The Official List-Your-Mods Thread
  • trent
    1984 BMW 318
    Exterior:
    HennaRot
    Late model plastic bumpers
    Late metal rear valence
    "iS" Front lip
    "iS" Sport sideskirts
    Reiger lip for track use
    ACS CF Replica Mirrors
    Gustave Hood Vent
    Zender wing with CF flapper
    Interior:
    Black Sport seats, alcantera inserts
    Sparco 6 point harness
    Autopower roll bar (custom cage soon)
    Coach Signiture Boot set
    VDO Switchable Transmission / Differential Oil Temperature Gauge
    Suspension:
    Shortened and knuckle reinforced strut housing
    Custom Valved Bilstein non-BMW strut short insert
    Custom coilover hardware
    IE "Race" Camber plates, custom bearing'd / shimmed
    Eibach 2.5 Springs
    TreeHouse CABs
    Racing Dynamics Sway Bars
    Bilstein aluminum threaded body custom valved coilover race shock
    Custom 2.25 inch coilover spring hardware
    Eibach 2.25 Springs
    Custom Rear shock mounts
    AKG Poly Subframe bushings (in progress)
    AKG Poly Trailing arm bushing setup (in progress)
    Delrin diff mount (in progress)
    Drivetrain:
    USM52b28 bottom end
    USM52b32 cylinder head
    RaceWare Head Stud Kit
    Pauter Machine dual valve spring setup
    OBDII M3 Camshafts
    OBD1 Conversion
    Getrag 265
    JB Racing Flywheel
    E30 Sachs Sport Clutch
    X5 3.0 Shifter
    Custom Borla Exhaust
    Custom built 75% lock 4.10
    Thanks to: (no particular order)
    Sean @ Autobahnparts.com (used parts body & engine)
    Brian Pauter @ Pauter Rods (parts development)
    Jason Hughes @ Differential Service (diff build)
    Charles Rodgers @ Pro Gear (lathe service)
    Brenda @ Jim's Auto Upholstery
    Rob @ CarArtUnlimited.com
    Jack @ Bilstein.com (suspension help & setup)
    Dan @ BavarianAutosport.com (parts advise)
    • uofom3
      • Jan 2004
      • 5392
      Specs:
      Model: 1990 e30 m3
      Exterior: Zinno
      Interior: Black Leather
      Factory Options: no clue
      Exterior Cosmetic:
      oe Sport evo front splitter w/undertray
      oe sport evo rear wing
      Grp A CF mirrors
      Euro smiley ellips
      sport evo grills
      sport evo hood seals
      sport evo bumper seals
      sport evo brake ducts
      sport evo tow hook covers
      sport evo undertray
      CF hood
      Interior Cosmetic:
      SRD seats
      2 spa digital guages
      mtech 2 steering wheel
      mcoupe floor mats
      sport evo seat belts
      factor e30 illuminated shift knob
      leather ebrake book
      leather e36 ebrake knob
      speedware harness bar
      sparco harness
      motorsport limited edition dash plaque
      Suspension:
      Koni Adjustables
      HnR GrpG race springs
      aluminum control arms
      treehouse bushings
      f/r strut bars
      gc rear shock mounts
      Drivetrain:
      2.5 liter s14 w/:
      sport evo crank
      lightened rods
      wiseco 11.25:1 pistons
      total seal rings
      raceware head studs (i think?? can't remember)
      bosch big green injectors
      Iigomotive header studs
      all new hoses/seals
      Iigomotive chip
      CF box
      MAxx a/n
      schrick 284/276 cams
      SRD7 valve springs
      LWT flywheel
      z3 1.9 short shift
      don fields ported head stage 2.5
      grp a gasket set
      TMS oil pan baffle
      electric fan added
      GSP wires
      the list goes on, I can't remember it all....
