Sonny's Weak M10 Build
This topic is closed.
  • Sonny
    • Feb 2019
    • 100
    #91
    Can’t get the right control arm disconnected. Hand hits the exhaust. Very frustrated as I can’t seem to get the nut turned
    • Sonny
      • Feb 2019
      • 100
      #92
      Got it under control!
      • 2mAn
        Señior Mod
        • 21017
        #93
        so you got the old control arm out... what are you installing for CABs? should have this done by now
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • Sonny
          • Feb 2019
          • 100
          #94
          I will get it all done tonight finally :) tie rods, and the CA
          • lukeADE335i
            • Apr 2013
            • 1389
            #95
            Hope it all goes back together ok. You'll definitely need a wheel alignment after fitting all that.
            Have to admit I still have a soft spot for the M10 - have owned two over the years, an M10 powered e21 that was great with 130hp, and then a carby fed e30 316. The engines are pretty bullet proof providing you don't overheat them.
            My e30: OEM+ with M30B35
            • Sonny
              • Feb 2019
              • 100
              #96
              Having issues with tie rods and the bendable tabs holding them in, cold chisel tommorow morning lets see what happens.
              Can shocks get damaged by staying extended?
              Originally posted by flyboyx
              Knowledge is knowing a tomato is a fruit. Wisdom is not putting it in a fruit salad.!
              • 2mAn
                Señior Mod
                • 21017
                #97
                This is the lifesaver. Go buy it.
                Are you boots destroyed? Or is there another reason you’re changing the tie-rods?
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • Sonny
                  • Feb 2019
                  • 100
                  #98
                  The tie rods hold no tension or resistance and drop straight down Plus they came with that OEM suspension refresh kit
                  • Powling
                    • Jan 2015
                    • 1291
                    #99
                    Originally posted by Sonny
                    Sorry I was just wondering if anyone had an opinion if it adds real caster or if it’s not noticeable and to what degree I’m currently at 3.5
                    Stock m3 is +7.5
                    Am I an idiot for passing perfectly good centered web bushings?
                    ^^^ Forwarded from the Nonsense thread for you.
                    Steve • Toronto
                    1991 318is • Brillantrot
                    Build Thread
                    • Sonny
                      • Feb 2019
                      • 100
                      #100
                      • Powling
                        • Jan 2015
                        • 1291
                        #101
                        Holy shit I just looked at my cat and it’s been installed in reverse since I’ve had it.
                        Forwarded from the Nonsense thread to where it belongs.
                        Steve • Toronto
                        Build Thread
                        • Melon
                          • Mar 2018
                          • 1311
                          #102
                          Engine work takes patience and finesse.
                          Suspension work takes anger, a big fucking hammer, and a torch.
                          I do things.
                          • Sonny
                            • Feb 2019
                            • 100
                            #103
                            Not really something that was specifically part of my build lol, it’s fixed already
                            • 2mAn
                              Señior Mod
                              • 21017
                              #104
                              so true!
                              If you're not cursing, something is wrong
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              • Powling
                                • Jan 2015
                                • 1291
                                #105
                                Its more relevant here than in the nonsense thread.
                                Steve • Toronto
                                Build Thread
