The Official List-Your-Mods Thread
  • kronus
    • Apr 2008
    • 13029
    #106
    might as well document it somewhere
    '87 325
    IE3 springs
    Bilstein sport shocks
    Powerflex offset CABs
    Bav Auto plug wires
    IE shorty manifolds, dual-pipe 325i exhaust to Bosal muffler
    325i airbox
    Turner chip
    UUC short-shift kit
    H4/H1 lights
    Euro grills
    Euro bumpers
    Euro valence with french fogs
    Pfeba front lip
    BBS rear spoiler (in transit)
    Redded-out tails
    Rear plate filler
    Kopi wheels
    front mudflaps (temporarily off)
    Alpina e30 Recaro seats
    Maplight mirror
    C33 radio
    infinity speakers (looking for proper BMW Premium speakers)
    Black door panels (carpet is still blue)
    TechI steering wheel
    mad tyte slightly yellow paint
    cars beep boop
    • newman
      • Mar 2007
      • 1159
      #107
      Chassis:
      • 1987 BMW 325IS (manual)
      •Seam Welded
      •Vito Antonicelli 10 Point Cage
      •Every suspension member powdercoated
      Body:
      •Ireland Engineering Fender flares
      •OEM Mtech1 Valences and Sideskirts
      •Euro Bumpers, Dechromed
      •Shaved Side Moldings
      •Shaved Fuel Door
      •Shaved Sunroof
      •Custom baby puke paint
      •Newman Engine Mount
      •Newman Transmission Mount
      •Custom Tunnel
      Engine:
      •R32 Nissan Skyline GT-R RB26DETT
      •87mm bore/3 angle valve job
      •Wiseco 87mm Pistons
      •Eagle Rods
      •HPE Crank collar
      •ARP head studs
      •ARP Flywheel Bolts
      •ARP Exhaust manifold studs
      •EPP valve guides
      •Ferrea Dual valve springs
      •Ferrea Valve spring locators
      •Ferrea Retainers
      •Ferrea Locks
      •ACL Calico coated main and rod race bearings
      •Garrett GT35R .82 A/R
      •Spitfire Coilpacks
      •New OEM Water Pump
      •New OEM Oil Pump
      •Trust Timing Belt
      •Powdercoated valve covers
      •OEM gasket kit
      •Cometic MLS Head gasket
      •Polished alternator
      •ATI 1000HP Race Damper
      •Custom valve shims
      •OEM timing tensioner and idler
      Transmission:
      •Modified RB26DETT Transmission
      •Nismo Flywheel
      •EXEDY 3 puck clutch
      •Custom Driveshaft
      •E30 M3 LSD 4.11
      •OEM slave cylinder
      Fuel:
      •Bosch -044 800HP fuel pump
      •Seimens 870cc injectors, flow calibrated to w/in .5% of each other
      •Summit 8 Gallon Fuel Cell
      •Custom Fuel Cell hold down straps
      •Custom Fuel Rail
      •Braided -8AN Fuel inlet line
      •Braided -8AN Fuel feed line
      •Braided -8AN Fuel return line
      •Aeromotive Rising rate regulator
      •Summit Inline fuel Filter
      •Custom filter and pump mounting brackets
      Exhaust:
      •Newman 304SS heavy wall manifold
      •Newman 304SS exhaust
      •Tial 38mm wastegate
      Induction:
      •Newman 304SS IC Plumbing
      •PWR 24X11X3 IC core semi-custom endtanks
      •Tial 50MM BOV
      Cooling:
      •MOXIES/Newman Radiator
      Electrical/Management
      •AEM EMS Speed Density Engine Management
      •AEM UEGO controller
      •AEM Serial Gauge
      •HKS Turbo Timer
      •New Engine Harness
      •Kwikwire Chassis harness
      •(4) Greddy warning gauges
      Suspension:
      •Ireland Engineering road race springs
      •Ireland Engineering poly trailing arm bushings
      •Ireland Engineering Poly Subframe mounts
      •Ireland Engineering 22/25mm swaybars
      •Ireland Engineering Camber/rear toe kit
      •Bilstein HD Dampers
      •New OEM wheel bearings
      •New OEM F&R strut mounts
      Wheels:
      •Work VS-XX wheels (17X10, 17X8.5) Custom Offset
      •Falken Azenis RT-615 275/40/17, 245/45/17
      •Vorshlag 90mm wheel studs
      Interior:
      •Sparco Evo Seats
      •Corbeau Harnesses
      •Sparco 300mm steering wheel
      •Rhinoliner interior and trunk
      Brakes:
      •Wilwood billet forged superlite narrow body, differential bore 6 piston calipers (front)
      •Wilwood superlite 4 piston caliper (rear)
      •Wilwood 13X1.1 GT48 rotor (front)
      •Wilwood 11.75X1.25 HD rotor (rear)
      •Cutsom machined rotor hats and brackets
      •Massive rear hat, ebrake ring and bracket
      •Wilwood Q pads
      •New OEM ebrake setup (backing plate, springs, adjusters, cables, pads, actuator, pin)
      •Wilwood Prop valve (installed next to driver’s seat)
      •Custom Brake Booster
      •Polished Master cylinder
      •-4AN stainless brake hardlines
      •-4AN stainless braided brake hoses
      1987 325is: 495whp/400ft-lb
      UPDATED 03/12/10!: RB26DETT Swapped E30
      • kronus
        • Apr 2008
        • 13029
        #108
        Dammit, newman!