      Exhaust:
      Borla rear muffler
      SS straight piped center section
      Fluids:
      All red line
      Wheels/Tires:
      sport evo factory wheels
      kumho 712's
      Brakes:
      Sport evo rotors f/r
      pagid pads
      ATE blue fluid
      SS brake lines
      25mm MC (in progress)
      Sound:
      Eclipse head unit
      stock everything else
      there's more but i can't remember... had the car almost six years
      PNW Crew
      90 m3
      06 m5
        • 34827
        Model: 1991 325ix 4 door auto (10/1990)
        Color: SterlingSilver metallic
        Interior: worn out M3 sport seats in black leather
        Transmission: 4 speed Automatic ;)
        Exterior:
        - Mashaw CF hood (10lbs)
        - Eurostyle Mtech 2 rear apron
        - Eurostyle Rieger Infinity I lip
        - Hella smoked ellipsoids
        - smoked kidneys
        - Euro grilles
        - Euro plate filler
        - Shadowline
        - Lamin-x'd turn signals
        - Euro bumper trim (eventually)
        Suspension:
        - H&R sport springs
        - Koni SA struts/shocks
        - Polyurethane diff, subframe & trailing arm bushings
        - M3 offset control arm bushings
        - 15x7 Euro weaves
        - Wiechers Sport front strut brace
        - Eric Lucas rear strut brace
        - Modified strut bearings -3.5deg.
        - Adjustable swaybar links
        - IE rear camber/toe adjustments (eventually)
        - E46 M3 rear shock mounts
        Engine:
        - 2823cc stroker with 10:1 comp
        - MM forged pistons, S50 rods
        - 86mm bore, 81mm stroke
        - Shrick 284/272 camshaft
        - Ported & polished head
        - Bavauto performance chip
        - 19# injectors
        - IE shorty headers
        - Supersprint catback exhaust
        - IE Adjustable FPR
        - clutch fan delete
        - flexalite S-blade 2010CFM electric fan conversion
        w/ E36 M42 temp switch
        Driveline:
        - ATE powerdisk rotors
        - ATE SuperBlue fluid, SS lines
        - Redline synthetic fluids
        - 5 Speed swap
        - ligthened flywheel (~15lbs)
        - sachs sport clutch & HD pressure plate
        - Z3 1.9 ssk
        - urethane filled tranny mount
        - UUC shifter carrier bushing
        - UUC DSSR (working on this one)
        Interior:
        - E30 M3 sport seats, mtech badges
        - Leather shift & ebrake boots
        - Brushed aluminum ebrake & shifter
        - Painted needles, trim rings
        - Parker Performance gauge pod
        w/ VDO oil temp, pressure and volt gauges
        - Mtech 2 steering wheel w/ mtech stiching
        next up: motronic 1.3 delete mod :p
        • backtrail69
          • Jul 2005
          • 4471
          My favorite. :)
          :: PNW Crew ::
          '87 325 4dr, '74 2002
          • rs4pro3
            • 5808
            Specs:
            Model: 1985 325e
            Exterior: Alpine White
            Interior: Burgundy leather
            Factory Options: Front spoiler, sports interior
            Cosmetic:
            Pfeba Front lip spoiler
            M-technic 1 rear trunk spoiler
            Euro front bumper
            Tucked rear bumper
            Euro h1 headlights
            Euro headlight wipers
            Sport model body colored mirrors
            Shadow-line trim
            Euro headlight grills
            Suspension:
            Custom coilovers
            350lb front springs 450 lb rears
            custom caster adjustable Control arm bearings
            Ireland race camber plates
            Ireland Urethane subframe mounts
            Ireland Urethane trailing arm bushings
            AKG delrin differential mount
            Bilstein sports
            Turner Urethane rear shock mounts
            Sparco front strut tower brace
            Lukas rear strut tower brace
            21mm cabby front sway bar
            14.5mm m3 rear sway bar
            custom m3 adjustable m3 front sway links
            custom adjustable rear sway links
            custom front undercarriage x-brace
            Drivetrain:
            87 325e driveshaft with larger guibo
            limited slip 4.10 differential
            UUC stainless clutch line
            M-coupe shift lever
            Weighted e46 shift knob
            Rebuilt and stiffened shifter console
            2.7i stroker motor
            Cold air intake
            Megasquirt V3.0 full spark and fuel control
            High power ignition coil
            Exhaust:
            Stainless steel shorty headers
            Ireland stainless cat back
            Wheels/Tires:
            Track
            15X7 Zender challenge ET10
            Toyo RA-1225/50/R15 r-compound tires
            Street
            15X7 Team dynamics pro race 1 Et 35
            Khumo Excta 711 205/50/R15 tires
            Sound:
            Inline 6 BMW engine
            Interior
            Rear seat deleat
            Kirk Bolt in 4-point roll bar
            G-force 6-point harnesses
            Recaro SRD custom modified driver’s seat
            Sound deadening removal
            Custom lightweight carpet
            3-panel wink rear view mirror
            fire extingusher
            Momo hub adapter
            NRG quick release steering wheel adapter
            6-bolt racing steering wheel
            85 325e 2.7 ITB'd stroker
            • e30sd
              Fistee
              • Jan 2004
              • 5517
              1991 318is. got some 5 lug shit out back, coilovers and dubs in the storage closet. yeaaaaaaaaaah
              future mods: looking to buy late model e38 regular wheel base or late e39 m5.
