Surgery for the track car
  • JGood
    • Jan 2004
    • 7959
    The 87 325is track car had some rust forming in the floorboard. I went to jack up the car from the square lift point, which then went up into the carpet. So began the surgery:
    • Cut nice big square area out of floor
    • Cut similar square, but ~1" bigger in all directions, out of parts car (89 325i)
    • Clean all the undercoating and paint from area
    • Discover rust in replacement panel (DOH!!!)
    • Clean away rust, find a 1" hole left over
    • Weld new metal into replacement panel
    • Weld panel into car (from underneath, so it overlaps)
    • Grind welds, seal it (used body filler)
    • Spray undercoating
    • Spray duplicolor red on inside, which is pretty close to zinno (close enough for a track car, anyway)
    Obviously, this is far from professional, and was done in the spare time I have between full time work and school, to get a track car ready for the season. So don't bust my balls too bad
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
  • 153624
    • Jan 2008
    • 82
    Good job! I did the same with a bunch of mid 80's fords at my last Job. I failed to pay attention to details as much as you did.
    88 325 S-ETA --Wahwooweewah
    • Joe318is
      • Sep 2005
      • 6451
      Nice work, but im pretty sure thats NOT a jacking point.
      Originally posted by vlad
      • Teaguer
        • Sep 2004
        • 6167
        Haha I was going to say the same thing .
        Oh and Jordo would NOT approve . :D
        • JGood
          • Jan 2004
          • 7959
          That square is not a jacking point? I most often just use the frame rail anyway, but every shop I've ever been to has used that square.
          Why wouldn't Jordo approve? I kept it red, no pink paint here...
          • FredK
            • 14761
            Jordo got into an e-fight with this canuck about welding in patches in the floor. But, that's water under the bridge.
            Good job on the fix though. Nice and strong.
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              But this guy used pateches of what look like other e30's the other guy was using scrap.
              • JGood
                • Jan 2004
                • 7959
                I though Teaguer was referring to Jordon's respect for my Mark Kay Pink eta.
                • Spiff325iS
                  • Jun 2004
                  • 1263
                  Sick build man. I would love to undergo a project like that. Nice work!
                  The Red Dragon V.5 1991 318iS / 2013 F800GT
                  "You gotta fix the nut behind the wheel before you fix the bolts on the car"
                  • Zorin
                    • 67
                    It was me and I didn't weld in scrap metal, but brand new sheet metal same thickness as the original metal. Please don't post comments when you don't know what was used. You commented that welding in new pieces will make the car weaker - any comments this time or is it ok to weld in 20+ years old piece of metal versus brand sheet metal ?
                    gary muwaut
                    89 325ic / 05 325i
                    • 155///MPH
                      • 473
                      Do yourself a favor and remove the rest of the sound deadening, a lot of hiding places for rust.
                      DE's are a tease.
                      Build a racecar.
                      • JGood
                        • Jan 2004
                        • 7959
                        Easy turbo.... Looks like you got a nice build going though! This kind of work is fun when it's not your daily. This was second body job, and since it was on my track car vs. the daily, I actuall really enjoyed it.
                        • JGood
                          • Jan 2004
                          • 7959
                          Yep, it's already gone. I've found a very small amount of rust on the drivers side floorboard, but due to time constraints it's going to have to wait til next winter. I know it will grow, but I simply don't have the ability to fix it if I am going to get it back on the track for the two series that I run.
                          • Zorin
                            • 67
                            Thank you and your repair job looks very good.
                            I would recommend applying primer before applying paint and undercoating.
                            gary muwaut
                            89 325ic / 05 325i
                            • Farbin Kaiber
                              Lil' Puppet
                              • 29502
                              Hey amigo, by scrap I meant "non e30 component" material. Scrap, new, whatever. Bottom line is you used peices of metal, wheras he used peices of e30. Pull th pompasasity out of your attitude. For fcuks sake, Jessie James makes tanks/frames out of "Scrap/Bulk" so don't take it to the butt.