        cars beep boop
        • Iain
          • Oct 2005
          • 2815
          #109
          Newman = nemesis = 'orrible c*nt?
          Impressive list. What model g'box you going with? Hopefully the R33 5MT as it is a fair chunk stronger than the ol' R32 nugget.
          Pork Hunt Motorsport
          eBay is like the summit racing catalog for today's special Olympics crowd
          • newman
            • Mar 2007
            • 1159
            #110
            Right now I'm going to use an R32 AWD transmission modified to be RWD only.
            • s38e30
              • Jul 2009
              • 53
              #111
              Hello to all.......
              New to the forum, not to BMWs
              My E30 with pics to follow later tonight when I get to it is:
              1986 325i (yes it is a euro for those who will say it didn't exist)
              Mods include
              Megan racing coilover (trying them based on reviews from other communities)
              treehouse CAB
              5 lug conversion
              M contours 17" (OEM)
              E34 M5 seats
              Euro Smilies
              Kamei eye lids
              iX fender flares
              E46 330i brakes
              Stock ti rears for now.........
              E32 750 hydraulic booster with MC
              Stainless lines
              All of this for the heart of the car-------
              1992 E34 M5 S38B36
              with 3.8 cam gears,
              individual K&Ns,
              Coil over Plug with wasted spark from the 3.8l
              Megasquirt
              When I get pics up tonight, please be gentle as it is my long term project. (primer and non-fitting front and rear bumper included)
              • oekundar
                • Sep 2007
                • 964
                #112
                Originally posted by s38e30
                Hello to all.......
                Mods include
                treehouse CAB
                5 lug conversion
                E34 M5 seats
                Euro Smilies
                Kamei eye lids
                iX fender flares
                E46 330i brakes
                Stainless lines
                1992 E34 M5 S38B36
                with 3.8 cam gears,
                individual K&Ns,
                Megasquirt
                Sounds like a pretty decent car/build...looking forward to pics.
                BMWCCA #389756
                • whatt18yahoo
                  • 619
                  #113
                  s38e30
                  i am curious about how you got the e34 seats tto mount up in the e30. the sizes are totally different and the mounts are even more so. whats more is i'm curious as to how you made them functional (if you did). if you did all of this mad props to you my friend cause seriously thats a lot of work.
                  • whatt18yahoo
                    • 619
                    #114
                    oekundar
                    where did you get the hood in your signature pic? whats it made of? whats the heat level under your hood relative to the original metal hood? and can i get one for my e34?
                    • JoeMadoo
                      • 936
                      #115
                      Might as well update after a year and a half.
