87' vert progress thread
  • jhaurimn
    • Nov 2012
    • 2224
    Originally posted by me_john85
    Did you find vogtland convertible springs? Or did you use regular e30 springs?
    Springs are based on the engine, there shouldnt be a difference from coupe/sedan and vert. Its either 4cyl or 6cyl.
    Current:
    1989 325i
    1988 M3
    1987 325ic
    Past:
    2001 330ci
    2001 M3
    • paynemw
      • Dec 2015
      • 439
      I really like the red interior + black paint. I wish the PO for my '87 325iS kept the red interior.
      • jhaurimn
        • Nov 2012
        • 2224
        Little overdue for an update. I hardly did anything with the car in 2019 until the fall, but updates have been steady since.
        It was September before I really messed with the car at all, and had a no start issue. Fuel pump fuse kept blowing. Since there are two pumps, I replaced the fuse and tried starting without the internal pump plugged in. In my quick testing, the fuse didnt blow again. Ordered a new (and expensive) internal pump from blunttech
        Old pump didnt look too bad.... and car still would not start. Tried fuse test again and managed to blow it with internal pump not plugged in now. Time to order another fuel pump. Go to remove the old one....uro branded pump. Doesnt look to be that old....replaced with bosch pump
        New filter while I was in there. Car starts again.
        Big package....whats inside? Euro bumpers and a euro valance. (no picture of parts unboxed for some reason)
        With old valance removed, took some time to tidy up the harness
        New euro valance primed up. I applied por15 to the backside as well to protect against rust prior to this.
        A NAPA auto near me has a paint area where I can get paint put into a can, as I do not have a setup to properly spray paint. Its worked well in the past. Decided it would be fine for the valance as it has a rough texture and is separated from the rest of the car with the bumper.
        I was surprised, compared to the old valance, paint matched perfectly.
        I had a little bit of paint left...and was not planning to paint the extra fender I got when I bought the car. (as the one on the car was smashed) The paint wouldnt be good after a few days, so I decided to just see if there was enough left for the fender. I am not joking when I say on my last coat of clear I had two decent sprays left before it started splattering due to the can being empty. Didnt get as much clear on it as I would prefer, but it was enough.
        While wetsanding
        And after. Not perfect, but excellent for a spray can job in my opinion.
        Old smashed fender removed, and a shit load of dirt with it. I applied por15 to any surface rust I found.
        After putting on the new fender and giving a 10 second hand polish to the neighboring door, I was relieved to find the paint matched.
        Door was filthy as you can tell
        And valance on. You may also notice I put some smoked headlights on. They did not last long.
        I started prepping the front euro bumper for install a month or so ago. Started by cleaning up the plastic bits
        After
        And not many pictures of the process sadly. But eventually I figured out how it all went together and got it on the car!
        Now you may notice something missing...fog lights. The valance i bought came with brackets for fogs, but not the lights themselves. My m3 since I bought it had butchered wiring on its fog lights, and I thought this would be the perfect opportunity to fix that, while also giving the convertible some fogs as well. Just had to switch around some brackets.
        Here you can see the plugs had been cut off. I obtained plugs some time in the past to wire in and fix this.
        The m3 brackets pop right off
        With those off, they pop right into the euro valance fog brackets.
        Aaand wiring fixed.
        Nice and tidy.
        And installed. Front end finally looking how I imagined when I bought the car. (also switched to normal smilies at this point as I didnt like how the smoked ones looked)
        Getting to almost current now. Paint had seen better days
        After a little compound polishing, looking much much better. Not going for perfect as there are some very deep scratches.
        ​​​​​​​M3 was on shelf duty for a bit while I waited for the brand new fogs to arrive to replace the ones I stole off of it haha
        Obligatory euro grilles
        And now to yesterday. Finally ripped out the shit aftermarket radio setup. HVAC panel was destroyed so I ordered another to replace it.
        Rear speakers were toast.
        Aftermath of removing all the extra wiring. Was tapped into the original harness but in a way that was easily fixed thankfully.
        Mucho better
        And everything I took out minus the cd deck which was a pain to get out so it immediately went in the trash. Still have to pull front speakers as well but saving that for another day.
        Aaaand we are caught up. Still waiting on a good shape rear euro bumper, should have one this summer. Been thinking about wheels as well....
        Current:
        1989 325i
        1988 M3
        1987 325ic
        Past:
        2001 330ci
        2001 M3
        • Tzantushka
          • Nov 2018
          • 390
          Euro bumper turned out really nice.
          Looks really clean!
          E30 320i vert
          But daily drive is Volvo V60 Polestar
          • bradnic
            • Jul 2012
            • 3554
            SUB'D. glad we got you squared with the amp bypass! I updated the speaker wiring thread with your pic.
