What did you do to your E30 today?
This is a sticky topic.
  • Gkwan
    • Sep 2015
    • 82
    #5326
    Picked up some parts off of a guy on craigslist and changed the rear shock tower mounts.
    • FreedomM3
      • Aug 2015
      • 191
      #5327
      Got her running and finished installing the rear bilsteins. Yay.
      Our RestoMod Diary!
      El Mustache De La Resistance!
      • ishy_gift99
        • Oct 2015
        • 3
        #5328
        i need help with a muffler!
        i have a 1984 318i e30 and i wanna know whats the best muffler ! was thinking about magnaflow or vibrant! help
        • DER E30
          • Sep 2013
          • 2349
          #5329
          I had a magnaflow knock off and that thing was loud and droned. Even with a resonator. My new 2.5inch borla is quieter, but still fairly loud and droney. Granted you're an m10 and I'm m42 but similar things.
          -Christian
          • JeLani
            • Aug 2015
            • 1552
            #5330
            Noticed that my 327i does have 1.3 ecu but there are a few unplugged wires i noticed :(
            1986 LTW M52 (First project 2015- )
            1998 e36 328ic/5 -
            Roundie alpina pig cheek’d (1969)
            1967 2002 parts car
            1994 318iS junked.
            • Andy.B
              • Sep 2011
              • 1650
              #5331
              Under the hood or in the glove box. If you're talking glove box, that is normal.
              If you don't have cruise control, an auto transmission, 13 button clock, etc, there will be unused wires. Even with all those things, there may be unused wires afaik.
              • rzerob
                • Jun 2013
                • 2315
                #5332
                Parking brake shoes and hardware. And adjusted them.
                • rzerob
                  • Jun 2013
                  • 2315
                  #5333
                  Tore it all apart to replace the rear main seal and front seal on transmission. Then put it back together again.
                  • JeLani
                    • Aug 2015
                    • 1552
                    #5334
                    barely reading this now, but yes in the glovebox. thank you.
                    1998 e36 328ic/5 -
                    1967 2002 parts car
                    1994 318iS junked.
                    • ak-
                      • 12422
                      #5335
                      RSM's this evening.
                      1991 325iS turbo
                      • FreedomM3
                        • Aug 2015
                        • 191
                        #5336
                        Those are nice! Designed to give you more shock travel?
                        Our RestoMod Diary!
                        • Blake B
                          • Feb 2015
                          • 150
                          #5337
                          Installed the Europlate and vacuumed it out for the 3rd time in a week. I hate fall, leaves get tracked everywhere.
                          also, the girl friend taught me how to use the Cricut in the picture, can make my own stickers and stuff now :devil:
                          1990 325i Cashmere Beige
                          "I don't like question marks. They're like exclamation points, but think they're fancy because they're curved. I won't tolerate it." -MNChiefsan
                          • spanish pants
                            • 294
                            #5338
                            Finally got around to ordering front wheel bearings. They´re not here yet but i decided to speed things up by removing the old ones during the weekend.
                            They literally fell out after i removed the discs.
                            My new E34 525i Sport Limousine Blog
                            http://bmw525isportlimousine.blogspot.com.es/
                            • itsonlygeorge
                              • Feb 2014
                              • 852
                              #5339
                              Mounted late model under splash guard. I am missing two of the frame mounts so I ended up using 24" heavy duty zip ties around the frame. Now my brake ducts are properly mounted and not floating.
                              During the last two weeks I replaced the fuel tank and in-tank fuel pump motor, replaced the rear soft brake lines with stainless lines, painted the exhaust, replaced water pump and timing belt, flushed the coolant and replaced it with BMW coolant, adjusted the valves and painted the valve cover.
                              I also ground off any surface rust and painted on the front subframe and transmission cross members and radiator bracket. I resprayed some of the undercoating as well.
                              Rotated the tires as well, seems that the steering shimmy was from the rims that are now in the rear.
                              1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
                              Originally posted by nando
                              I don't think there's really strong evidence that ZDDP harms cats.
                              • m3crazyo
                                • Dec 2013
                                • 1
                                #5340
                                I put my Mtech II steering wheel on.