                      Engine:
                      3.5L M30 (E34 535i/E32 735i)
                      "Team Joe" Motor Mount Brackets
                      K27 T3 Turbo (E23 745i)
                      Cast Iron Manifold (E23 745i)
                      10PSI L-Jet Wastegate (E23 745i)
                      Ebay Mechanical Boost Controller
                      SSQV 3" Blow Off Valve
                      A/A Intercooler 18"x6"x2.75"
                      2.5-3" Charge Pipes
                      Bosch 36# Injectors
                      E28 535i Radiator
                      Engine Fan Delete / Aux Fan Install
                      3" Turboback SS Exhaust
                      AEM Wideband o2
                      Megasquirt ECU
                      Modified Motronic Manual Wire Harness (E32 735i)
                      Volvo 740turbo Front Lip
                      '86 E30
                      '05 E53 X5
                      '72 Firebird
                      '10 Prius
                      '03 Tundra
                      • red325
                        • 961
                        #116
                        Originally posted by newman
                        Chassis:
                        •Seam Welded
                        Body:
                        •Shaved Fuel Door
                        •Shaved Sunroof
                        •Custom Tunnel
                        Engine:
                        •Eagle Rods
                        •HPE Crank collar
                        •ARP head studs
                        •ARP Flywheel Bolts
                        •EPP valve guides
                        •Ferrea Retainers
                        •Ferrea Locks
                        •Spitfire Coilpacks
                        •New OEM Water Pump
                        •New OEM Oil Pump
                        •Trust Timing Belt
                        •OEM gasket kit
                        •Custom valve shims
                        Transmission:
                        •Nismo Flywheel
                        •Custom Driveshaft
                        •E30 M3 LSD 4.11
                        •OEM slave cylinder
                        Fuel:
                        •Custom Fuel Rail
                        Exhaust:
                        Induction:
                        •Tial 50MM BOV
                        Cooling:
                        •AEM Serial Gauge
                        •HKS Turbo Timer
                        •New Engine Harness
                        Suspension:
                        Wheels:
                        Interior:
                        •Sparco Evo Seats
                        •Corbeau Harnesses
                        Brakes:
                        •Wilwood Q pads
                        Cost?
                          • 34839
                          #117
                          Originally posted by red325
                          Cost?
                          your first born son.
                          • kamotors
                            • Nov 2007
                            • 7102
                            #118
                            updated
                            exterior:
                            euro grills
                            smileys
                            black headlight rings
                            smoked turn signals
                            Is lip
                            splitter w/corner extensions
                            taurus skirts
                            zender spoiler
                            carbon emblems
                            MHW style tail lights
                            smoked euro plate filler
                            black side markers
                            suspension/wheels/brakes:
                            H&R sports
                            Bilstien sport shocks
                            HD mounts
                            H&R 20mm spacers
                            front and rear strut bars
                            green pads
                            performance:
                            cold air intake
                            Miller MAF
                            "alpina" headers
                            Kamotors heatshield
                            8mm plug wires
                            MSD coil
                            electric fan
                            19lb injectors
                            catco cat
                            magnaflow muffler
                            160lbs of weight reduction
                            4.10LSD
                            7speedshop.com
                            • tifosichris
                              • May 2008
                              • 216
                              #119
                              Got this a few weeks ago. Couldn't be happier (although i'm learning the co$ts of BMW ownership already...)
                              - Full J Stock Suspension
                              - Strut and Rear Shocks
                              - ST Sway Bar Set
                              - Front Camber Plates
                              - Offset Euro Upper Strut Mounts
                              - Chassis Reinforcement Pieces
                              - Rear Shock Mounts Aluminum
                              - Offset control Arm bushings
                              - Control Arms
                              - Custom Springs
                              - K&N Air Filter
                              - TMS / Conforti Performance Chip
                              - UUC Shift Kit
                              - Kosei K1s
                              - Sabelt 5 Point Race Belts
                              Completely gutted interior
                              Future mods? Plastic/euro bumpers, Brake kit (although the brakes on it are great. Slotted rotors, race pads and stainless brake lines). OBD1 S52? :D
                              Auto Technic J-Stock Suspension Kit, Bilstein Shocks and Struts, ST Sway Bars, Front Camber Plates, Offset Euro Upper Strut Mounts, Chassis Reinforced, Aluminum Rear Shock Mounts, Offset control Arm bushings, Custom Control Arms, Custom Springs, Conforti Chip, UUC Ultimate Shift Kit, Kosei K1s, Sabelt 5 Point Race Belts
                              • Andy348
                                • Sep 2009
                                • 688
                                #120
                                • 1986 325 5MT
                                Euro Grills
                                Smileys w/Yellow lamin-x
                                Tucked + Painted Diving Boards
                                Smoked Bumper turning signals
                                Painted chrome trim + windshield moulding
                                All red tails
                                M20B25 Swap
                                MarkD 91 octane chip
                                17lb Injectors
                                UUC Evo 3 w/DSSR
                                ZHP Knob
                                Apex 60/40 springs
                                Bilstein Sport Shocks
                                16x8 Rota Slipstreams
                                Euro Analog Clock
                                "Respect Your Elders" sticker :)
                                All of this is done or will be done within the next month.
