What did you do to your E30 today?
This is a sticky topic.
  • kingston
    • Jun 2010
    • 2669
    #3376
    Continued work on the donor M50. Got the head off, finished cleaning the block, and got it painted. Re-assembly finally about ready to start!
    Originally posted by LJ851
    kingston is the play by play announcer for this thread.
    ‘Tis by the grace of God that my cars run!
    Originally posted by unloadedak
    #teamross
    Siobhan's Build Thread - UPDATED!
    • F34R
      sLaughter
      • 12390
      #3377
      Painted my engine bay and ordered Bavauto Hi-performance coils. Later tonight installing cams and redoing the timing chains.
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • Jand3rson
        • 37587
        #3378
        Andrew and I just fixed my SPAL fan, wasn't coming on at all. Checked all the fuses, relays, pulled apart the wiring, couldn't find anything wrong. Turned out that the contacts for the relay up in the fusebox were pushed down inside of the housing. Pulled the fusebox apart, popped them back in, power to the relay/fuses and the fan works.
        • kingston
          • Jun 2010
          • 2669
          #3379
          Pulled the oil pan off of the M50, and cleaned up the head gasket area on the block, and cleaned the pistons.
          #teamross
          • MattAvino
            • Jan 2011
            • 2147
            #3380
            Dropped my subframe
            E30 buildy things
            http://www.r3vlimited.com/board/showthread.php?t=195286
            • thowes24
              • Jul 2010
              • 121
              #3381
              Got to work on it for the first time since I bought it. The PO removed the clutch slave cylinder to put in a new one and never did. He told me that the clutch just needed to be bled (liar). So I bought a new slave cylinder but now I have to order the vent screw for it before I install the new slave. Also worked on the vacuum lines today and figured out some lines that I need to purchase.
              • ethrtyiS
                • 8147
                #3382
                resprayed trim all around and installed smoked tint on lows, highs, and fogs.
                '89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5
                my feedback thread
                • VRSTLE
                  • Dec 2010
                  • 146
                  #3383
                  replaced the old m20 with a slightly less old m20 and did all the gaskets and replaced everything rubber
                  • Reap3r
                    • 596
                    #3384
                    Put the extractors back on & radiator back in properly to continue running it in NA. Will get the rest of the exhaust on tomorrow & fill up with coolant.
                    Turbo M42 Build thread:
                    http://www.r3vlimited.com/board/showthread.php?t=169672
                    • Erik
                      • Oct 2005
                      • 5370
                      #3385
                      Shaved my trunk roundel. Still need to finish with gloss black paint, but I like it so far.
                      -Erik
                      Originally posted by 87e30
                      • C!ph3r
                        • Aug 2011
                        • 34
                        #3386
                        put on a new set of bronze D-Force 15x7 wheels and tires.
                        • Bretts85E30
                          • 340
                          #3387
                          tucked my metal bumpers it looks 100 times better now but that oil smells alot lol
                          • Reap3r
                            • 596
                            #3388
                            Ripped the broken IE Engine mounts out that have 600km's on them & put vorschlag ones in. Can not even begin to say how dissapointed I am with Ie Engine mounts. Also filled it with coolant, put the exhaust on. Ran it up to temperature & made sure all was good.
                            Tomorrow will be bringing my home my drill & fitting race skid bash plate & bleeding my brakes.
                            • cbouchez
                              • May 2007
                              • 2789
                              #3389
                              CD43 installed! What a great stereo.
                              Follow my IG @bouchezphotography
                              • SilentJon
                                • Feb 2011
                                • 88
                                #3390
                                Originally posted by blalor
                                Track day prep continued yesterday. I went through the safety tech check myself (because at this point, I'm more familiar with this car than any paid-for mechanic), changed the transmission fluid (the old stuff smelled minty?!), replaced the exhaust hanger, and I think I'm good to go! The transmission was immediately quieter.
                                could have had marvel mystery oil in it, i cant think of anything else that would cause it to smell minty lol
