What did you do to your E30 today?
This is a sticky topic.
  • Joe_Nycalive
    • Apr 2020
    • 5
    #5776
    Swapped my bolts to studs but found out my rear spindles are shot so now have to replace my spindles So much fun
    1988 321 - Currently in pieces
    2008 335xi - lightly modded…….
    2003 Element - My everyday beater :)
    NYC ALIVE
    • roguetoaster
      Biggus Tippus
      • 7830
      #5777
      Changed the cam sensor seal, replaced the driver's sill trim, and repainted the lower exterior trim.
      • TeXJ
        • 1914
        #5778
        yesterday, installed the tuner coolant temp sensor(OBD2) and the splitter for the obd1 signals. I'm obd1 swapped and the sensor was in the head was a obd1 sensor and would need to be rethreaded to fit the obd2 head.
        1990 325is
        m52b28
        3.73lsd
        g260 (1987 325is 5spd tranny)
        • prisonerofdoom83
          • May 2013
          • 529
          #5779
          Got bored got custom with it
          • strickland
            • Sep 2018
            • 251
            #5780
            Finally got around to adding sound deadener.
            1989 325is ✨
            • sdfe30
              • May 2020
              • 7
              #5781
              Finally started getting some parts in for my late model 318. This was the first to show up, other than the poly bushings, which I'm waiting on new suspension components to do.
              Of all the parts on order, this was the first to come in. The console was detailed immediately after this, so don't worry about the grime.
              Incoming:
              z3 rack with garagistic kit
              Garagistic Offset FCA bushings
              Koni Orange and H&R sports all around
              e90 top hats
              new front shock mounts/bearings
              Garagistic rear subframe and diff bushings
              Rear wheel bearings
              Mtech 1 Steering wheel
              • 808ETA
                • Nov 2018
                • 436
                #5782
                How is the sound deadening? Is there a noticeable difference?
                sigpic84 325e
                • jhaurimn
                  • Nov 2012
                  • 2224
                  #5783
                  Originally posted by e30vert
                  Replaced rear trunk shock and adjusted the trunk to be flush when closed. With a new shock installed there was upward pressure on the drivers side that pushed the trunk up just a little bit. Adjusted the center bracket thingy to bring the trunk down a tad more when shut. Its so weird having the trunk pop open now when I press the button to open it.
                  Looks like this person hasnt been active since May, I will try PM'ing them but does anyone understand what was done to fix this?
                  Current:
                  1989 325i
                  1988 M3
                  1987 325ic
                  Past:
                  2001 330ci
                  2001 M3
                  • Narsiyousif
                    • Dec 2016
                    • 71
                    #5784
                    easy modification to the headlight
Name:	117173817_10222877163228485_2450690843636116447_o.jpg?_nc_cat=107&_nc_sid=0debeb&_nc_ohc=-QqCFkCHBNAAX87shoD&_nc_ht=scontent.fsan1-2.fna&oh=8eeb9c93181ce960f3a5aa7db10badde&oe=5F55126D.jpg
Name:	117309012_10222877162108457_2022748999036814302_o.jpg?_nc_cat=102&_nc_sid=0debeb&_nc_ohc=u77uKJEO0E0AX_BerQs&_nc_ht=scontent.fsan1-1.fna&oh=9f957285ed266c88f1f2bb079d52ac03&oe=5F54BA88.jpg
Name:	117120452_10222877161588444_5590831335070397629_o.jpg?_nc_cat=105&_nc_sid=0debeb&_nc_ohc=150jj6BhtLIAX--w4Ij&_nc_ht=scontent.fsan1-2.fna&oh=20c371f4b239298f38b97231b2b9a7b8&oe=5F56D5FD.jpg
Name:	117538382_10222877163428490_4402550674891865997_o.jpg?_nc_cat=102&_nc_sid=0debeb&_nc_ohc=eK1jWF5FyM4AX8Myjlq&_nc_ht=scontent.fsan1-1.fna&oh=519af7a410c67cea3d32fd8a2e34ae03&oe=5F55B185.jpg
                    • Stan
                      • Jul 2019
                      • 780
                      #5785
                      very low tech, installed Laminex on my headlights and fog lamp lenses.
