Swapped my bolts to studs but found out my rear spindles are shot so now have to replace my spindles So much fun
What did you do to your E30 today?
This is a sticky topic.
Finally started getting some parts in for my late model 318. This was the first to show up, other than the poly bushings, which I'm waiting on new suspension components to do.
Of all the parts on order, this was the first to come in. The console was detailed immediately after this, so don't worry about the grime.
Incoming:
z3 rack with garagistic kit
Garagistic Offset FCA bushings
Koni Orange and H&R sports all around
e90 top hats
new front shock mounts/bearings
Garagistic rear subframe and diff bushings
Rear wheel bearings
Mtech 1 Steering wheel
Originally posted by e30vert View PostReplaced rear trunk shock and adjusted the trunk to be flush when closed. With a new shock installed there was upward pressure on the drivers side that pushed the trunk up just a little bit. Adjusted the center bracket thingy to bring the trunk down a tad more when shut. Its so weird having the trunk pop open now when I press the button to open it.
Current:
1989 325i
1988 M3
1987 325ic
Past:
2001 330ci
2001 M3
"I don't like question marks. They're like exclamation points, but think they're fancy because they're curved. I won't tolerate it." -MNChiefsan