            HOWTOs:
            DB vert plastic bumpers
            OEM Keys
            MTech1 docs
            88 ix Lach/Card
            91 ic Calypso 3.1
            86 Cosmo 2.7
            OEM+ or bust!
            • jhaurimn
              • Nov 2012
              • 2224
              Update time :)
              When redoing the radio stuff, I decided to replace the destroyed hvac panel.
              There was also a chrome trim piece here that had the broken plastic piece that plugs into the body broken, so bought a new one to replace.
              Got lucky and there was one on ebay available that was in decent condition. Old broken one on top
              My transmission used to grind into 3rd if i shifted at all quickly. Went to go change the fluid, and the transmission was definitely low. New MTL fluid was put in and the grind is gone.
              Also found a rear euro bumper :)
              Aaaaand, a birthday present to myself, a new set of ronal LS wheels with yokohama adven fleva v701 (the replacement to the yokohama s drives)
              Thats all for now. :)
              Current:
              1989 325i
              1988 M3
              1987 325ic
              Past:
              2001 330ci
              2001 M3
              • 2mAn
                SeƱior Mod
                • 21017
                Wow, looks perfect now.
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • 2mAn
                  SeƱior Mod
                  • 21017
                  jhaurimn Time to bring this thing out of the garage?
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  • jhaurimn
                    • Nov 2012
                    • 2224
                    It is now. :)
                    Whats going on here....
                    Ope.
                    OPE.
                    OPEEEE.
                    Boom.
                    Goes.
                    The dynamite.
                    All buttoned up, just gotta tidy up the engine bay a bit and bring it to an exhaust shop. This is the m52 from my old rusty 325i, and this is at least the 5th car its been in. 3rd e30. Shes a trooper.
                    Current:
                    1989 325i
                    1988 M3
                    1987 325ic
                    Past:
                    2001 330ci
                    2001 M3
                    • 2mAn
                      SeƱior Mod
                      • 21017
                      Now how about an M3 update?...
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      • jhaurimn
                        • Nov 2012
                        • 2224
                        Unfortunately, nothing really to update on the m3. I went crazy on that car for 3 years and got it to the point where I was happy with it, and haven't done anything new since. Every year I tell myself I am going to drive it more... not going too well so far this year lol. I still have it though!
                        Current:
                        1989 325i
                        1988 M3
                        1987 325ic
                        Past:
                        2001 330ci
                        2001 M3
                        • 2mAn
                          SeƱior Mod
                          • 21017
                          Maybe we can get a COTM on the vert when its done... I think we were going to do one on the 325is but you waited so long that it rusted away LMAO... at least you're back
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          • jhaurimn
                            • Nov 2012
                            • 2224
                            Got the car to the exhaust shop. Pretty much the same setup as my old 325i exhaust had but with slanted tips. It really is harder with an early model to get the muffler looking right. I may end up doing something different down the road but I just wanted to get the car driveable.
                            Unfortunately on the way home...I was having overheating problems. In downtown Minneapolis. At 4PM. Not ideal. The spot I managed to park turned into a tow away zone which I was waiting for the tow truck and a parking lady was about to give me a ticket but thankfully just gave me a warning. Not the greatest of days.
                            And all because of this bastard. After the engine sat dry for a month prior to putting the m52 in the vert, the thermostat would not fully open.
                            Thankfully engine survived and is running great. In the old car I had the aux fan running to a manual switch (fog light switch) in my dash. I noticed low speed wasnt working and high speed would eventually blow fuse 18, so I knew the resistor was bad. I was going to order a new resistor for ~$30 when I realized MTC made a new aux fan with new resistor for about $145. Decided to just replace it all.
                            Its tight but because I no longer have an oil cooler in the way, was able to replace it without taking off the bumper and valance. Nice.
                            I also ordered a 80/88c switch for the m42 radiator so I can have the fan be controlled automatically, should be in soon.
                            Car gets aligned on wednesday and she should be good to go for quite a bit. I am glad to be back in a fast and reliable e30!
                            Current:
                            1989 325i
                            1988 M3
                            1987 325ic
                            Past:
                            2001 330ci
                            2001 M3
                            • jhaurimn
                              • Nov 2012
                              • 2224
                              Video going over the swap as it progressed here https://youtu.be/EeOekwLjyE0
                              Current:
                              1989 325i
                              1988 M3
                              1987 325ic
                              Past:
                              2001 330ci
                              2001 M3
                              • 2.5-12
                                • Jan 2010
                                • 1814
                                engine got a car swap.. for the 5th time
                                1991 E30 M3 Brilliant/black - S54B32/5M
                                1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
                                2011 E82 1M VO/blk/6M
                                1991 E31 850i red/grey/6M
                                1997 F355 spider red/tan/6M
