318is S50 BAR'D and Supercharged
  • Stanley Rockafella
    • Aug 2011
    • 4062
    Originally posted by jinoguy
    After researching several options for head unit I went with the VDO. It's the closest unit that looks era specific besides the CD33 or CD43. Plus you get bluetooth, usb and aux without any modifications.
    BMW crimps and shrink tubes were used.
    Nice choice!
    I have the same deck in my e30.
    Nothing is cooler than having the modern tech of Bluetooth in a car built decades before it was invented!
    For connectors, I used these:
    16 Posi-Twist™ wiring connectors: makes it easy to splice your new car stereo's wiring to the vehicle harness
    Best darn thing I ever purchased!
    No more worrying if you accidentally connected the wrong speaker wiring!
    If you hake a mistake, simply unscrew the tap and re-connect with the right one. Wires are tight and won't come undone easily :D
    • e30sh
      • Apr 2015
      • 618
      Nice work. What did you use for the OBC screen?
      • mike.bmw
        • Dec 2015
        • 1777
        Nice choice with the VDO. I like that unit a lot.
        Do you happen to have part #s for the fog light grommets?
        • jinoguy
          • 183
          For the fog light grommet its called an expanding nut.
          part number: 63 17 1 367 868
          • jinoguy
            • 183
            Replaced the vehicle speed sensor. Had a whining noise from the diff so it was replaced with a 2.93 lsd, z3m cover and fluids. Also replaced the pigtail connector and wires.
            • jinoguy
              • 183
              Suspension set up is the full Turner motorsport J stock.
              Custom valved bilsteins with mono ball mounts
              ST front and rear sway bars
              Reinforcement kit for sway bars welded
              Reinforcement subframe kit welded
              J stock springs
              Treehouse lollipops
              OEM control arms
              • jinoguy
                • 183
                Axles rebuilt. E36 m3 steering rack redone (debating on custom lines or not depending on set up)
                • jinoguy
                  • 183
                  Finishing up on some wiring using all bmw connectors and shrink tubes. Project is going to another level and will post later ;)
                  • Melon
                    • Mar 2018
                    • 1311
                    Looks great man, what's the part No. for those connectors?
                    I do things.
                    • Supadave
                      • 1006
                      AMG Hammer tribute (all metal widebody) 3.6 and only manual transmission in the states
                      Wow, gorgeous Benz
                      https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
                      • 2mAn
                        SeƱior Mod
                        • 21088
                        Ironically, a S50 E30 might be the fastest car in that group of awesome cars haha
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        Make R3V Great Again -2020
                        • jinoguy
                          • 183
                          Thanks. There are multiple part numbers depending on the gauge/thickness of wires you're using. It's in group 61 or 62 if I remember correctly
                          • jinoguy
                            • 183
                            lol! Actually the AMG was comparable to an e30 s50. If you see my early posts I built an e30 s52. The AMG had a 3.6 with 3.25 lsd and manual trans. Had around 290hp and boogied while looking intimidating like a bulldog. :)
                            Porsche 964 was a c4 and was comparable to an e36 m3
                            NSX was still the fastest of all. custom tune, headers, cat delete, full exhaust and short shift. Thing revved up to 8k
                            The e30 S50 is having a huge upgrade soon which WILL be fastest of the group! Will post soon once I get things in order.
                            • jinoguy
                              • 183
                              Well an easy clutch job turned into a full build now lmao! Was in the process of removing the tranny and told myself to do the oil pan which turned into dropping the motor.
                              • jinoguy
                                • 183
                                Now the special part.....Tada! Full Dinan blower set up! Test fit done and getting sent out to vortech for rebuild!
