What did you do to your E30 today?
This is a sticky topic.
  • Dakotademon7
    • Jan 2014
    • 446
    #4951
    Just filled my tank up with free gas.
    sigpichttp://www.germanaudiospecialties.com/
    1986 325es :early:
    • deutschman
      • May 2008
      • 5958
      #4952
      Yesterday I did a valve adjustment, made things sound a bit less like a sowing machine.
      Added some oil as my m20b25 leaks (cant wait to do a swap of some kind)
      Took my radio out, still need to remove the front speakers.
      Installed a dash mounted horn button because steering wheel quick release race car shenanigans.
      • E30 Wagen
        • Jul 2005
        • 3425
        #4953
        After four months, finally finished the manual transmission swap on my eta, installed 325i cat and muffler. It is a massive understatement to say that I am elated to finally have the car driving again!
        My Feedback
        • Ray Smoodiver
          • Jun 2004
          • 8809
          #4954
          RH guard off, RH door off, rocker cover off to inspect the Alpina cam for lobe wear (none), front bumper off, interior out, leather conditioned, ignition system off, cooling system out, radiator out, bonnet off, and I'm sure there's other stuff I'm missing. Finished at 4:30am this morning ha.
          • Northern
            • 5071
            #4955
            Added some coolant. Check light was coming on for the past two weeks if I cornered/accelerated decently, but kept forgetting.
            I need to replace my alt belt and adjust the valves soon, but I'm so lazy.
            Originally posted by priapism
            Originally posted by shameson
            • lambo
              Captain Scene Points
              • 10953
              #4956
              Finally straightened my steering wheel after living with it slightly crooked for the past few months...
              • randomtask37
                • 3154
                #4957
                Gave her a bath.
                98 M3/4/5
                • ncsubowen
                  • Nov 2013
                  • 1012
                  #4958
                  New valve cover gasket + spark plugs. Had some fouling on plugs 4 and 5, so figured it was time to do that. Found a bolt hanging around in the valve train that I've yet to locate the source of, but it didn't manage to screw anything up so for now I sealed everything back up and went on with life.
                  4 doors.. so much room for activities!
                  IG @bluebombr
                  Transaction Feedback:
                  http://www.r3vlimited.com/board/showthread.php?t=323622
                  • fresh_TD
                    • Aug 2013
                    • 2457
                    #4959
                    This.
                    Sent from my Samsung Note 3
                    '91 318i (Alpine) - daily
                    '88 325ix (Zinno) - drive here and there!
                    • jd_e30
                      • Mar 2014
                      • 167
                      #4960
                      Bath, waterless wash, detail spray and brilliant glaze. Also removed broken brake light switch
                      1990 325i
                      • Northern
                        • 5071
                        #4961
                        Originally posted by fresh_TD
                        This.
                        <iX reman rack/subframe pic>
                        OEM rebuilt/reman rack or something else?
                        Drove around a bit, nearly overheated in a drivethough (again) even though its only 5 above freezing out.
                        Not sure if the coolant really needed to be bled, temp gauge is farked, or if something is seriously wrong with the car. So I bled the coolant.
                        • Oats
                          • Feb 2013
                          • 64
                          #4962
                          I replaced the slave cylinder and drove around town :p
                          • illest318i
                            • 1472
                            #4963
                            Omg its so beautiful. Do you have tint on your e30?
                            IG: @_j.wn
                            • DER E30
                              • Sep 2013
                              • 2343
                              #4964
                              Washed, quick detailer spray, tire shine, waxed my windows. Hopefully it doesn't rain tomorrow and ruin it...
                              -Christian
                              • Madhatter
                                • Oct 2004
                                • 966
                                #4965
                                I nearly tripped over this. When I bent down to throw it out the way I realised the purple tag and the part number, so I ran as fast as I could and stuck it in my boot to take home. Just what I needed, a new steering rack.
                                Looks to be in mint condition too. :D
                                Just a little project im working on
                                - http://www.lse30.com -