              • Jand3rson
                • 37587
                Model: 01/1986 325es 5 speed
                Color: 086 Schwarz
                Exterior:
                - Conversion to late model plastic bumpers
                - Late model front valence and custom fit rear valence
                - Eurostyle Reiger Infinity front lip spoiler
                - Lip splitter
                - Euro grills
                - Smoked turn signals
                - Ellipsoid headlights
                - All-red taillights
                - Body color matched side mirrors and door handles
                Suspension:
                - Ireland Engineering Stage III Race springs
                - Lemforder M3 offset control arm bushings
                - Bimmerworld Lifetime rear shock mounts
                Engine:
                - Jim Conforti ECU chip
                - K&N panel filter
                - Magnaflow exhaust w/ 2.25" dual round tips
                Driveline:
                - 16" x 7.5" Borbet Type E wheels
                - 205/50/16 Bridgestone Potenza S03 Pole Position tires
                - 8mm H&R spacers
                - ATE Powerslot front rotors
                - Brembo OE rear rotors
                - Vorshlag stud kit
                - Ireland Engineering stainless steel brake lines
                - Hawk HPS Street brake pads
                - Z3 1.9 short shift kit
                Interior:
                - Black leather sport seats / tan leather rear seat
                - Leather shift & ebrake boots with ///M stitching
                - Momo short anatomic shift knob
                - E36 M3 leather ebrake handle
                - E36 power window switches
                - Red painted needles
                - Faux AC Schnitzer pedals and dead pedal
                - Euro 316i HVAC panel with no OBC
                - Euro overhead check panel
                - M-Tech II steering wheel
                • 4ce30
                  • Feb 2006
                  • 2762
                  1990 325is Brillantrot
                  Engine/Performance:
                  -AC Shneitzer 7k chip
                  -#19 Ford motorsport injectors
                  -Full Tubular Exhaust w/ resonator to Bavarian Tri-Flow catback
                  -M30 027 AFM
                  -K&N + heatshield
                  -Deleted AC
                  -Painted intake manifold(gloss black)
                  -Painted valve cover(gloss black)
                  Drivetrain:
                  -Rebuilt 3.73 LSD
                  -Bavarian short throw kit
                  Suspension:
                  -Ireland Engineering stage III springs
                  -Bilstein sport shocks
                  -Sparco strut bar Front
                  Wheels:
                  Keskin KT-1 classics(staggard)
                  -16x7.5 et35
                  -16x9 et25
                  -Hubcentric 10mm spacers Front
                  -Hubcentric rings Rear
                  Tires:
                  Falken Ziex 512's -90%+ tread-
                  -215/40/16 Front
                  -225/40/16 Rear
                  Stereo:
                  -Alpine 9811 headunit w/ controller
                  -Replaced all speakers with top of the line Pioneer
                  -12in. Memphis MOJO sub
                  -Volfenhag 600w amp
                  -Interior:
                  -Momo millenium wheel
                  -3 Fuzzy’s
                  Exterior:
                  -European MHW all red tails
                  -European rear plate filler
                  -European grills
                  -Hella ellipsed headlights
                  -Hella ellipsed foglights
                  -Ryan G splitter
                  -Smoked Turn signals
                  -Black air ducts
                  -Black IS lip
                  -Lamin-X Headlight + Fog light covers
                  Lighting:
                  -Silverstar high beam bulbs
                  -Silverstar low beam bulbs
                  -Brandon
                  • Jparkr
                    HR Admin
                    • Jan 2006
                    • 3494
                    as of june 9th 2007 :-)
                    Model: 02/1990 325is 5 speed
                    Color: #08 Brillantront
                    Exterior:
                    - New american trim fnt. Euro trim rear.