                      • Narsiyousif
                        • Dec 2016
                        • 71
                        #5786
Name:	118460049_10223011607429506_3140797444215601070_o.jpg?_nc_cat=100&_nc_sid=0debeb&_nc_ohc=10Jog8TpI_wAX_sKOZG&_nc_ht=scontent.fsan1-2.fna&oh=cdf6a381be587514953fbe5323cd9958&oe=5F7D5095.jpg
Name:	118626420_10223011608069522_5958050443511287550_o.jpg?_nc_cat=109&_nc_sid=0debeb&_nc_ohc=E4sM-BUMLYAAX8NKnic&_nc_ht=scontent.fsan1-1.fna&oh=a3bffe01faecd469617d34bfa32e9c56&oe=5F7D39F7.jpg
Name:	118620787_10223011610349579_4825364859840178178_o.jpg?_nc_cat=106&_nc_sid=0debeb&_nc_ohc=3oaPUWJJSTEAX_RYMQU&_nc_ht=scontent.fsan1-1.fna&oh=c4312f3a95b8c68f47a8f63a8fa22986&oe=5F7EB03A.jpg
Name:	118620182_10223011610789590_4418600532278031013_o.jpg?_nc_cat=110&_nc_sid=0debeb&_nc_ohc=j-cf3AwaXYIAX8fJfuk&_nc_ht=scontent.fsan1-1.fna&oh=d0db799e2a61947540a8c74b7ec3f50a&oe=5F7EBE7C.jpg
Name:	118616637_10223011611269602_5545573521736303190_o.jpg?_nc_cat=101&_nc_sid=0debeb&_nc_ohc=ScJVIDN2CuoAX_bN-4_&_nc_ht=scontent.fsan1-2.fna&oh=1e4cd8cd5be76b95085ace4043ce3fb8&oe=5F7F0D6B.jpg
                        • Narsiyousif
                          • Dec 2016
                          • 71
                          #5787
                          • Narsiyousif
                            • Dec 2016
                            • 71
                            #5788
                            • Narsiyousif
                              • Dec 2016
                              • 71
                              #5789
                              Click image for larger version  Name:	119007554_10223096114662134_6003893078296591764_o.jpg?_nc_cat=110&_nc_sid=0debeb&_nc_ohc=CAyT89gD4K4AX8oIfDx&_nc_ht=scontent.fsan1-1.fna&oh=542cc7838f08b5a563602900cb2da708&oe=5F7F45BB.jpg Views:	0 Size:	50.1 KB ID:	9949671
                              Click image for larger version  Name:	118783537_10223096113542106_8478601566873728079_o.jpg?_nc_cat=108&_nc_sid=0debeb&_nc_ohc=cqcgfn3Ww2IAX8cNs3b&_nc_ht=scontent.fsan1-2.fna&oh=505de00426eeb10dd830020322661229&oe=5F7CF355.jpg Views:	0 Size:	59.5 KB ID:	9949672
                              Click image for larger version  Name:	119057759_10223096113862114_7924146087181772091_o.jpg?_nc_cat=100&_nc_sid=0debeb&_nc_ohc=SKLTg6TRGcIAX8B2JEy&_nc_ht=scontent.fsan1-2.fna&oh=7ad8c3eefaa2482f992578733870f98f&oe=5F7F2F5E.jpg Views:	0 Size:	45.3 KB ID:	9949673
                              Next will be the custom leather wrap and will be done :)
                              • Blake B
                                • Feb 2015
                                • 150
                                #5790
                                not making a ton of progress as of right now but i figure if i'm out in the garage cleaning things up, it's better than nothing
                                Click image for larger version  Name:	IMG_20200725_140724.jpg Views:	0 Size:	108.1 KB ID:	9951117
                                Click image for larger version  Name:	IMG_20200725_153629.jpg Views:	0 Size:	53.0 KB ID:	9951118
                                Also picked up a few more 885 heads which brings the tally to 4 now. I guess I'll get around to rebuilding them eventually.
                                Click image for larger version  Name:	IMG_20200628_112538_291 (1).jpg Views:	0 Size:	96.4 KB ID:	9951115
                                1990 325i Cashmere Beige
                                "I don't like question marks. They're like exclamation points, but think they're fancy because they're curved. I won't tolerate it." -MNChiefsan
