Uber hot :twisted:
project 318i
Last edited by ///M42 sport; 04-30-2011, 04:43 PM.Renting my rear wheel bearing tool kit. SIR
For everyone who doesn't know what's going on, here's a clue:
This is what's called "doing it right the first time". Stripping it all down and modifing it to a truely unique spec. I mean, moving the engine / tranny back, new rear mounts, the reenforcement, etc. This is some mad awesome work. I wish I had a garage to start a project like this with my e30...
I tip my hat to you sir. Truely amazing!
-Prince
You're using an M54 head and block. Awesome. However, I'm just confirming that this too is an Al block, yes?
What are you going to run in terms of engine management? You going to have both VANOS units on that block or just intake or ripping them all out? Thanks!
plans are that i will turbocharge this engine. will use m50 exhaust cam and m54 intake cam( more degree on exh and less on int and more lift on int) i dont know yet what management i will use ( i am interested in this: www.sdsefi.com ) also i never had any experience with turbos so i am studying this subject, not many info out there :(
as i an on extreme tight budget i will consider reusing m50 management with some adjustments, bigger injectors, bigger airflow sensor body, etc
and yes its alu block with inserts
Originally posted by patrick.sYou're using an M54 head and block. Awesome. However, I'm just confirming that this too is an Al block, yes?
This just goes to show that there are other options for Al block engines. The bore is the same as well so assuming the S52B32US crank will fit, It looks like 3.1L is possible as well. This is great news for a lot of people.
-Prince