                    - New fogs
                    - iS lip W/ Ryan G splitter
                    - Eyebrows
                    - Smiley headlights
                    - M3 replica wing
                    Suspension:
                    - Bilstein suspention kit W/ H&R springs
                    Engine:
                    - Jebring Headers
                    - deleted catalitic converter
                    - IE Catback muffler
                    - Deleted A/c
                    - Deleted Power steering
                    - Swissed airbox
                    Driveline:
                    - 00 Mcoupe shift lever
                    - James Criv Aluminum Shift bushing
                    - deleted harmonic balancer
                    - SS brake lines
                    - ATE super blue brake fluid
                    - 3.73 LSD
                    Wheels:
                    - Ronal LV's
                    - Toyo RA-1s
                    Interior:
                    - E36 M3 Black leather sport seats (non vader)
                    - M3 shift knob
                    - E36 M3 leather Ebrake handle
                    - E36 power window switches and sunroof switch
                    - deleted OBC
                    - Deleted SRS
                    - Deleted cruse control
                    - Welded in Autopower street bar
                    - Narcadi Blackline Steering wheel
                    Im sure i missed stuff
                    1987 PRO-3 car /1990 325is (2.7i Concours)
                    • Mtriple
                      • 3139
                      Model: 1989 325is Coupe
                      Color: Alpine White
                      Transmission: 5 speed
                      Exterior:
                      -Euro smiley's (clear)
                      -4500k HID
                      -MHW smoked turn signals
                      -MHW Red tails
                      -Euro fog using all factory parts
                      -Euro bumper trim
                      -Euro plate filler
                      -Euro grilles
                      -OEM skidplate
                      -Ryan G splitter
                      -Lamin-X (headlights and fogs)
                      -DTM non-vented CF mirrors
                      -M-tech 1 wing
                      -M3 hood seals
                      -M3 bumper seals
                      -IS sideskirts
                      -Zender M3 style wing with Gurney flap (not installed)
                      Interior:
                      M-tech 2 wheel
                      M-tech Illuminated shift knob
                      M-tech sill strips
                      Redline Leather shift and e-brake boots
                      E34 leather e-brake handle
                      M3 cluster
                      Rear headrests
                      Rear fold down armrest/skipass
                      UUC carbon fiber pedals
                      Euro check panel
                      GG dimming module
                      Husco Armrest
                      Analog clock
                      VDO Boost, Oil pressure, EGT, Water temp, gauges
                      Innovate Wideband
                      Engine:
                      TCD Stage 2 turbo with water to air intercooler
                      TCD clutch
                      TCD Exhaust
                      MLS headgasket
                      Raceware studs
                      Snow Performance Stage 2 Methanol injection
                      M3 harness covers
                      M30 AFM
                      IE 8mm wires
                      MSD coil
                      Mocal oil cooler
                      Bimmerworld Hoses
                      Spal Fan
                      Driveline:
                      E30 M3 Calipers f+r
                      Brembo cross drilled rotors
                      Axxis Ultimate pads
                      ATE Super Blue fluid
                      Turner SS lines
                      Turner caliper guide bushings
                      UUC Evo3 SSK
                      M-Coupe finned diff cover
                      IE Motor mounts
                      IE tranny mounts
                      3.73 lsd
                      2.93 lsd
                      Suspension:
                      E30 M3 5-lug conversion
                      E30 M3 Aluminum control arms
                      Shortened and reinforced front strut housings
                      Koni SA's
                      Ground Control Coilovers (450/650)
                      Ground Control Camber Plates
                      Ground Control swaybar links
                      Ground Control RSM's
                      Suspension Technique sway bars
                      IE Rear sway bar reinforcement
                      Turner Rear sway bar tab reinforcements
                      Sparco front strut bar
                      Beertech rear strut bar
                      Powerflex offset LCAB's
                      Powerflex RTAB's
                      Powerflex subframe bushings
                      E36 M-Contours 17x7.5/8.5
                      E38 Style 5 16x8's
                      Forged M-systems 17x8 with turbine's
                      BBS RS061 16x8's
                      Vorshlag studs and spacers
                      E36 M3 steering rack
                      Audio:
                      Alpine 9887 w/Ipod interface
                      Precision Power A404.2 amplifier
                      ADS 320is seperates
                      (1) JL Audio 10W1
                      Alpine SEC-150R alarm
                      Originally posted by Simon S
                      • 325is///M-tech
                        • Jun 2006
                        • 77
                        -1987 325is
                        -Delphin grey
                        Interior & Safety
                        Sparco 375 350mm steering wheel
                        -Momo wheel hub adapter
                        -UUC pedals
                        -///M dead pedal
                        -///M shift knob
                        -Bride adjustable race seat
                        -Sparco harnesses
                        -VSR bolt in roll bar
                        -Speedware fire extinguisher
                        -IO Port camera mount
                        -BMW maplight mirror
                        -Alpine head unit
                        -Bostan Accustic front speakers
                        -ADS plate rear speakers
                        -Stage 1 weight reduction (via blown heatercore)
                        Exterior
                        -BMW early front spoiler
                        -BMW M-tech 1 rear spoiler
                        -BMW euro grills
                        -Bosch ellipsoid headlights
                        -Stonguard for lows and fogs
                        -Laminx yellow film for highs
                        -Prolummen 6000k HIDs
                        -Abrams Motor Sports smoked front turns
                        Drivetrain
                        -M20B25
                        -Dinan chip
                        -Dinan custom intake
                        -Top Speed longtube headers
                        -Magnaflow custom Exht.
