Sonny's Weak M10 Build
This topic is closed.
  • AudioNToxication
    • Nov 2013
    • 117
    #166
    this thread delivers.
    where the hell are you that you are near a les schwab.
    try bymar tire in mission viejo if you really are in newport.
    • glnr13
      • 1334
      #167
      Originally posted by Sonny
      They drive it around the block to test everything.
      i've had dozens of alignments in the last 20+ years of car ownership and really good shops do test drives after. basic shops give you a printout and get you out of there asap. if you're into that type of alignment (which your car isn't ready for imo. think coilovers, corner balanced, track prep, etc) go to Bullet performance, they love e30s and will take care of you plus they're not far from you, costa mesa. i'm sure they'll do a basic alignment for you as well.
      • Sonny
        • Feb 2019
        • 100
        #168
        does this look bad?
        Did my best by hand
        • Javier h
          • Sep 2007
          • 1189
          #169
          Exactly
          They normally test drive it afterwards. Do not let them go got a test drive BEFORE do the alignment. I had this one shop disappear on me for 20 minutes.....some BS rule they needed to feel the car.
          • Sonny
            • Feb 2019
            • 100
            #170
            What exactly do i say to the shop ?
            • 2mAn
              Señior Mod
              • 21017
              #171
              Thats weird that the paint flaked off the fender so easily. Is it the original fender?
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              Make R3V Great Again -2020
              • Sonny
                • Feb 2019
                • 100
                #172
                It’s all metal it seems to be original , somehow paint seems like it was double layered at roof what do you think?
                • Javier h
                  • Sep 2007
                  • 1189
                  #173
                  Shop
                  I would simply ask them if they will test drive the car BEFORE they do the alignment when you call for an appointment (or check on their prices). If they say yes, go elsewhere. Most shops wont test drive the car before the alignment. It was clear to me, the tech that disappeared was out for a joy ride.
                  • Sonny
                    • Feb 2019
                    • 100
                    #174
                    All old rusted bumper screws replaced. Did not know stainless existed. Will redo all bolts tommorow, spent $2
                    • 2mAn
                      Señior Mod
                      • 21017
                      #175
                      Stainless isn’t as strong as the OEM bolts. I made the same mistake with my Roadster. Make sure you get the similar grade hardware. Evaporust will help the stock hardware too
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      • Sonny
                        • Feb 2019
                        • 100
                        #176
                        Wow, your fucking awesome. Thanks!
                        • Sonny
                          • Feb 2019
                          • 100
                          #177
                          Will going out to get a can of Liquid Film help to protect this ?
                          • Melon
                            • Mar 2018
                            • 1311
                            #178
                            You want to be careful to not use something that will react with the existing rubber coating on the car, that happened to me and isn't fun. I'd leave it alone if there is no rust, or epoxy primer over it, and apply a rubberized coating of your choice.
                            I do things.
                            • Sonny
                              • Feb 2019
                              • 100
                              #179
                              Yes your correct it had made my door gasket swell and pop out, did not know this.
                              Is Permatex Silver safe to use ?
                              Or I’ll just use epoxy primer and shut up, thanks!
                              • Melon
                                • Mar 2018
                                • 1311
                                #180
                                SprayMax 2K Activated EPOXY Primer Black 3680034 https://www.amazon.com/dp/B07CXPQ814..._a.Y6CbE9WJSJC
                                3M 03584 Professional Grade Rubberized Undercoating - 16 oz. https://www.amazon.com/dp/B002H9CMCQ..._2.Y6CbD8EF9CJ
                                I do things.
