What did you do to your E30 today?
This is a sticky topic.
  • 325ix
    • Aug 2009
    • 7783
    #4351
    Yesterday, Andrew and I replaced my E36 window switches (one died, so we replaced them both with lighted ones), replaced my sunroof switch with an E36 switch, and finally after like 5 years, spliced in my late-model foglight pigtails, so I finally have functioning foglights.
    I really would like to do the e36 retrofit. However, I think I am going to take it one step further and install the one touch as outlined by a member on here.
    Also, I haven't even seen my car in a week. I hope to drive it later on tonite.
    • ttrousdell
      • Nov 2009
      • 1770
      #4352
      Continued to work on project money pit. Laid the cams, sprockets, valve cover.
      Threw the ITBs on for looks. They will go on once its in the car.
      Finally heres a hot chick near a porsche because I like it.
      The Build:
      • midwest
        • 64
        #4353
        Removed my entire front suspension because its all junk except the struts... those top ball joint nuts where a HUGE pita with the engine still in the car
        • 325ix
          • Aug 2009
          • 7783
          #4354
          [ATTACH]62757[/ATTACH]
          I like your style, all of it.
          • CHIF8008
            • 3447
            #4355
            swapped new wheels on the old e30. feels so good
            ,then vac'd the carpet of my new e30 and started to pull the dash apart
            -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
            -The Beauty in the Tragedy-
            MECHANIC SMASH!!- (you all know you do it)
            Got Drop?? ;-)
            But of course
            E30s are know to be notoriously really really really ridiculously good looking
            • randomtask37
              • 3154
              #4356
              I got some goodies in the mail today!
              SSR comps should be getting rubber later this week.
              I cleaned up and painted the valve cover and manifold. I took the valve cover off for the job because I needed a new valve cover gasket, but i didnt remove the manifold. i just masked it off. I think it turned out well. especially if you had seen how bad it looked before i started.
              Also, I installed a new clutch slave cylinder. it was a good day.
              98 M3/4/5
              • CHIF8008
                • 3447
                #4357
                "stretched" the fenders
                Got Drop?? ;-)
                But of course
                • Deathtoll
                  • Aug 2012
                  • 1285
                  #4358
                  Wow I really love SSR Comps!
                  -Art
                  • t1xj
                    • Nov 2012
                    • 10
                    #4359
                    bought it recently. today ordered shift knob, couple relays, blower resistor, bentley manual, odometer gears, delrin shifter bushings, dssr, cap, rotor, plugs, fuel filter, hood support, and just for fun a keyless entry system. adds up quick.
                    • austindavidg
                      • Oct 2012
                      • 17
                      #4360
                      Winter mode 325ix w/ Christmas lights!!
                      • bekurt
                        • Mar 2012
                        • 7
                        #4361
                        Slotted rotors from brakeperformance.com and Axxis pads! :D
                        • e30m3s54turbo
                          • Jun 2010
                          • 3205
                          #4362
                          Polishing my m88 valve cover.
                          • e30s50dan
                            • Nov 2008
                            • 2076
                            #4363
                            Block sanded....block sanded....block sanded.
                            NASA
                            BMWCCA member
                            PCA member 25yrs
                            1991 318IS slick top
                            1997 M3 sedan
                            2001 325CI DD
                            “whoever turns the wheel the least, wins"
                            • Kevinl
                              • Oct 2012
                              • 897
                              #4364
                              It took me 6 hours to install a radiator and motor and tranny mounts:letitout:
                              1989 BMW 325is Lachsilber metallic 5 speed
                              2007 BMW 335i KARMESINROT 6 Speed manual
                              2011 BMW X5 35I
                              • pputkowski
                                • May 2007
                                • 112
                                #4365
                                bought it... here comes the sickness again
