. For that matter I would change the timing belt to include the timing belt, engine timing belt tensioner, camshaft seal, crank shaft seal, water pump, thermostat , PS pump belt, alt drive belt, ac belt, distributor cap, spark plugs and possibly ignition coil. You also should do a valve adjustment and replace the valve cover gasket. Change the coolant, differential fluid and brake fluid.
    • wholepailofwater
      • Apr 2018
      • 63
      Awesome, Thank you. Exactly what I'm looking to hear, I've been looking thru the folder that came with the car and can't nail down the last timing belt change.
      1984 533i
      1984 733i
      1985 325e
      1998 M3
      1998 318ti
      2008 335i
      • wholepailofwater
        • Apr 2018
        • 63
        Found the receipt for the last timing belt, 2005 and 40,000 miles ago. Ticking time bomb? Should I stop doing clutch drops at 3500 rpm?
        Any suggestions on where to get aforementioned parts?
        Thanks
        JP
        1984 533i
        1984 733i
        1985 325e
        1998 M3
        1998 318ti
        2008 335i
        • Echo30V
          • Sep 2017
          • 301
          Parts from ECS, Pelican Parts and/or FCP Euro
          • itsonlygeorge
            • Feb 2014
            • 852
            Don't drive it unless you want an expensive paperweight! Timing belt ASAP!
            1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
            Originally posted by nando
            I don't think there's really strong evidence that ZDDP harms cats.
            • 2mAn
              SeƱior Mod
              • 21088
              Thanks
              JP
              Definitely a ticking time bomb.
              Originally posted by Echo30V
              Parts from BluntTech
              support those who support us #theyfoughtforourfreedom #neverforget
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              Make R3V Great Again -2020
              • wholepailofwater
                • Apr 2018
                • 63
                I haven't been driving it. All the parts got delivered today.
                Timing Belt
                TB tensioner
                water pump
                thermostat
                lower timing cover gasket
                Coolant
                camshaft seal
                Crankshaft seal
                Cap
                Rotor
                Wires
                plugs
                coil
                o2 sensor
                fuel filter
                valve cover gasket
                all new belts
                guibo
                new fan clutch
                updated head bolts (torx heads)
                shifter rebuild kit
                Prob some more little stuff that I missed but, a whole tune up to get this ole thing purring like a kitten....
                While I gather all the parts for a K24 swap!!:):)
                1984 533i
                1984 733i
                1985 325e
                1998 M3
                1998 318ti
                2008 335i
                • wworm
                  • Dec 2016
                  • 1719
                  oh goodie.
                  1984 Delphin 318i 2 door
