Congrats man! Finally!
Another S50 E30 Build
Nice! When you have it up and running you should come out to a in-n-out meet on a thursday night. What are your plans for exhaust setup?Comment
gonna drive it open header to Tri-Valley saturday morning. Dave doesnt work there anymore, but his shop foreman George took over and he is still doing work for Edge, so thats good enough for me.IG: @Baye30
FRONT VALENCE IS ZENDER!!! STOP FILLING MY PM BOX PPL!!!Comment
that is a damn fine automobile you got there. this is the first time i have viewed this thread but i just sat down and read all 7 pages. looks like you hit a few snags here and there but big time congrats on getting it running. if you dont mind my asking, i am curious about the next cost of the swap. how much was the total when you were done?what exactly is sigworthyComment
fuck. my brakes dont work. i think the booster is bad. gotta find another booster, and pull the intake manifold off again to change it out. gonna be a lil while i suppose, holiday weekend means i aint gonna find a booster anytime soon. damnit.IG: @Baye30
i did install the IX booster upside down so that the vaccum is on the engine side, that shouldnt matter though.Last edited by golde30; 02-15-2008, 10:32 PM.IG: @Baye30
my car too idled smoothly even with the leaky booster.
i tested my booster the following way: put my mouth to the hole, suck real hard while i pressed the rod into the ground...if the booster's good, the rod should literally push in with very minor effort
i did the same thing as you did...moddin the rod to eliminate the spacer and be able to fit the resevoir where its supposed to ;) badass!!No more e30s for me.
88 black BMW OBDII 332is dedicated track [sold]
88 BMW OBDII bronzit 332is [RIP 03/08]
91 BMW 325i [sold]
86 Corolla 'Ae86' HB 20v trd [sold]
http://youtube.com/watch?v=pTj7Hn9v5RsComment
Yea, check the check valve, make sure it is in the right way around. Also, you can use the booster from a 735, I believe. It's the one I used.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
i urge you to recheck vacuum and the grommet on the booster....i had the same problem and it turned out to be a stupid leak problem...also check that checkvalve. hope its not a bad booster. if anything i got an IX one laying around which i bought becuase i thought i had a bad booster.
That and maybe spray some carb cleaner or something around the fitting too and see if the idle changes from it getting sucked in. Test all over the vacuum lines. Even though you said you just moved the vacuum line from your old booster to this one, check the valve and all that anyway. I've never had to, but if you do end up removing the booster before figuring it out, try that method of making your own vacuum and pushing the rod in...Comment
got the brake situation worked out. i didnt cut down the booster rod enough, so i had to bend the tab on the brake pedal. that metal on the pedal is freakin strong, was really hard to bend even after getting it red hot first.
so now i just need to get the exhaust fabbed up and installed and i will be good to go. hopefully i can squeeze in a photo shoot this weekend.IG: @Baye30
Awesome!!!Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Cary... I will be driving back from south of pleasanton on Saturday night if maybe I could stop by, and we could meet up for a sec to shoot a few... It would be later though, like midnightish. Lemme know.
"BMW Style 32 Poster-Child"
HTTP://WWW.CLAVINZERO.COM/e30-5-lug
**(My Guide to E36 M3/Z3 1.9L 5-lug Swap)**