                        -Sachs clutch
                        -BMW E30 ///M3 S4:10 diff
                        -BMW ///M coupe/roadster finned diff cover
                        -UUC evo 3 short shift kit
                        -Turner Motor Sports reinforced motor mounts
                        -UUC TME trans mounts (black)
                        -Redline Fluids in trans and diff
                        Brakes
                        Ate cryo treated rotors
                        -Stoptech stainless steel brake lines
                        -Motul RBF 600 brakefluid
                        -Carbotech XP-10 brakepads
                        Suspension
                        Ground Control coilovers
                        -Eibach ERS springs 375lb front/ 475lb rear
                        -Koni Sa shock / Struts
                        -Ground Control rear shock mounts
                        -Ground Control camber/caster plates
                        -Treehouse Racing control arm eyeballs
                        -BMW E30 ///M3 front swaybar
                        -BMW E30 325ic rear swaybar
                        -Powerflex poly subframe bushings
                        -Ireland Engineering poly trailing arm bushings
                        -Sparco front strut bar
                        -Turnermotorsports wheel stud kit
                        Wheels / Tires
                        -SSR comp wheels 16 x 7 1/2
                        -Falken rt-615 tires 225 / 45 - 16
                        ///PNW E30 Crew
                        Bryce
                        '87 325is.....Pro3?....One day!
                        '91 318is Daily drive with a bit of attitude
                        • M42Technik
                          • 9781
                          Can we sticky this in Member's Rides as a mod-list thread?
                          And get rid of that stupid LTW flag stickied post?!
                          Reminiscing...
                          • fretburnr
                            • Jan 2005
                            • 1496
                            1990 325i / brilliantrot / 5sp
                            220k
                            Engine/Driveline:
                            -K&N conefilter
                            -M30 AFM
                            -19# injectors
                            -Mark D'Sylva software (for the injectors/AFM)
                            -IE sparkwires
                            -MSD b2 coil
                            -Custom 2.5" + magnaflow exhaust
                            -OE Sachs clutch kit
                            -Custom e36 short shift lever, delrin bushings
                            -OE driveshaft
                            -S3.73
                            -Redline gear oils
                            Suspension/Brakes:
                            -H&R Cup Kit, with h&r sport springs in the rear
                            -ST swaybars
                            -OE control arms / balljoints / tierods / etc
                            -Sparco strut brace
                            -Axxis Ultimate ceramic pads
                            -ATE super blue brake fluid
                            -16x7 ASA JS1 // 215/45-16 Hankook RS2
                            -14x6 'caps // 185-65-14 Dunlop Wintersport M3
                            Lighting/Electronics:
                            -Bosch euro ellipsoids / osram silverstars
                            -Clarion DXZ745MP
                            -Alpine TypeS 5.25" coaxes
                            -Alpine amp
                            -12" Rockford XLC
                            -VDO gauges in ashtray pod - oiltemp, oilpress, volts
                            Cosmetics/Interior:
                            -Shadowlined trim
                            -MHW smoked signals
                            -Euro plate filler
                            -Black brakeducts
                            -iS decklid spoiler - non painted
                            -iS front lip
                            -Ryan G splitter
                            -330i ZHP shift knob
                            -Recaro Sport driver's seat
                            -iS passenger seat
                            -Mtech1 wheel
                            -Ultimate cupholder
                            -Maplight mirror
                            Jay
                            • Ahheck01
                              • Aug 2004
                              • 185
                              Werd.
                              1992 525i 5speed: Sold :: 1996 328i 5speed: Sold :: 1997 540i 6speed: Sold :: 1995 M3ti 5speed: Sold :: 1997 328i 5speed: Sold ::
                              • blunttech
                                • 12850
                                69 2002 POS
                                smoke screen mod
                                blunt tech big brakes
                                sales@blunttech.com
                                www.blunttech.com
                                Like us on Facebook
