project 318i
  • patrick.s
    • Mar 2004
    • 45
    project 318i
    ok, here we go:
    i have been driving e30s for ten years or so, ad of course started modding them too. but after some time i realized that you cant make a car that is loaded with ice, have loads of power, is incedible fast in corners and a daily driven on bad roads. as my last cars body started to give up after firm suspension, 300kg ice and 230hp engine i decided that the time has come to buy a really good chassis, to swap all parts and sell the old car. and then things got crazy :mrgreen:
    my old car looked like that:
    lately i was giving it technical attention so never had time to deal with cosmetics
    now this is my next project: 318i ยด88
    some stripping is done:
    to improve weight distribution engine and gearbox will be moved about 25cm back. of course all parts have to be moved backwards too
    for first i thought i would use its own floor but that would have been more difficult than making new one
    to not get bored i decided to work on other parts too beside body. here you see front suspension components: alu control arms, equipped with m3 3,2 rear bushings turned 90degrees, modified steering rack and othed details
    well this is a dogleg sport gearbox used on euro m3 e30 and on m535i
    these are shift linkage bushings on needle bearings, they will never wear out and make shifting sloppy
    oil pump thoroughly checked and cleaned
    25mm master cylinder
    rebuilt starter
    this is cylinder head fron m54 3,0l. it has conical valve springs to have lighter valvetrain
    i got m54 without intake, wiring, ecu or anything, i throwed out cams, because in m54 they are infinitely variable ( double vanos), put in 525 m50 95y cams and vanos, ecu, intake etc, and bolted on remus headers and custom made exhaust. but as engine consumed serious amount of oil 1l- 1000km i had to rebuild it ( doing it now) idiots who sold me this engine had left it outside for several months and this screwed up cylinder walls. its very sad that you have to rebuild engine that has just about ten thousand miles on clock
    pistons are ok, only need oversized rings
    these sprinklers are mounted near the crankshaft facing up to cool pistons from beneath
    old suspension components
    roll cage arrived!
    fabricating floor
    front and rear strut tower modifications, will move rear springs on shocks
    mating gearbox to engine
  • kencopperwheat
    King of Kegstands
    • 14396
    Originally posted by Gruelius
    • AndrewBird
      The Mad Scientist
      • 11898
      And why are you cutting large holes out of your floor? Trying to go CSL style and replace it with carboard? lol
      Andrew
      • spencers
        • Jan 2004
        • 1150
        Yowza! :P
        • James Crivellone
          Head Janitor
          • 6305
          ok, sooo what is happening?
          • Jand3rson
            • 37587
            I'm not so sure that he knows... :D
            • patrick.s
              • Mar 2004
              • 45
              new suspension components fabricated
              will use adjustable shocks
              Estonian winters and H&R springs dont match, they will get my attention later. also will gather up all components which need coating( zinc, anodize, powder coating) and do them all together
              sachs sporting clutch :bow:
              closeup
              fuel system will be totally different from what bmw came up, will use at least two fuel pumps- one to fill small tank and other to feed the beast from that tank. this is brand new bosch fuel pump worth about 300$, got it for 15$ and only had to open it up and remove debry
              • Jordan
                • 12916
                Ohhhhh it's a e30 themed Erector set!!! SWEET!!! hahaha.
                I can see what you are doing, but the more important question is why?
                https://mtechniqueabs.com/
                • Super Eta
                  • 1884
                  I dont get it, what are you doing to the car.
                  Why are you cutting out the floorboard and firewall and replacing it with rolls bars?
                  • patrick.s
                    • Mar 2004
                    • 45
                    will post comments later :mrgreen:
                    • Super Eta
                      • 1884
                      Yea i think you should.
                      • M3 Ryan
                        Site Sponsor
                        • 2298
                        nice undertaking!!
                        some cool parts that should make for a badass car...
                        is that an aluminum block M50?
                        '88 M3.2 S54 Lachssilber/Black
                        '07 335i Alpine/Black Sedan
                        '12 X5 3.5i Alpine/Black
                        iS Splitters For Sale, PM ME!
                        • patrick.s
                          • Mar 2004
                          • 45
                          m54 from x5
                          • Spaz
                            Crazy Canuck
                            • 2276
                            well to clear it up for most people.
                            well as you see he is cutting out the all of the lower body, mounting a full blown cage, tubbing the whole car, modified firewall and trans tunnel, to fit some big ass custom drivetrain, modified rear strut towers with some nice reinfrocements....i could go on but i don;t want to spoile this project for the rest of you.
                            looks great nice progress so far keep the pictures coming.
                            Cam .W '91 325is
                            Spaz's 1991 Alpine White???? S52 Build Thread...
                            • patrick.s
                              • Mar 2004
                              • 45
                              comments added
