Sonny's Weak M10 Build
This topic is closed.
  • Melon
    • Mar 2018
    • 1311
    #151
    Originally posted by 2mAn
    words to live by ;)
    I laughed.
    Love you Sonny.
    I do things.
    • Melon
      • Mar 2018
      • 1311
      #152
      Originally posted by Sonny
      Car suddenly started smoking white as soon as I got home at idle. Maybe it was the Carwash going in the muffler and seafoam residue as it coated my trunk and bumper with oil residue also last I ran a can in the vacuum line 2 weeks ago when and the car had sat since with only 30 miles after the seafoam. Hopefully so as I don’t want to find out I have coolant loss, going to wait for her to get cold and start, we’ll see if she smokes or hard to start as that would mean I might have cracked my block on impact.
      All the coolant is in the head and the top part of the block around the cylinder sleeves. Also, your motor mounts would insulate it from impact.
      Check all the hose clamps, give them a turn. Also, squeeze the hoses, there's only a few of them. If it persists rent a pressure tool from AutoZone and do a leak test. Basically you pump pressure in the system with an air pump, then look for leaks.
      My money is on a bad hose, or water pump.
      I do things.
      • Sonny
        • Feb 2019
        • 100
        #153
        the side that took the impact has a lot of toe.
        I threaded both tie rods to 10 open threads showing. Steering wheel has to be held turned to passenger side.
        Driver side was the side that dropped
        • Sonny
          • Feb 2019
          • 100
          #154
          It’s stopped doing it boss. Do you think a bad hose or water pump could make steam come out the exhaust?
          • Melon
            • Mar 2018
            • 1311
            #155
            It's out the exhaust? I wouldn't worry about that, that's just condensation.
            I do things.
            • Melon
              • Mar 2018
              • 1311
              #156
              Also, get and alignment.
              I do things.
              • Sonny
                • Feb 2019
                • 100
                #157
                Redoing my inner tie rods already have new locking plates, probably not tight enough. Brought some wheel weights to add the ones chipped off.
                • Sonny
                  • Feb 2019
                  • 100
                  #158
                  • Sonny
                    • Feb 2019
                    • 100
                    #159
                    Can anyone help me out? I want to get new tires/ alignment. But I absolutely don’t want any of the workers driving it? Is it okay to ask them not to. I know it’s a old m10, but I care for it and don’t want a teenager ripping my gears .
                    • glnr13
                      • 1334
                      #160
                      up the ramps, down the ramps. where else are they going to go beyond 5mph?
                      • Sonny
                        • Feb 2019
                        • 100
                        #161
                        They drive it around the block to test everything.
                        • DaWildBeast
                          • Mar 2016
                          • 244
                          #162
                          Never heard of that tbh, an alignment doesn’t take long you can literally sit in the waiting room.
                          • Sonny
                            • Feb 2019
                            • 100
                            #163
                            Maybe it’s just the place I go to, any chain retailers that don’t do this that you recommend? Les Schwab maybe but I feel there to cheap.
                            • DaWildBeast
                              • Mar 2016
                              • 244
                              #164
                              Les Schwab does it I think it’s around $100 or less. They also give you a print out of the specs for the alignment when it’s finished.
                              • Melon
                                • Mar 2018
                                • 1311
                                #165
                                99.99% Of teenagers can't drive a manual anyway.
                                I do things.
