Sonny's Weak M10 Build
This topic is closed.
  • Sonny
    • Feb 2019
    • 100
    #61
    Trying to find more things to replace and add on to my list
    • Sonny
      • Feb 2019
      • 100
      #62
      So far the fun is just starting.
      Have a pile of parts and couple cans of Pringles at home that Blunt keeps shipping out.
      • glnr13
        • 1334
        #63
        The chain tensioner is easy it's the chain guide that is daunting.
        • Sonny
          • Feb 2019
          • 100
          #64
          I was planning to remove the timing cover in order to bleed it does that need to be done for a new tensioner? Thanks!
          Edit: my chain guides are like new when I did my valve adjustment.
          • glnr13
            • 1334
            #65
            No need to remove the cover for the tensioner spring. What are you bleeding?
            • Sonny
              • Feb 2019
              • 100
              #66
              https://youtu.be/9lEkuaHE_Hw
              Am I getting the wrong idea? Is it simply unscrew old and screw in new tensioner?
              • glnr13
                • 1334
                #67
                I forgot about that step. I think you can do that bleed/burp with just the valve cover off. Not 100% positive since I haven't wrenched on an m10 in a while.
                • Sonny
                  • Feb 2019
                  • 100
                  #68
                  Ok sounds possible, i'll look into the Bentley to thanks !
                  • Sonny
                    • Feb 2019
                    • 100
                    #69
                    Oil changed, i put almost 4.5 quarts a month ago now she's at 3. Oil seems darker, I'll change in a month and see what happens. Exactly 4.5 quarts and stp oil treatment.
                    • Sonny
                      • Feb 2019
                      • 100
                      #70
                      Mityvac 7201 Fluid Evacuator Plus https://www.amazon.com/dp/B0002SR7TC..._qZ9PCbSBZ1N8A
                      Stick it through oil dipstick tube. Changed oil 5 mins. Do it when oil is warm, not hot, so it's faster
                      • Sonny
                        • Feb 2019
                        • 100
                        #71
                        It's a beauty!
                        • Sonny
                          • Feb 2019
                          • 100
                          #72
                          Going to wrap the fuel hoses and radiator hoses with the heat tape instead, seems more reasonable. Time to disconnect the lines this time properly.
                          • Sonny
                            • Feb 2019
                            • 100
                            #73
                            Gold tape was all a lie $30 wasted when I could have done another oil change
                            • Motheye99
                              • May 2018
                              • 853
                              #74
                              Your car doesn't make enough heat to bother radiator hoses, or anything in the car for that matter. It went 35 years with out it
                              91' 318is 90' 325is
                              Buy the E30s, they ain't gonna last long
                              E30 can make you, E30 can break you
                              "He who controls the Nova's, controls the Boomers"
                              • Sonny
                                • Feb 2019
                                • 100
                                #75
                                Spot-on you are right thanks!
