Fixed my cluster by swapping the oil pressure and temp sender connectors (PO swapped them unknowingly). I can see what my engine is doing finally!
What did you do to your E30 today?
This is a sticky topic.
Took my pass seat out. drove to work, filled with gas. Picked up my dog that had double ACL surgery (TPLO). See previously stated Pass seat delete. Tomorrow an oil change, brake fluid job and clean some windows while my dog is drugged up on the good stuff.Been with me for 16 years...
Wish i had more time to play with herComment
Wiggled the highbeam bulb and connector in to my low beams . HUGE difference with the same cutoff; not quite as bright as HIDs but I can finally see again!Bronzit 4-door Swap Drifting somewhere
Cammed B25 Swap Daily Driver
Updated 10/1
Originally posted by StereoInstaller1Maybe 300 CANADIAN HP, thats like 225 US HP.Comment
Replaced both transmission mounts, the air intake boot, the clutch slave cylinder, and the hose that runs from the clutch slave cylinder to the master cylinder. Bled the clutch and brakes. And drove it around the yard for the first time since I bought it. Pretty good day...Comment
I washed it in the rain. There's something awesome about washing a car in the rain, relaxing and invigorating at the same time. Very peaceful.Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.Comment
Put in an uncracked windshield. Looks great but now it needs an uncracked dash to match.87 325isComment
hack-fixed my coolant leak. Thought it was leaking at the waterpump, found out the end of a radiator hose was split next to the hose clamp. cut off 1/2" of the hose, clamped it back down. all fixed till i can get a replacement :D
